DR04DR118TL357
DR04DR118TL357
    ALPHAWIRE(阿尔法电线)
    M12MSTR/M12MSTR04POLE
DR04DR118TL357 数据手册
Customer Specification PART NO: DR04DR118 M12 Male to M12 Male Drawings Issue: 1 Issue Date: 7/29/2016 Effective Date: 7/29/2016 Technical Data Cordage Construction Cordage Part Number Component a) Conductor b) Insulation Insulation Colors c) Pair d) Cabling Twists e) Inner Jacket Color Shield a) Foil Direction b) Braid Jacket a) Color(s) Cord Configuration End 1 End 2 Insert Molded Body Contact Coupling Nut Available Lengths Diameters (In) 118 2 PAIR 24 (7/32) AWG Tinned Copper 0.010” Wall, Nom. Polyolefin White/Orange - Orange, White/Green Green 2/Cond Cabled Together, Staggered Lays 2 Pairs Cabled 5.3 Twists/foot (min) 0.025" Wall, Nom.,TPE White Alum/Mylar Tape, 25% Overlap, Min. Foil Facing Out Tinned Copper,85% Coverage, Min. 0.032” Wall, Nom. TPE TEAL 0.023 0.043 0.201 0.293 M12 Male M12 Male Black TPU Black TPU Copper Alloy, gold plated Copper Alloy, nickel plated 0.6, 1, 3, 5, 10, 15, 20 Meters ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 1 Customer Specification PART NO: DR04DR118 M12 Male to M12 Male Applicable SpecificationsCable UL CSA International Applicable SpecificationsCord Set Ingress Protection Environmental Compliance CE REACH Regulation (EC 1907/2006) Physical & Electrical Properties Temperature Range Bend Radius Voltage Rating Current Rating Ordering Information DR04DR118 TL355 DR04DR118 TL356 DR04DR118 TL357 DR04DR118 TL358 DR04DR118 TL359 DR04DR118 TL400 DR04DR118 TL401 Standard Package CMR AWM/STYLE 20626 CMG FT4 75°C 80°C / 600 V RMS 75°C IP68 All materials used in the manufacture of this part meet the requirements of European Directive 2011/65/EU regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. Exemption used; 6a. This product does not contain Substances of Very High Concern (SVHC) listed on the European Union’s REACH candidate list in excess of 0.1% mass of the item. -40 to 75°C(operating), -25 to 75°C (installation) 10X Cable Diameter (2 million cycles), 20X Cable Diameter (10 million cycles) 250V 1.6 Amps 0.6 Meters 1.0 Meters 3.0 Meters 5.0 Meters 10.0 Meters 15.0 Meters 20.0 Meters Each Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specification herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Alpha has been advised of the possibility of such damages, whether in an action under contact, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specification described herein. ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 2
DR04DR118TL357 价格&库存
很抱歉,暂时无法提供与“DR04DR118TL357”相匹配的价格&库存,您可以联系我们找货
