N201-SR1-BL
N201-SR1-BL
    TRIPPLITE
    N201-SR1-BL
N201-SR1-BL 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Right-Angle Cat6 Gigabit Snagless Molded Slim UTP Ethernet Cable (RJ45 M/M), Blue, 1 ft. (0.31 m) MODEL NUMBER: N201-SR1-BL Highlights ● Over 35% slimmer than standard Cat6 cables ● Rated for Cat6 Gigabit/1 Gbps communications ● Right-angle RJ45 male connectors ● Easy to route through cable management panels ● High-quality 28 AWG stranded copper wire Package Includes ● Connects network components like printers, computers, copiers, routers, servers, modems and switches. Ideal for high-density data centers. Slim design increases airflow in tight spaces. Description The N201-SR1-BL Cat6 Gigabit Molded Slim UTP Patch Cable is perfect for connecting network components like printers, computers, copiers, routers, servers, modems and switches in high-density data centers. Designed for fast transmission and excellent signal quality, this 1-ft. (0.31 m) blue cable ensures peak performance throughout your local area network (LAN). Manufactured from 28 AWG copper wire, the four-pair stranded UTP N201-SR1-BL delivers speeds up to Cat6 Gigabit/1 Gbps. Protected by a PVC jacket, this cable is more than 35% smaller in diameter than standard Cat6 cable, which increases airflow in tight spaces and makes it easier to install around corners and through cable management panels. Space-saving right-angle RJ45 male connectors are easy to plug into patch panels and switches located in adjoining spaces inside a rack. Integral strain relief ensures the cable and connectors last a long time. Features Perfect Solution for Your Networking NeedsIdeal for connecting components like printers, computers, copiers, routers, servers, modems and switches in high-density data centersDesigned for fast transmission and excellent signal qualityEnsures peak performance throughout your LANDelivers speeds up to Cat6 Gigabit/1 Gbps No-Snag Right-Angle RJ45 ConnectorsMale connectors plug easily into patch panels and switches in adjoining rack spacesMolded boots protect locking tabs from damage during installation Special Slim DesignMore than 35% smaller in diameter than standard Cat6 cableIncreases airflow in tight spacesIncreased flexibility for installing around corners and through cable management panels Premium Construction for Superior PerformanceMade from 28 AWG copper wirePVC 4-pair stranded UTPIntegral strain relief for long life Specifications 1/3 N201-SR1-BL Cat6 Gigabit Molded Slim UTP Patch Cable (M/M), 1-ft. (0.31 m) 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332193650 Technology Cat6 PHYSICAL Cable Jacket Color Blue Cable Jacket Material PVC Cable Jacket Rating CM Cable Shielding UTP Cable Outer Diameter (OD) 4.0 mm Number of Conductors 4 Pair Conductor Material Stranded Copper Conductor Gauge 28 AWG Cable Length (ft.) 1 Cable Length (m) 0.30 Cable Length (in.) 12 Cable Length (cm) 30.5 Shipping Dimensions (hwd / in.) 7.00 x 9.00 x 0.50 Shipping Dimensions (hwd / cm) 17.78 x 22.86 x 1.27 Shipping Weight (lbs.) 0.04 Shipping Weight (kg) 0.02 ENVIRONMENTAL Operating Temperature Range 14 to 140 F (-10 to 60 C) Storage Temperature Range -4 to 158 F (-20 to 70 C) Relative Humidity 10% ~ 90%, NON-CONDENSING Operating Humidity Range 10% to 90% RH, Non-Condesing Storage Humidity Range 10% to 90% RH, Non-Condesing COMMUNICATIONS Bandwidth per TIA Standard 250 MHz Maximum Bandwidth as Tested 500 MHz Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3an CONNECTIONS 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Side A - Connector 1 RJ45 (MALE) Side B - Connector 1 RJ45 (MALE) Crossover Wiring No Contact Plating Gold Connector Type Snagless; Molded Wiring Configuration EIA/TIA 568B Angled Connector No FEATURES & SPECIFICATIONS IP68 Rated No Snagless Connector Yes Antibacterial No STANDARDS & COMPLIANCE Product Certifications UL Listed; cUL Listed Product Compliance CE (Europe); RoHS; IEEE 802.3an 10GBase-T; REACH; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N201-SR1-BL 价格&库存
很抱歉,暂时无法提供与“N201-SR1-BL”相匹配的价格&库存,您可以联系我们找货
