P019-008-C15RA
P019-008-C15RA
    TRIPPLITE
    HEAVY-DUTYPOWERCORD,15A,14A
P019-008-C15RA 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Power Cord, NEMA 5-15P to Right-Angle C15 Heavy-Duty, 15A, 125V, 14 AWG, 8 ft. (2.43 m), Black Highlights ● Right-angle C15 plug allows easier connection in confined or hard-to-reach spaces ● Recommended for powering PoE switches with high-wattage power supplies ● 8-ft. (2.43 m) length allows flexibility in placing devices in relationship to AC outlet ● NEMA 5-15P to C15 cable replaces or upgrades original manufacturer's power cord ● Thick 14 AWG wire gauge manages high power levels required for larger equipment MODEL NUMBER: P019-008-C15RA Applications ● Connect devices like highwattage PoE switches to a PDU up to 8-ft. (2.43 m) away in your data center ● Extend an existing power connection up to 8-ft. (2.43 m) to more easily place a device or reach a power source ● Update or replace the standard power cord provided by a device's original manufacturer ● Power a device located in a hard-to-access area behind a desk or flush against a wall C15 right-angle power cable connects a PoE network switch or other device with a C16 power inlet in tight spaces or awkward angles. Features IEC C15 Power Cord for Network Devices That Require a Heavy-Gauge ConnectionThis IEC C15 power cable features 14 AWG wire suitable for high power connections, making it reliable for large server applications that require a higher-rated, heavier-gauge cable. The C15 connector is designed for highertemperature devices, such as electric kettles, PoE (Power over Ethernet) switches with high-wattage power supplies, and similar network components. This cord can also replace or upgrade the standard power cord provided by the device's manufacturer. The 8-ft. (2.43 m) length allows you flexibility in placing equipment with respect to the power outlet. Right-Angle C15 Plug Makes Connecting in Tight Spaces EasierThe C15 right-angle power cable is easier to install in confined spaces, such as the back of a rack enclosure cabinet. When plugged in, the right-angled C15 plug guides the cable parallel to your peripheral, allowing you to push the device up against a wall or hide it behind a desk to maximize space. Specifications OVERVIEW UPC Code 037332202413 Device Compatibility Computer; Server; Network Switch; UPS; PDU Country/Region North America INPUT Maximum Input Amps 15 Voltage Compatibility (VAC) 125 1/3 Package Includes ● P019-008-C15RA 5-15P to Right-Angle C15 Power Cord, 8ft. (2.43 m), Black 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Plug Color Black Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Power Cord Jacket Type SJT Cable Outer Diameter (OD) 9.20mm Number of Conductors 3 Wire Gauge (AWG) 14 Wire Gauge (OD - mm²) 2.08 Cable Length (ft.) 8 Cable Length (m) 2.44 Shipping Dimensions (hwd / in.) 0.50 x 11.80 x 14.00 Shipping Dimensions (hwd / cm) 1.27 x 29.97 x 35.56 Shipping Weight (lbs.) 1.00 Shipping Weight (kg) 0.45 ENVIRONMENTAL Operating Temperature Range -4 F TO 140 F (-20 C TO 60 C) Storage Temperature Range -4 F TO 140 F (-20 C TO 60 C) Operating Humidity Range 10 TO 65% RH Storage Humidity Range 10 TO 65% RH CONNECTIONS Side A - Connector 1 NEMA 5-15P Side B - Connector 1 IEC-320-C15 – RIGHT ANGLE FEATURES & SPECIFICATIONS High Voltage No Locking Plug No Antibacterial No Angled Plug Yes Coiled Power Cord No STANDARDS & COMPLIANCE Product Certifications cUL Listed; UL Listed 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P019-008-C15RA 价格&库存
很抱歉,暂时无法提供与“P019-008-C15RA”相匹配的价格&库存,您可以联系我们找货
