U022-010-BE
U022-010-BE
    TRIPPLITE
    U022-010-BE
U022-010-BE 数据手册
USB 2.0 A to B Cable (M/M), Beige, 10 ft. (3.05 m) Highlights ● Supports data transfer rates up to 480 Mbps ● Premium foil and braid shielding ● Gold-plated connectors and contacts ● Twisted 28/24 AWG data/power lines ● Backward compatible with earlier USB generations MODEL NUMBER: U022-010-BE Package Includes ● Connects high-speed USB 2.0 peripherals with a USB-B port to your computer, laptop or other compatible USB-A device. Recommended for printers and scanners. Description The U022-010-BE USB 2.0 Hi-Speed A/B Cable (M/M) connects your computer, laptop or other compatible USB-A device to a USB-B peripheral, such as printers and scanners. This 10-ft. (3.05 m) cable supports data transfer rates up to 480 Mbps for both low- and high-speed devices, including multimedia applications. Premium foil and braid shielding delivers reliable, error-free signal quality and protection from EMI/RFI interference. Molded gold-plated connectors with gold-plated contacts ensure excellent conductivity. Integral strain relief ensures the cable and connectors last a long time. A rugged PVC jacket protects twisted 28 AWG data lines and 24 AWG power lines. Features Connect Your USB Type-B Peripherals to Your Computer ● Recommended for printers and scanners ● Supports data transfer rates up to 480 Mbps ● Backward compatible with earlier USB generations First-Rate Construction for Superior Signal Transfer ● Premium foil and braid shielding for EMI/RFI noise protection ● Molded nickel-plated connectors for optimal signal quality ● Integral strain relief for long life ● Twisted 28/24 AWG data/power lines ● Flexible PVC jacket easy to install in tight spaces Specifications OVERVIEW UPC Code 037332198792 1/2 U022-010-BE USB 2.0 HiSpeed A/B Cable (M/M), Beige, 10-ft. (3.05 m) Technology USB 2.0 (High Speed) USB Cable Type Passive PHYSICAL Cable Jacket Color Beige Cable Length (ft.) 10 Cable Length (m) 3.05 Shipping Dimensions (hwd / in.) 0.50 x 6.70 x 8.00 Shipping Dimensions (hwd / cm) 1.27 x 17.02 x 20.32 Shipping Weight (lbs.) 0.30 Shipping Weight (kg) 0.14 ENVIRONMENTAL Operating Temperature Range 14 to 122 F (-10 to 50 C) Storage Temperature Range 5 to 140 F (-15 to 60 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing CONNECTIONS Side A - Connector 1 USB A (MALE) Side B - Connector 1 USB B (MALE) STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
U022-010-BE 价格&库存
很抱歉,暂时无法提供与“U022-010-BE”相匹配的价格&库存,您可以联系我们找货
