REV.
B
NOTES:
1. ALL ITEMS SHIPPED NON-ASSEMBLED.
2. SEALED TO IP67 RATING.
DESCRIPTION
DATE
4/4/17
Engineering Release
APPROVED
J.C.
SEAL
POLYURETHANE, 94V-0
WASHER, WHITE NYLON, 94V-0
LIGHT PIPE
CLEAR PC, 94V-0
NUT, M4 X 0.50, WHITE NYLON, 94V-0
TORQUE: 10-11 in-oz
0.315in 8.0mm
REF
0.050in 1.3mm
0.197in 5.0mm
0.25in 6.4mm
TABLE A
L
HOLD HEAD
WHILE TORQUING NUT
+0.003
+0.08
0.177in - 0.001 4.50mm - 0.03
RECOMMENDED MOUNTING HOLE
PANEL THICKNESS: 0.047" - 0.093"
PART NUMBER CONFIGURATION
PANEL, REF
PART No.
PLTR5-250-PRX
PLTR5-500-PRX
PLTR5-1000-PRX
PLTR5-1500-PRX
PLTR5-2000-PRX
PLTR5-2500-PRX
PLTR5-3000-PRX
PLTR5-8MM-PRX
PLTR5-16MM-PRX
PLTR5-24MM-PRX
PLTR5-32MM-PRX
PLTR5-40MM-PRX
PLTR5-48MM-PRX
PLTR5-56MM-PRX
PLTR5-64MM-PRX
PLTR5-72MM-PRX
TABLE B (SEAL)
L = BODY LENGTH
0.250 (6.4mm)
0.500 (12.7mm)
1.000 (25.4mm)
1.500 (38.1mm)
2.000 (50.8mm)
2.500 (63.5mm)
3.000 (76.2mm)
8mm (0.315")
16mm (0.630")
24mm (0.945")
32mm (1.260")
40mm (1.575")
48mm (1.890")
56mm (2.205")
64mm (2.520")
72mm (2.835")
COLOR
BLACK
WHITE
CODE
1
2
TABLE C (DYE)
COLOR
BLUE
BLACK
GREEN
GRAY
RED
YELLOW
NONE
CODE
BE
BK
GN
GY
RD
YW
BLANK
STANDARD TOLERANCE
(UNLESS OTHERWISE SPECIFIED)
PLTR5-XXX-PRX XX
LIGHT PIPE DYED COLOR, TABLE C
SEAL COLOR, TABLE B
L = BODY LENGTH, TABLE A
DECIMALS
.X
.XX
.XXX
± .1
± .01
± .005
DESIGNED:
TD. NGUYEN
CHECKED:
J. CHIANG
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE: LIGHT PIPE, 5mm, IP67
DATE:
4/4/17
DATE:
4/4/17
PART NO:
PLTR5-XXX-PRX
REVISION:
B
CAGE CODE : 32559 SHEET # 1 OF 1
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING
很抱歉,暂时无法提供与“PLTR5-500-PR2”相匹配的价格&库存,您可以联系我们找货
