N370-03M-T
N370-03M-T
    TRIPPLITE
    DUPLEXSINGLEMODE8.3/125FIBER
N370-03M-T 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Duplex Singlemode 9/125 Fiber Patch Cable (LC/LC), Push/Pull Tabs, 3 m (10 ft.) MODEL NUMBER: N370-03M-T Highlights ● Attenuation loss meets or exceeds latest industry standards ● 9/125 duplex (zipcord) fiber made from glass ● LC male connectors meet insertion loss standards ● FDDI- and OFNR-rated ● Push/pull tab connectors install/remove with one hand System Requirements ● Fiber optic hardware or NIC card requiring singlemode duplex cable with LC/LC connectors Package Includes ● Premium singlemode fiber optic cabling transmits fast, clear data signals through your LAN with data transfer speeds up to 10 Gbps. Features Fast, Clear Data Transmission Through Your LAN ● Data transfer speeds up to 10 Gbps ● Ideal for network equipment that requires singlemode fiber optic patch cables ● Attenuation loss meets or exceeds latest industry standards LC Connectors with Push/Pull Tabs ● Push/pull tab connectors easy to install and remove with one hand ● Sturdy dual LC connectors tested to meet stringent insertion loss standards Superior Construction for Error-Free Signal Transfer ● 9/125 duplex (zipcord) fiber made from glass ● Beveled edge on glass ends for easy plug insertion ● Yellow-colored for identification as singlemode ● FDDI- and OFNR-rated Specifications OVERVIEW UPC Code 037332202772 Technology Singlemode Optical Mode OS2 1/3 N370-03M-T Duplex Singlemode 9/125 Fiber Patch Cable, Push/Pull Tabs, 3 m 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Cable Jacket Color Yellow Connector Color Blue; White Cable Jacket Material LSZH Cable Jacket Rating OFNR Clad Diameter (microns) 125 Core Diameter (microns) 9 Number of Fibers 2 Cable Length (ft.) 9.8 Cable Length (m) 2.99 Cable Length (in.) 118.1 Minimum Bend Radius 20MM (Dynamic); 10MM (Static) Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.05 Shipping Weight (kg) 0.02 ENVIRONMENTAL Operating Temperature Range -4 to 140 °F (-20 to 60 °C) Storage Temperature Range -4 to 140 °F (-20 to 60 °C) Operating Humidity Range 5% to 85% RH, Non-Condensing Storage Humidity Range 35% to 65% RH, Non-Condensing COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit); 10 Gbps; 25 Gbps; 40 Gbps; 100 Gbps; 400 Gbps Attenuation @ 1310NM 0.36dB/Km Attenuation @ 1550NM 0.22dB/Km Insertion Loss 0.30dB CONNECTIONS Side A - Connector 1 LC DUPLEX (MALE) Side B - Connector 1 LC DUPLEX (MALE) Endface Polish UPC FEATURES & SPECIFICATIONS Push/Pull Tabs Yes 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Breakout No Trunk No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N370-03M-T 价格&库存
很抱歉,暂时无法提供与“N370-03M-T”相匹配的价格&库存,您可以联系我们找货
N370-03M-T
  • 10+396.7923410+51.35912
