P006-015-HG13CL
P006-015-HG13CL
    TRIPPLITE
    HOSPITAL-GRADECOMPUTERPOWERCO
P006-015-HG13CL 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Hospital-Grade Power Cord, NEMA 5-15P to C13 Green Dot, 13A, 125V, 16 AWG, 15 ft. (4.57 m), Clear Plugs Highlights ● Fully molded clear plugs allow visual inspection of internal construction to ensure safety ● Recommended for connecting devices to power outlets outside patient-care vicinities ● 15-ft. (4.57 m) length allows great flexibility in placing devices in relationship to AC outlet ● Hospital-grade power cord replaces or upgrades power cord provided by manufacturer ● NEMA 5-15P-HG plug connects to AC power; C13 plug connects to device's C14 inlet MODEL NUMBER: P006-015-HG13CL Applications Connects your PC, mobile cart or other hospital equipment with a C14 inlet to a grounded hospital-grade AC outlet. ● Connect devices like PCs, mobile carts, monitors and printers to a power outlet up to 15-ft. (4.57 m) away in a hospital environment outside patient-care vicinities ● Extend an existing power connection up to 15-ft. (4.57 m) to more easily place a device or reach a power source ● Update or replace the standard power cord provided by a device's original manufacturer Features Hospital-Grade Power Cable is a Safe Solution for Medical FacilitiesThis hospital-grade IEC power cord is designed for computers, mobile carts, printers, scanners, monitors and other compatible hospital equipment with a three-pin C14 inlet. It features a C13 end for connecting to a device and a NEMA 5-15PHG plug for connecting to a hospital-grade AC power source located outside patient-care vicinities. The 15-ft. (4.57 m) length allows you great flexibility in placing equipment with respect to the power outlet. Package Includes ● Designed and Tested to Strict Hospital-Grade StandardsBoth fully molded ends are clear, so you can inspect their internal connections at a glance. This hospital-grade power cord is tested to ANSI/UL 62 and 817 standards, as well as CAN/CSA C22.2 no. 21 and 49 standards, ensuring it's a dependable power solution for hospital environments. Specifications OVERVIEW UPC Code 037332193308 Device Compatibility Mobile Cart; Computer; Printer; Monitor/HDTV; Server; UPS; PDU Country/Region North America INPUT Maximum Input Amps 13 Voltage Compatibility (VAC) 125 1/3 P006-015-HG13CL HospitalGrade Power Cord, NEMA 515P to C13, 15-ft. (4.57 m), Clear Plugs 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Plug Color Clear Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating FT2 Power Cord Jacket Type SJT Cable Outer Diameter (OD) 9mm Number of Conductors 3 Wire Gauge (AWG) 16 Wire Gauge (OD - mm²) 1.31 Cable Length (ft.) 15 Cable Length (m) 4.57 Shipping Dimensions (hwd / in.) 10.60 x 14.90 x 0.50 Shipping Dimensions (hwd / cm) 26.92 x 37.85 x 1.27 Shipping Weight (lbs.) 1.19 Shipping Weight (kg) 0.54 ENVIRONMENTAL Operating Temperature Range -4 TO 140 F (- 20° TO 60°C) Storage Temperature Range -4 TO 140 F (- 20° TO 60°C) Operating Humidity Range 20-80% RH Storage Humidity Range 20-80% RH CONNECTIONS Side A - Connector 1 NEMA 5-15P-HG Side B - Connector 1 IEC-320-C13 FEATURES & SPECIFICATIONS High Voltage No Locking Plug No Antibacterial No Angled Plug No Coiled Power Cord No STANDARDS & COMPLIANCE Product Certifications cUL Listed; UL Listed 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P006-015-HG13CL 价格&库存
很抱歉,暂时无法提供与“P006-015-HG13CL”相匹配的价格&库存,您可以联系我们找货
