1000 Eaton Boulevard
Cleveland, OH 44122
United States
Hospital-Grade Power Cord, NEMA 5-15P to C13 Green Dot, 15A, 125V, 14 AWG, 25 ft. (7.62 m),
Black
Highlights
Recommended for connecting
devices to power outlets outside
patient-care vicinities
25-ft. (7.62 m) length allows
great flexibility in placing
devices in relationship to AC
outlet
Medical power cord replaces or
upgrades power cord provided
by manufacturer
Thick 14 AWG wire gauge
manages high power levels
required for larger equipment
NEMA 5-15P-HG plug connects
to AC power; C13 plug connects
to device's C14 inlet
MODEL NUMBER: P006-025-HG15
Applications
Hospital-grade power cord connects a computer, monitor or other peripheral to a hospital-grade AC outlet
in a medical facility.
Connect devices like PCs,
mobile carts, monitors and
printers to a power outlet up to
25-ft. (7.62 m) away in a
hospital environment outside
Extend an existing power
connection up to 25-ft. (7.62 m)
to more easily place a device or
reach a power source
Update or replace the standard
power cord provided by a
device's original manufacturer
Features
Hospital-Grade Power Cable is a Safe Solution for Medical FacilitiesThis hospital-grade IEC power
cord features 14 AWG wire suitable for high power connections, making it a reliable solution for devices
that require a higher-rated, heavier-gauge cable. The C13 end connects to a computer, mobile cart,
printer, scanner, monitor or other compatible hospital component with a three-pin C14 inlet. The NEMA 515P-HG green-dot plug connects to a hospital-grade AC power source located outside patient-care
vicinities. The 25-ft. (7.62 m) length allows you great flexibility in placing equipment with respect to the
power outlet.
Designed and Tested to Strict Hospital-Grade StandardsThis hospital-grade power cord is tested to
ANSI/UL 62 and 817 standards, as well as CAN/CSA C22.2 no. 21 and 49 standards, ensuring it's a
dependable power solution for hospital environments.
Specifications
OVERVIEW
UPC Code
037332193315
Device Compatibility
Mobile Cart; Computer; Printer; Monitor/HDTV; Server; UPS; PDU
Country/Region
North America
INPUT
Maximum Input Amps
15
Voltage Compatibility (VAC)
125
1/3
Package Includes
P006-025-HG15 NEMA 5-15P
to C13 Computer Power Cable,
25-ft. (7.62 m), Black
Cleveland, OH 44122
United States
PHYSICAL
Plug Color
Black
Cable Jacket Color
Black
Cable Jacket Material
PVC
Cable Jacket Rating
FT2
Power Cord Jacket Type
SJT
Cable Outer Diameter (OD)
9.2mm
Number of Conductors
3
Wire Gauge (AWG)
14
Wire Gauge (OD - mm²)
2.08
Cable Length (ft.)
25
Cable Length (m)
7.62
Shipping Dimensions (hwd / in.)
14.17 x 11.80 x 0.50
Shipping Dimensions (hwd / cm)
35.99 x 29.97 x 1.27
Shipping Weight (lbs.)
2.40
Shipping Weight (kg)
1.09
ENVIRONMENTAL
Operating Temperature Range
-4 TO 140 F (- 20° TO 60°C)
Storage Temperature Range
Operating Humidity Range
20-80% RH
Storage Humidity Range
20-80% RH
CONNECTIONS
Side A - Connector 1
NEMA 5-15P-HG
Side B - Connector 1
IEC-320-C13
FEATURES & SPECIFICATIONS
High Voltage
Yes
Locking Plug
No
Antibacterial
No
Angled Plug
No
Coiled Power Cord
No
STANDARDS & COMPLIANCE
Product Certifications
cUL Listed; UL Listed
2/3
Cleveland, OH 44122
United States
Product Compliance
RoHS
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“P006-025-HG15”相匹配的价格&库存,您可以联系我们找货
