LR05KW115YL355
LR05KW115YL355
    ALPHAWIRE(阿尔法电线)
    MINIMSTRTOMINIF90DEG16AWG0
LR05KW115YL355 数据手册
Customer Specification PART NO: LR05KW115 Mini Male 7/8” to Mini Female 90 Degree Drawings End 1 Issue: 1 Issue Date: 8/1/2016 Effective Date: 8/1/2016 End 2 Technical Data Cordage Construction Cordage Part Number Component 1 a) Conductor b) Insulation Insulation Colors Jacket a) Color(s) Cord Configuration End 1 End 2 Insert Mold Color Contact Diameters (In) 115 5 COND 16 (65/34) AWG Bare Copper 0.016" Wall, Nom. PVC/ 0.005" Wall Nylon White, Red, Green/Yellow, Orange, Black 0.050” Wall, Nom. TPE YELLOW 0.059 0.101 0.380 Mini Male 7/8” Mini Female 7/8” 90 Degree Yellow TPU Yellow TPU Copper Alloy, Gold over Silver plated ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 1 Customer Specification PART NO: LR05KW115 Mini Male 7/8” to Mini Female 90 Degree Coupling Nut Available Lengths Applicable SpecificationsCable UL CSA International Applicable SpecificationsCord Set UL CSA Ingress Protection Environmental Compliance CE REACH Regulation (EC 1907/2006) Physical & Mechanical Properties Temperature Range, Cord Bend Radius Pull Tension Current Rating Ordering Information LR05KW115 YL355 LR05KW115 YL356 LR05KW115 YL357 LR05KW115 YL358 LR05KW115 YL359 LR05KW115 YL400 LR05KW115 YL401 Standard Package Aluminum, anodized black 0.6, 1, 3, 5, 10, 15, 20 Meters TC-ER SUN RES OIL RES I/II AWM/STYLE 20327 C(UL) CIC Control/TC FT4 90°C Dry/75°C Wet 600 V RMS 90°C Dry/75°C Wet 600 V RMS ANSI/UL 2238, Cable Assembly Extension RU, UL File Number E485156 CSA-C22.2 No. 182.3, Special Use Attachment Plugs, Receptacles and Connectors cRU, UL File Number E485156 IP67 All materials used in the manufacture of this part meet the requirements of European Directive 2011/65/EU regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. Exemption used; 6a. This product does not contain Substances of Very High Concern (SVHC) listed on the European Union’s REACH candidate list in excess of 0.1% mass of the item. -30 to 90°C(static), -15 to 90°C (dynamic) 7X Cable Diameter (static), 10X Cable Diameter (dynamic) 101 Lbs, Maximum 7.3 Amps @ 50°C 0.6 Meters 1.0 Meters 3.0 Meters 5.0 Meters 10.0 Meters 15.0 Meters 20.0 Meters Each ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 2 Customer Specification PART NO: LR05KW115 Mini Male 7/8” to Mini Female 90 Degree Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specification herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Alpha has been advised of the possibility of such damages, whether in an action under contact, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specification described herein. ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 3
LR05KW115YL355
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款红外遥控接收器。
2. 器件简介:EL817是一款红外遥控接收器,用于接收红外信号并将其转换为电信号。
3. 引脚分配:EL817共有3个引脚,分别为VCC、GND和OUT。
4. 参数特性:工作电压范围为2.5V-5.5V,工作电流为1.5mA,接收频率为38kHz。
5. 功能详解:EL817可以接收红外信号并将其转换为电信号输出,用于遥控设备。
6. 应用信息:EL817广泛应用于电视、空调等红外遥控设备。
7. 封装信息:EL817采用SOP-8封装。
LR05KW115YL355 价格&库存
很抱歉,暂时无法提供与“LR05KW115YL355”相匹配的价格&库存,您可以联系我们找货
