N001-014-OR
N001-014-OR
    TRIPPLITE
    N001-014-OR
N001-014-OR 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat5e 350 MHz Snagless Molded (UTP) Ethernet Cable (RJ45 M/M), PoE - Orange, 14 ft. (4.27 m) MODEL NUMBER: N001-014-OR Highlights ● Premium cabling for Cat5/5e applications ● Rated for 350 MHz/1 Gbps communications ● Snagless RJ45 male connectors ● 26 AWG 4-pair stranded UTP with PVC jacket ● Color-coded orange for easy identification System Requirements ● For 1000Base-T (1Gbps Ethernet), 10/100Base-T (Ethernet), 100 Mbps TPDDI, 155 Mbps ATM, ISDN, voice and Token Ring Type3 applications. Package Includes ● Color-coded Cat5e cable connects high-speed network components like computers, servers, printers, copiers, routers and switches in a home or office Cat5/5e application. Ideal for high-density data centers. Description The N001-014-OR Cat5e 350 MHz Snagless Molded UTP Patch Cable (M/M) is recommended for connecting high-speed network components, such as computers, servers, printers, copiers, routers and switches, in high-density data centers. Designed for fast transmission and excellent signal quality, this 14ft. (4.27 m) orange cable ensures peak performance throughout your Cat5/5e network. Manufactured from 26 AWG copper wire that cuts down on interference, the four-pair stranded UTP N001014-OR delivers speeds up to 350 MHz/1 Gbps. Near-end crosstalk levels are kept to a minimum. The RJ45 male connectors' snagless design protects the locking tabs from being damaged or broken off during installation. Integral strain relief with ridges on each end gives the cable extra flexibility, reduces stress, and helps the cable and connectors move freely without cracking. Wrapped in a durable PVC jacket that resists corrosion, the N001-014-OR is designed for 1000Base-T (1 Gbps Ethernet), 10/100Base-T (Ethernet), 100 Mbps TPDDI, 155 Mbps ATM, ISDN, voice and Token Ring Type 3 applications. It meets most current industry standards, including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568, ISO/IEC 11801 and ETL (Cat5e draft 11). Features An Ideal Solution for High-Speed Cat5/5e Networking ● Connects high-speed network components, such as computers, servers, printers, copiers, routers and switches ● Designed for 1000Base-T, 10/100Base-T, 100 Mbps TPDDI, 155 Mbps ATM, ISDN, voice and Token Ring Type 3 applications ● Provides high-speed connections up to 350 MHz/1 Gbps ● Flawless signal delivery with minimal near-end crosstalk levels Snagless RJ45 Male Connectors ● Molded snagless boots prevent locking tabs from damage during installation ● Connectors and cable color-coded orange for easy ID in crowded applications Premium Construction Ensures Excellent Performance ● Manufactured from 26 AWG 4-pair stranded UTP 1/3 N001-014-OR Cat5e 350 MHz Snagless Molded UTP Patch Cable (RJ45 M/M), Orange, 14ft. (4.27 m) 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Gold-plated copper contacts for accurate signal transfer ● Molded integral strain relief for long life ● Durable corrosion-resistant PVC jacket ● Meets most current industry standards, including IEEE 802.3ab, IEEE 802.5, ANSI/EIA/TIA 568, ISO/IEC 11801 and ETL (Cat5e draft 11) Specifications OVERVIEW UPC Code 037332202628 Technology Cat5/5e POWER Power Over Cable (PoC) Support No PHYSICAL Cable Jacket Color Orange Cable Jacket Material PVC Cable Jacket Rating CM Cable Shielding UTP Cable Outer Diameter (OD) 5.0 mm Number of Conductors 4 Pair Conductor Material Stranded Copper Conductor Gauge 26 AWG Cable Length (ft.) 14 Cable Length (m) 4.27 Cable Length (in.) 168 Cable Length (cm) 426.7 Shipping Dimensions (hwd / in.) 0.50 x 7.00 x 9.00 Shipping Dimensions (hwd / cm) 1.27 x 17.78 x 22.86 Shipping Weight (lbs.) 0.40 Shipping Weight (kg) 0.18 ENVIRONMENTAL Operating Temperature Range 14 to 104 F (-10 to 40 C) Storage Temperature Range 5 to 122 F (-15 to 50 C) Operating Humidity Range 0% to 90% RH, Non-Condensing 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Storage Humidity Range 0% to 90% RH, Non-Condensing COMMUNICATIONS Bandwidth per TIA Standard 100 MHz Maximum Bandwidth as Tested 350 MHz Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3ab; 802.3at CONNECTIONS Side A - Connector 1 RJ45 (MALE) Side B - Connector 1 RJ45 (MALE) Crossover Wiring No Contact Plating Gold PoE Type Type 2 PoE+ (30W, IEEE 802.3at) Connector Type Molded; Snagless Wiring Configuration EIA/TIA 568B Angled Connector No FEATURES & SPECIFICATIONS IP68 Rated No Snagless Connector No Antibacterial No IP20 Rated No STANDARDS & COMPLIANCE Product Certifications UL Listed; cUL Listed Product Compliance CE (Europe); RoHS; IEEE 802.3ab 1000Base-T; IEEE 802.3at PoE+; REACH; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N001-014-OR 价格&库存
很抱歉,暂时无法提供与“N001-014-OR”相匹配的价格&库存,您可以联系我们找货
