USB 3.0 SuperSpeed Active Extension Repeater
Cable (USB-A M/F), 15M (49.21 ft.)
MODEL NUMBER: U330-15M
Highlights
Daisy-chain 2 cables for max
distance up to 98-ft. (29.87 m)
Supports data transfer rates up
to 5 Gbps
Built-in signal booster for peak
performance
Provides up to 388mA of power
to connected device
Backward compatible with
previous USB generations
System Requirements
Connects to any computer, device and/or cable with USB-A connectors to increase the length of a device
cable with no decrease in signal or performance. Extends beyond the 10 ft. limit of conventional USB 3.0
cables.
Description
Tripp Lite's U330-15M USB 3.0 SuperSpeed Active Extension Repeater Cable (M/F) increases the length
of a device cable up to 49-ft. (14.93 m) with no worry of signal loss. By daisy-chaining two cables, you can
extend the length between USB devices up to 98-ft. (29.87 m). Connect the male plug to a USB port on
your computer or hub and the female end to a USB device cable. A built-in bus-powered signal booster
ensures peak performance. Backward compatible with previous USB generations, this cable supports
data transfer rates up to 5 Gbps.
The U330-15M works with all computers, devices and cables with USB-A connectors, and provides up to
388mA of power to a connected device (a 5V, 2A external power supply is required for power applications
stronger than 388mA). Premium foil and braid shielding delivers top-of-the-line signal quality and
protection from EMI/RFI interference. Nickel-plated USB connectors with gold-plated copper contacts
ensure excellent conductivity. Integral strain relief ensures the cable and connectors last a long time.
Features
Extends Connections Between 2 USB-A Devices and/or Cables
● Increases length of device cable up to 49-ft. (14.93 m)
Daisy-chain 2 cables for maximum distance up to 98-ft. (29.87 m)
Supports data transfer rates up to 5 Gbps
Built-in bus-powered signal booster for peak performance
Provides up to 388mA of power to connected device
Premium Construction for Superior Signal Transfer
● Premium foil and braid shielding protects against EMI/RFI
Nickel-plated connectors with gold-plated copper contacts ensure excellent conductivity
Works with all computers, devices and cables with USB-A connectors
5V, 2A external power supply required for power applications stronger than 388mA
1/2
USB 3.0 computer port and USB
3.0 device required to meet USB
3.0 speeds
5V, 2A power supply with 3.5 x
1.35 mm DC jack required for
power applications above
388mA. Output plug requires
positive tip and negative sleeve.
Package Includes
U330-15M USB 3.0
Repeater Cable (M/F), 15 m
Specifications
OVERVIEW
UPC Code
037332199706
PHYSICAL
Color
Black
Cable Jacket Color
Black
Cable Length (ft.)
49.2
Cable Length (m)
15.00
Shipping Dimensions (hwd / cm)
43.18 x 36.32 x 1.27
Shipping Dimensions (hwd / in.)
17.00 x 14.30 x 0.50
Shipping Weight (kg)
1.04
Shipping Weight (lbs.)
2.30
CONNECTIONS
Side A - Connector 1
USB 3.0 A (MALE)
Side B - Connector 1
USB 3.0 A (FEMALE)
STANDARDS & COMPLIANCE
Product Compliance
RoHS
WARRANTY
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“U330-15M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1192.820421+154.51197
