N370-06M
N370-06M
    TRIPPLITE
    DUPLEXSINGLEMODE8.3/125FIBER
N370-06M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Duplex Singlemode 9/125 Fiber Patch Cable (LC/LC), 6 m (20 ft.) MODEL NUMBER: N370-06M Highlights ● Attenuation loss meets or exceeds latest industry standards ● 9/125 duplex (zipcord) fiber made from glass ● LC male connectors meet insertion loss standards ● FDDI- and OFNR-rated ● Beveled edge on glass ends for easy plug insertion System Requirements ● Fiber optic hardware or NIC card requiring singlemode duplex cable with LC/LC connectors Package Includes ● Premium singlemode fiber optic cabling transmits fast, clear data signals through your LAN with data transfer speeds up to 10 Gbps. Description The N370-06M Duplex Singlemode 9/125 Fiber Patch Cable transmits fast, clear data signals through your LAN with data transfer speeds up to 10 Gbps. Designed for network equipment that requires singlemode fiber optic patch cables, this six-meter (20-foot) cable has attenuation loss that meets or exceeds current standards. The FDDI-rated N370-06M has 9/125 duplex (zipcord) fiber made from glass, instead of polymer. The sturdy LC male connectors meet stringent insertion loss standards and feature beveled edges on their glass ends for easy insertion into a patch panel or switch. The OFNR-rated PVC jacket is yellow to easily identify it as a singlemode cable. Features Fast, Clear Data Transmission Through Your LAN ● Data transfer speeds up to 10 Gbps ● Ideal for network equipment that requires singlemode fiber optic patch cables ● Attenuation loss meets or exceeds latest industry standards Superior Construction for Error-Free Signal Transfer ● 9/125 duplex (zipcord) fiber made from glass ● Sturdy LC male connectors meet stringent insertion loss standards ● Beveled edge on glass ends for easy plug insertion ● Yellow-colored for identification as singlemode Specifications OVERVIEW UPC Code 037332195760 1/3 N370-06M Duplex Singlemode 9/125 Fiber Patch Cable, 6 m 1000 Eaton Boulevard Cleveland, OH 44122 United States Technology Singlemode Optical Mode OS2 PHYSICAL Cable Jacket Color Yellow Connector Color Blue; White Cable Jacket Material LSZH Cable Jacket Rating OFNR Clad Diameter (microns) 125 Core Diameter (microns) 9 Number of Fibers 2 Cable Length (ft.) 19.7 Cable Length (m) 6.01 Cable Length (in.) 236.2 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.12 Shipping Weight (kg) 0.05 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit); 10 Gbps; 25 Gbps; 40 Gbps; 100 Gbps; 400 Gbps Attenuation @ 1310NM 0.36dB/Km Attenuation @ 1550NM 0.22dB/Km Insertion Loss 0.30dB CONNECTIONS Side A - Connector 1 LC DUPLEX (MALE) Side B - Connector 1 LC DUPLEX (MALE) Endface Polish UPC 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N370-06M 价格&库存
很抱歉,暂时无法提供与“N370-06M”相匹配的价格&库存,您可以联系我们找货
N370-06M
  • 1+261.110081+33.77858
