N370-08M
N370-08M
    TRIPPLITE
    N370-08M
N370-08M 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Duplex Singlemode 9/125 Fiber Patch Cable (LC/LC), 8 m (26 ft.) MODEL NUMBER: N370-08M Highlights ● Attenuation loss meets or exceeds latest industry standards ● 9/125 duplex (zipcord) fiber made from glass ● LC male connectors meet insertion loss standards ● FDDI- and OFNR-rated ● Beveled edge on glass ends for easy plug insertion System Requirements ● Fiber optic hardware or NIC card requiring singlemode duplex cable with LC/LC connectors Package Includes ● Premium singlemode fiber optic cabling transmits fast, clear data signals through your LAN with data transfer speeds up to 10 Gbps. Features Fast, Clear Data Transmission Through Your LAN ● Data transfer speeds up to 10 Gbps ● Ideal for network equipment that requires singlemode fiber optic patch cables ● Attenuation loss meets or exceeds latest industry standards Superior Construction for Error-Free Signal Transfer ● 9/125 duplex (zipcord) fiber made from glass ● Sturdy LC male connectors meet stringent insertion loss standards ● Beveled edge on glass ends for easy plug insertion ● Yellow-colored for identification as singlemode Specifications OVERVIEW UPC Code 037332195005 Technology Singlemode Optical Mode OS2 PHYSICAL Cable Jacket Color Yellow Connector Color Blue; White 1/3 N370-08M Duplex Singlemode 9/125 Fiber Patch Cable, 8 m 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Jacket Material LSZH Cable Jacket Rating OFNR Clad Diameter (microns) 125 Core Diameter (microns) 9 Number of Fibers 2 Cable Length (ft.) 26.2 Cable Length (m) 7.99 Cable Length (in.) 315 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.15 Shipping Weight (kg) 0.07 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit); 10 Gbps; 25 Gbps; 40 Gbps; 100 Gbps; 400 Gbps Attenuation @ 1310NM 0.36dB/Km Attenuation @ 1550NM 0.22dB/Km Insertion Loss 0.30dB CONNECTIONS Side A - Connector 1 LC DUPLEX (MALE) Side B - Connector 1 LC DUPLEX (MALE) Endface Polish UPC FEATURES & SPECIFICATIONS Push/Pull Tabs No Breakout No Trunk No STANDARDS & COMPLIANCE 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N370-08M 价格&库存
很抱歉,暂时无法提供与“N370-08M”相匹配的价格&库存,您可以联系我们找货
