1000 Eaton Boulevard
Cleveland, OH 44122
United States
MTP/MPO Multimode Base-8 Trunk Cable, 24Strand, 40GB/100GB, 40/100GBASE-SR4, OM4
Plenum-Rated (3xF/3xF), Push/Pull Tab, Magenta,
30 m (98 ft.)
MODEL NUMBER: N858-30M-3X8-MG
Highlights
Push/pull tab connectors
install/remove with one hand
8-fiber MTP/MPO connectors
with 12x density of SC
connectors
100% tested for low insertion
loss and back reflection
50/125 OM4-rated multimode
fiber
Magenta color for easy OM4
identification
Package Includes
Premium multimode fiber optic cabling for transmitting 40/100 Gb data and voice signals. Designed for
high-density connections between network equipment in telecom rooms and data centers.
Features
OM4-Rated for 40/100 Gb Ethernet Applications
● Designed to extend high-density connections between network equipment in telecom rooms and data
centers
Recommended for patching between data center MDFs and IDFs
Optimized for QSFP+ 40GBASE-SR4 and QSFP28 100GBASE-SR4 networks
Magenta-colored for identification as an OM4 cable
MTP/MPO Connectors with Push/Pull Tabs
● 8-fiber female connectors 12 times denser than SC connectors
Push/pull tab connectors easy to install and remove with one hand
100% tested for low insertion loss and back reflection
Error-Free Signal Transfer
● 50/125 duplex glass fiber construction
Plenum-rated jacket and bend-insensitive fiber perfect for ceilings, walls and ducts
Specifications
OVERVIEW
UPC Code
037332200204
1/3
N858-30M-3X8-MG MTP/MPO
Magenta, 30 m
Cleveland, OH 44122
United States
Technology
Multimode
Optical Mode
OM4
PHYSICAL
Cable Jacket Color
Magenta
Connector Color
Magenta; Black
Cable Jacket Material
PVC
Cable Jacket Rating
OFNP
Clad Diameter (microns)
125
Core Diameter (microns)
50
Number of Fibers
24
Cable Length (ft.)
98.4
Cable Length (m)
30.00
Cable Length (in.)
1181.1
Minimum Bend Radius
20MM (Dynamic); 10MM (Static)
Shipping Dimensions (hwd / in.)
3.74 x 8.27 x 8.27
Shipping Dimensions (hwd / cm)
9.50 x 21.01 x 21.01
Shipping Weight (lbs.)
2.82
Shipping Weight (kg)
1.28
ENVIRONMENTAL
Operating Temperature Range
-4 to 140 °F (-20 to 60 °C)
Storage Temperature Range
Operating Humidity Range
5% to 85% RH, Non-Condensing
Storage Humidity Range
35% to 65% RH, Non-Condensing
COMMUNICATIONS
Network Compatibility
40 Gbps; 100 Gbps; 400 Gbps
Attenuation @ 850NM
3.0dB/Km
Insertion Loss
0.35dB
CONNECTIONS
Side A - Connector 1
(3) 8-STRAND MTP/MPO (FEMALE)
Side B - Connector 1
Endface Polish
PC
FEATURES & SPECIFICATIONS
2/3
Cleveland, OH 44122
United States
Push/Pull Tabs
Yes
Breakout
Yes
Trunk
Yes
STANDARDS & COMPLIANCE
Product Compliance
RoHS; REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N858-30M-3X8-MG”相匹配的价格&库存,您可以联系我们找货
