UT06V1208P03FT00
UT06V1208P03FT00
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    S/EASSMBLY8POS16AWG3'
UT06V1208P03FT00 数据手册
CABLE ASSEMBLY Overmoulded Cable Assembly Selector Guide Cable Assembly | SOURIAU Services An availability around the world Reliable solutions - Global manufacturing locations - Vast network of authorised distribution partners. - Certification for all major high speed protocols: CAT 5, 5E, RS-485 Electrical control of each harness Test capabilities: vibration, temperature, flexing and sealing Wires encapsulated within the potting: sealing is maintened if the cable sheath is breached. Your Custom Interconnect Capabilities Custom Overmould Optical Cable Assembly Overmould on Two Cables Overmould on Curly Cable PCB Connection Y or T Shape Connection Cable Assembly | Features & Benefits READY TO INSTALL Full Interconnect Solution SOURIAU overmould harness is composed of connectors, overmould (straight or right angle) and cable according to your requirements (length, environmental constraints) for an easy and secured installation. IP68/69K Mated and Unmated WATER PROOF LONG LIFE DURATION Water and dust protection, secure for outdoor and indoor applications. UV Resistant No mechanical deterioration or important variation of colour after 5 years of exposure in natural environment (equivalence exposure to sun and moisture as per ISO4892). Halogen Free HUMAN FRIENDLY Non-hazardous to members of the public in case of fire. Shielding SIGNAL INTEGRITY Can be used when signals have to be transmitted in EMC area. Cable Assembly | Description Robust Metal & Shielding Overmould (UTO Series) 3 standard layouts: 4 pos, 8 pos, 12 pos. Other layouts on request, please consult us. Connector • Metal connector with Nickel plating • Rapid 1/3 turn connection Cable • • • • TPE outer sheath (black color) 300V Flammability rating UL 94V0 Sec.1080 (VW-1) Resistant to a wide range of chemical fluids MIL DTL 26482 Overmould (851 Series) 4 standard layouts: 4 pos, 6 pos, 10 pos, 19 pos. Other layouts on request, please consult us. Connector • Metal connector • Rapid 1/3 turn connection • Conforms to the international standard MIL-DTL-26482G series 1 Cable • • • • Connector UTO 851 Plating Salt spray Black anodized 96 H Nickel 48 H Black Zinc nickel or Cadmium or Black anodized 500 H Nickel With appropriate cable and overmould 48 H TPE outer sheath (black color) 300V Flammability rating UL 1581 Sec.1080 (VW-1) Resistant to a wide range of chemical fluids Temperature Sealing Mechanical Shielding -40° C up to + 105° C IP68/69K mated 500 matings/ unmatings 65 dB -55° C up to + 125° C IP68 500 matings/ unmatings IP68 500 matings/ unmatings -55° C up to + 125° C 70 dB UL/IEC Power Supply Overmould (UTL Series) 1 standard layout: 4 pos. Connector • Plastic connector • Push pull locking mechanism Cable • • • • • H07RN-F: 750V Outer sheath: rubber compound EM2 Colour outer sheath (black color) Core section: 2.5mm² Flame retardant in acc. to IEC 60332-1-2 resp. VDE 0482 part 332-1-2 • Resistant to Oil, Solvents, Water, Ozone, aging and abrasion Waterproof IP67/IP68/IP69K Overmould (UTS Series) 3 standard layouts: 4 pos, 8 pos, 12 pos. Other layouts on request, please consult us. Connector • Plastic connector • Rapid 1/3 turn Cable • • • • • • PVC outer sheath (grey color) 1.5 mm2 conductor 300V Flammability rating IEC (UL1581 Sec.1160) High flexibility Small cable diameter Connector Plating Salt spray Temperature Sealing Mechanical UTL No plating ≥1000 H -40° C up to + 105° C IP68/69K mated 500 matings/unmatings UTS No plating 500 H -40° C up to + 105° C IP68/69K mated 500 matings/unmatings With appropriate cable and overmould Cable Assembly | Applications Recommended Applications Renewable Energy Connector Cable UTS Low Smoke Halogen Free UTL UTS UTL PVC Outer Sheath UTO UTO 851 PUR or TPE Outer Sheath UTS UTL UTS UTS UTO 851 Shielding HII HHI III HII HHI III HII HHH III HII HHH III HII HHH HHH HHH HHI HHH HHH HHI HHH HHH HHI III HHH HHI III HII HHI III HII HHI III HII HHH III HII HHH III HHH HHH III HHH HHH III HHH HHH III HHH HHH III H07RN8F UTL UTL Flexing H07RNF UTL UTS UV resistant Curly Structure Pur Sheath Road Infrastructure 3 3 Portable Energy Civil Marine Power Generation / Energy Factory Automation & Control Off-Road Instrumentation / Measurement Telecom / Datacom Infrastructure Stage Light & Sound Why use this configuration? 3 3 Can be used in public facilities The best proposal for indoor applications Proven all-weather harnesses resistant against a variety of chemical fluids Heavy-duty and very well known cable for usage both in and outdoor applications The right choice for immerged applications Perfect solution for telescopic applications www.souriau-industrial.com contactindustry@souriau.com Our contribution to environmental protection: This catalog is printed on PEFC certified paper Advancement of sustainable wood cultivation. www.pefc.org All information in this document presents only general particulars and shall not form part of any contract. All rights reserved to SOURIAU for changes without prior notification or public announcement. Any duplication is prohibited, unless approved in writing. Photos: Fotolia.com, SOURIAU CPHARNESSEUUSEN01 © Copyright SOURIAU Dec 2013 - SOURIAU is a registered trademark Your local contact
UT06V1208P03FT00
1. 物料型号:文档中提到了几种电缆组件型号,如UTO系列、851系列、UTL系列和UTS系列。 2. 器件简介:SOURIAU提供的电缆组件包括全球制造地点和广泛的授权分销商网络,提供可靠的解决方案,包括所有主要高速协议的认证、电气控制、测试能力以及在电缆护套受损时仍能保持密封的封装电线。 3. 引脚分配:提供了几种标准布局,包括4位、6位、8位、12位和19位,其他布局可以根据要求定制。 4. 参数特性:包括连接器的金属或塑料材质、快速1/3转连接机制、TPE或PVC外护套、耐化学性、阻燃等级、温度范围、密封等级(IP68/69K)、耐盐雾、机械寿命等。 5. 功能详解:电缆组件具有防水、耐紫外线、长寿命、环保(无卤素)、屏蔽信号完整性等特点。 6. 应用信息:推荐的应用包括公共设施、越野、轻便照明等,根据电缆的UV抗性、柔韧性、屏蔽和推荐应用提供了配置建议。 7. 封装信息:详细介绍了不同系列的电缆组件的封装特性,如防水等级、连接器的镀层、耐盐雾性能、工作温度范围、密封性能和机械性能。
UT06V1208P03FT00 价格&库存
很抱歉,暂时无法提供与“UT06V1208P03FT00”相匹配的价格&库存,您可以联系我们找货
