315KCFNC356
315KCFNC356
    ALPHAWIRE(阿尔法电线)
    7/8INMINIFEMALEFRONTREC
315KCFNC356 数据手册
Customer Specification PART NO: KCF Series Mini 7/8” Female ½ NPT Mount Receptacle Issue: 1 Issue Date: 8/8/2016 Effective Date: 8/8/2016 Drawing Technical Data Mechanical Receptacle Style Receptacle Threads Housing Insert Contact Mounting Orientation Panel Nut O-Ring Electrical Contact Resistance Nom. Current @ 40°C Rated Voltage UL File Lead Wires AWG Insulation Color Code Outside Diameter Lead Length UL Style CSA Style Environmental Degree of Protection Mini, Female Internal Aluminum, Leads Epoxy Potted Polyurethane Copper Alloy, Gold Plated 1/2” 14-NPT Zinc Plated Steel FKM ≤ 5 mΩ 8A 600 V E485156 16 AWG (26/30) Tinned Copper PVC US 0.121” Nominal See Ordering Information AWM 1015 & 1230 and MTW TEW IP 68/ NEMA 6P ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 1 Customer Specification PART NO: KCF Series Mini 7/8” Female ½ NPT Mount Receptacle Operating Temperature Range CE Issue: 1 issue Date: 8/4/2016 Effective Date: 8/4/2016 REACH Regulation (EC 1907/2006) Ordering Information 315KCF NC356 315KCF NC402 315KCF NC405 317KCF NC356 317KCF NC402 317KCF NC405 319KCF NC356 319KCF NC402 319KCF NC405 -40C (-40F)/ +90C (+194F) All materials used in the manufacture of this part meet the requirements of European Directive 2011/65/EU regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. Exemption used; 6a. This product does not contain Substances of Very High Concern (SVHC) listed on the European Union’s REACH candidate list in excess of 0.1% mass of the item. Description 3 Pin, 1 Meter 3 Pin, 0.3 Meter 3 Pin, 2 Meter 4 Pin, 1 Meter 4 Pin, 0.3 Meter 4 Pin, 2 Meter 5 Pin, 1 Meter 5 Pin, 0.3 Meter 5 Pin, 2 Meter Quantity Each Each Each Each Each Each Each Each Each Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specification herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Alpha has been advised of the possibility of such damages, whether in an action under contact, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specification described herein. ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 2
315KCFNC356 价格&库存
很抱歉,暂时无法提供与“315KCFNC356”相匹配的价格&库存,您可以联系我们找货
