CSC36AC
CSC36AC
    TRIPPLITE
    36-DEVICEACCHARGINGSTATIONCA
CSC36AC 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Multi-Device Charging Cart, 36 AC Outlets, Chromebooks and Laptops, Black MODEL NUMBER: CSC36AC Highlights ● Charges 36 Chromebooks and laptops with screen sizes up to 15 in. ● Hourly timer alternates charging zones to help prevent overloads ● In-cabinet RJ45 jack allows secure use of a wireless router ● Convenient external outlets provide power for a monitor or projector Package Includes Keep up to 36 Chromebooks and laptops secure, charged and ready to use. Ideal for classrooms, businesses and government organizations that rely on daily use of mobile devices. Features Charges 36 Chromebooks and Laptops Up to 15 in.Device power adapters plug into internal NEMA 515R outlets (up to 1,440 watts total)Also charges tablets and other USB devices through their power adaptersExtra internal AC outlet for powering peripheralsRJ45 jack for external Ethernet networking10-ft. (3.05 m) AC input cord with NEMA 5-15P plug reaches distant outlets Timed Device Charging to Guard Against OverloadsInternal outlets split into 2 color-coded zones of 18 outlets eachTimer alternates charging between zones hourlyLEDs indicate which zone is being charged Dual External AC OutletsNEMA 5-15R outlets for connecting projectors and other devicesCan be switched on and off to protect against possible overloads Comprehensive ProtectionDevices and adapters kept in separate, lockable compartmentsDoors lock with included keys to help prevent theft, damage and tamperingFlow-through ventilation helps prevent overheatingCircuit breaker protects against overloadsHeavy-duty steel construction and powder-coated finish promote long-term durability Clutter-Reducing OrganizationHeavy power adapters store out of the way in removable rear basketsCables and connectors run through shelf slots and overhead cable managerDevice spaces numbered for easy identification Simple MobilityLocking swivel casters with non-marking wheels for smooth, even rideReversible widegrip handle assists cart controlPower cord wrap keeps input cord out of the wayCorner safety bumpers prevent scratches on walls and doorwaysCompact cart fits in same space as typical AV cart Flexible ConfigurationShips ready for quick, easy installation—just attach handle, bumpers and cord wrapAdjustable dividers accommodate up to 12 devices per shelfLaminated wood-grain top serves as a smooth writing surface Specifications 1/4 ● CSC36AC 36-Device AC Charging Station Cart, Black ● Cart handle ● Input cord wrap ● (6) Protective bumpers ● (10) Hex screws ● Hex key ● (2) Keys ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332200488 Product Type Multi-Device Charger Charging Form Factor Mobile Cart Functions Charge; Secure Device Compatibility Chromebook; Laptop Device Slots 36 INPUT Nominal Input Voltage(s) Supported 120V AC Voltage Compatibility (VAC) 120 Input Frequency 60 Hz Input Plug Type NEMA 5-15P Input Cord Length (ft.) 10 Input Cord Length (m) 3.05 CHARGING Number of Charging Ports 36 Charging Method AC Charging Port Type NEMA 5-15R Charging Ports Details Pass through Charging Ports / Amps (36) 12A Overcharge Protection No Charging Amps per Port 12A PHYSICAL Color Black Material of Construction Steel Charging Station Form Factor Mobile Cart Shipping Dimensions (hwd / in.) 46.85 x 26.77 x 29.13 Shipping Dimensions (hwd / cm) 119.00 x 68.00 x 73.99 Shipping Weight (lbs.) 188.00 Shipping Weight (kg) 85.28 Slot Dimensions - Bottom (hwd / in.) 10.11 x 1.5 x 15.58 Slot Dimensions - Bottom (hwd / mm) 256.9 x 38.22 x 395.72 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Slot Dimensions - Middle (hwd / in.) 10.13 x 1.5 x 15.58 Slot Dimensions - Middle (hwd / mm) 257.3 x 38.22 x 395.72 Slot Dimensions - Top (hwd / in.) 10.13 x 1.5 x 15.58 Slot Dimensions - Top (hwd / mm) 257.3 x 38.22 x 395.72 Unit Dimensions (hwd / in.) 40.030 x 24.300 x 23.560 Unit Dimensions (hwd / cm) 107.45 x 71.04 x 56.13 (with handle installed) Unit Weight (lbs.) 110.23 Unit Weight (kg) 50.00 Number of Shelves 3 Assembly Required Yes FEATURES & SPECIFICATIONS Cord Management Yes Antimicrobial No EMI/RFI Line Noise Protection No Locking Yes Lock Type Key IP68 Rated No Built-In Circuit Breaker Yes Overcurrent Protection Yes Flow-Through Ventilation Yes UV Sterilization No IP20 Rated No STANDARDS & COMPLIANCE Product Certifications CAN/CSA-C22.2 No. 60950-1 (Canada); NOM (Mexico); UL 60950-1 Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty CATEGORY PAGE FILTERS (Y/N ONLY) External Receptacle Yes 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
CSC36AC 价格&库存
很抱歉,暂时无法提供与“CSC36AC”相匹配的价格&库存,您可以联系我们找货
