Male-to-male is not a standard USB cable configuration. It’s used only in rare instances where a
peripheral or patch bay employs a female connector instead of a USB-B port.Not for use with Tripp Lite's
Highlights
Supports data transfer rates up
to 5 Gbps
Nickel-plated connectors with
gold-plated contacts
Data flows both directions
simultaneously
Twisted 28/24 AWG data/power
lines
Backward compatible with
earlier USB generations
U325-000-KP-BK, U325-000-KPA-BK or U325-001-KPA-BK. The U325-003 and U325-006 USB A
Male/Male cables are designed for use with those products. This cable will not connect two PCs. Filesharing between computers requires special software-driven cables, such as Tripp Lite’s U234-006-MP-R.
USB 3.0 SuperSpeed A/A Cable (M/M), Black, 6 ft.
(1.83 m)
MODEL NUMBER: U320-006-BK
System Requirements
Computer with USB-A female
port
Peripheral or patch bay with
USB-A female port
Package Includes
Connects peripherals and patch bays with female USB-A ports to your computer, laptop or other
compatible USB 3.0 device, such as a Chromebook™ or Microsoft® Surface®.
Features
Connects Your USB Type-A Peripherals to Your Computer
● Recommended for peripherals, patch bays, computers, laptops and other compatible USB 3.0 devices
with female connectors
Supports data transfer rates up to 5 Gbps
Bi-directional data interface allows data to flow both directions
Backward compatible with earlier USB generations
First-Rate Construction for Superior Signal Transfer
● Premium foil and braid shielding for EMI/RFI noise protection
Molded nickel-plated connectors for optimal signal quality
Integral strain relief for long life
Twisted 28/24 AWG data/power lines
Flexible PVC jacket easy to install in tight spaces
Specifications
OVERVIEW
1/2
U320-006-BK USB 3.0
UPC Code
037332198730
USB Cable Type
Passive
PHYSICAL
Cable Jacket Color
Black
Cable Length (ft.)
6
Cable Length (m)
1.83
Shipping Dimensions (hwd / in.)
0.50 x 7.00 x 9.50
Shipping Dimensions (hwd / cm)
1.27 x 17.78 x 24.13
Shipping Weight (lbs.)
0.20
Shipping Weight (kg)
0.09
ENVIRONMENTAL
Operating Temperature Range
14 to 122 F (-10 to 50 C)
Storage Temperature Range
5 to 140 F (-15 to 60 C)
Operating Humidity Range
0% to 90% RH, Non-Condensing
Storage Humidity Range
CONNECTIONS
Side A - Connector 1
USB 3.0 A (MALE)
Side B - Connector 1
USB 3.0 A (MALE)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“U320-006-BK”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+107.320521+13.88192
