1000 Eaton Boulevard
Cleveland, OH 44122
United States
Duplex Singlemode 9/125 Fiber Patch Cable
(LC/LC), 50 m (164 ft.)
MODEL NUMBER: N370-50M
Highlights
Attenuation loss meets or
exceeds latest industry
standards
9/125 duplex (zipcord) fiber
made from glass
LC male connectors meet
insertion loss standards
FDDI- and OFNR-rated
Beveled edge on glass ends for
easy plug insertion
System Requirements
Fiber optic hardware or NIC
card requiring singlemode
duplex cable with LC/LC
connectors
Package Includes
Premium singlemode fiber optic cabling transmits fast, clear data signals through your LAN with data
transfer speeds up to 10 Gbps.
Features
Fast, Clear Data Transmission Through Your LAN
● Data transfer speeds up to 10 Gbps
Ideal for network equipment that requires singlemode fiber optic patch cables
Attenuation loss meets or exceeds latest industry standards
Superior Construction for Error-Free Signal Transfer
● 9/125 duplex (zipcord) fiber made from glass
Sturdy LC male connectors meet stringent insertion loss standards
Beveled edge on glass ends for easy plug insertion
Yellow-colored for identification as singlemode
Specifications
OVERVIEW
UPC Code
037332140395
Technology
Singlemode
Optical Mode
OS2
PHYSICAL
Cable Jacket Color
Yellow
Connector Color
Blue; White
1/3
N370-50M Duplex Singlemode
9/125 Fiber Patch Cable, 50 m
Cleveland, OH 44122
United States
Cable Jacket Material
LSZH
Cable Jacket Rating
OFNR
Clad Diameter (microns)
125
Core Diameter (microns)
9
Number of Fibers
2
Cable Length (ft.)
164
Cable Length (m)
50.00
Cable Length (in.)
1968.5
Minimum Bend Radius
20MM (Dynamic); 10MM (Static)
Shipping Dimensions (hwd / in.)
9.00 x 7.00 x 0.50
Shipping Dimensions (hwd / cm)
22.86 x 17.78 x 1.27
Shipping Weight (lbs.)
0.84
Shipping Weight (kg)
0.38
ENVIRONMENTAL
Operating Temperature Range
-4 to 140 °F (-20 to 60 °C)
Storage Temperature Range
Operating Humidity Range
5% to 85% RH, Non-Condensing
Storage Humidity Range
35% to 65% RH, Non-Condensing
COMMUNICATIONS
Network Compatibility
1 Gbps (Gigabit); 10 Gbps; 25 Gbps; 40 Gbps; 100 Gbps; 400 Gbps
Attenuation @ 1310NM
0.36dB/Km
Attenuation @ 1550NM
0.22dB/Km
Insertion Loss
0.30dB
CONNECTIONS
Side A - Connector 1
LC DUPLEX (MALE)
Side B - Connector 1
LC DUPLEX (MALE)
Endface Polish
UPC
FEATURES & SPECIFICATIONS
Push/Pull Tabs
No
Breakout
No
Trunk
No
STANDARDS & COMPLIANCE
2/3
Cleveland, OH 44122
United States
Product Compliance
RoHS; REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N370-50M”相匹配的价格&库存,您可以联系我们找货
