P004-003-AGN
P004-003-AGN
    TRIPPLITE
    STANDARDCOMPUTERPOWEREXTENSIO
P004-003-AGN 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States PDU Power Cord, C13 to C14 - 10A, 250V, 18 AWG, 3 ft. (0.91 m), Green MODEL NUMBER: P004-003-AGN Highlights ● Recommended for powering computers, printers and other essential peripherals ● Adds 3-ft. (0.91 m) to your existing connection to provide more flexibility in placing devices ● C13-to-C14 PDU-style extension cord is ideal replacement for worn-out or missing cable ● Color-coded green for fast, easy identification in a crowded rack or workstation Applications ● Connect devices like computers, servers and monitors to a PDU up to 3 ft. away in your data center ● Extend an existing power connection up to 3 ft. to more easily place a device or reach a power source near your workstation ● Provide a high-quality replacement for a worn-out or missing power cord Computer power extension cord connects 2 devices with C13/C14 power connectors or extends your existing power connection by 3 ft. Features C14-to-C13 Power Cable Connects Computers, Printers, Servers and Other EquipmentThis IEC320-C14 to IEC-320-C13 cable is designed for small data center or office workstation applications that do not require a heavy-gauge connection. This C14 male to C13 female cord can be used to power a computer, server or monitor; attach a server or drive to a UPS system or PDU; or extend an existing connection up to three feet. The three-foot length helps reduce cable clutter and minimize the risk of tripping. Color-Coded to Avoid Misidentification That Can Cause Costly DowntimeThis computer power extension cord features a green SJT jacket and fully molded green ends. The color-coding allows easy, fast identification in a crowded rack or workstation and helps prevent the cable from becoming inadvertently disconnected. Specifications OVERVIEW UPC Code 037332198846 Device Compatibility Computer; Monitor/HDTV; Printer; Server; UPS; PDU Country/Region Global INPUT Maximum Input Amps 10 Voltage Compatibility (VAC) 100-250 PHYSICAL 1/3 Package Includes ● P004-003-AGN C14 Male to C13 Female Power Cable, 3 ft., Green 1000 Eaton Boulevard Cleveland, OH 44122 United States Plug Color Green Cable Jacket Color Green Cable Jacket Material PVC Cable Jacket Rating FT2 Power Cord Jacket Type SJT Cable Outer Diameter (OD) 7.7mm Number of Conductors 3 Wire Gauge (AWG) 18 Wire Gauge (OD - mm²) 0.82 Cable Length (ft.) 3 Cable Length (m) 0.91 Cable Length (cm) 91.44 Shipping Dimensions (hwd / in.) 0.50 x 5.70 x 8.80 Shipping Dimensions (hwd / cm) 1.27 x 14.48 x 22.35 Shipping Weight (lbs.) 0.60 Shipping Weight (kg) 0.27 ENVIRONMENTAL Operating Temperature Range -4 TO 140 F (- 20° TO 60°C) Storage Temperature Range -4 TO 140 F (- 20° TO 60°C) Operating Humidity Range 20-80% RH Storage Humidity Range 20-80% RH CONNECTIONS Side A - Connector 1 IEC-320-C14 Side B - Connector 1 IEC-320-C13 FEATURES & SPECIFICATIONS High Voltage Yes Locking Plug No Antibacterial No Angled Plug No Coiled Power Cord No STANDARDS & COMPLIANCE Product Certifications CSA (Canada); cUL Listed; UL Listed Product Compliance RoHS; REACH 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P004-003-AGN 价格&库存
很抱歉,暂时无法提供与“P004-003-AGN”相匹配的价格&库存,您可以联系我们找货
