1000 Eaton Boulevard
Cleveland, OH 44122
United States
Power Cord C14 to C15 - Heavy-Duty, 15A, 250V,
14 AWG, 2 ft. (0.61 m), Orange
MODEL NUMBER: P018-002-AOR
Highlights
Recommended for powering
PoE switches with high-wattage
power supplies
2-ft. (0.61 m) length allows
flexibility in placing devices,
while avoiding cable clutter
C14 to C15 power cable
replaces or upgrades original
manufacturer's power cord
Color-coded orange for fast,
easy identification in a crowded
rack or workstation
Thick 14 AWG wire gauge
manages high power levels
required for larger equipment
Applications
Heavy-duty C14 to C15 power cord connects a PoE network switch or other device with a C16 power inlet
to a PDU or UPS system.
Features
C15 to C14 Power Cord for Network Devices That Require a Heavy-Gauge ConnectionThis 250V
C15 to C14 cable features 14 AWG wire suitable for high power connections, making it reliable for large
server applications that require a higher-rated, heavier-gauge cable. The C15 connector is designed for
higher-temperature devices, such as electric kettles, PoE (Power over Ethernet) switches with highwattage power supplies, and similar network components. This IEC C14 to IEC C15 cord can also replace
or upgrade the standard power cord provided by the device's manufacturer. The 2-ft. (0.61 m) length helps
reduce cable clutter and minimize the risk of tripping.
Color-Coded to Avoid Misidentification That Can Cause Costly DowntimeThis C15 to C14 power
cable features an orange SJT jacket and fully molded orange ends. The color-coding allows easy, fast
identification in a crowded rack or workstation and helps prevent the cable from becoming inadvertently
disconnected.
Specifications
OVERVIEW
UPC Code
037332199102
Device Compatibility
Network Switch; UPS; PDU
Country/Region
North America
INPUT
Maximum Input Amps
15
Voltage Compatibility (VAC)
100-250
1/3
Connect devices like highwattage PoE switches to a PDU
up to 2-ft. (0.61 m) away in your
data center
Update or replace the standard
power cord provided by a
device's original manufacturer
Extend an existing power
connection by 2-ft. (0.61 m)
Package Includes
P018-002-AOR IEC C14 to IEC
C15 Power Cable, 2-ft. (0.61 m),
Orange
Cleveland, OH 44122
United States
PHYSICAL
Plug Color
Orange
Cable Jacket Color
Orange
Cable Jacket Material
PVC
Cable Jacket Rating
FT2
Power Cord Jacket Type
SJT
Cable Outer Diameter (OD)
9.2mm
Number of Conductors
3
Wire Gauge (AWG)
14
Wire Gauge (OD - mm²)
2.08
Cable Length (ft.)
2
Cable Length (m)
0.61
Cable Length (cm)
60.96
Shipping Dimensions (hwd / in.)
9.90 x 7.00 x 0.50
Shipping Dimensions (hwd / cm)
25.15 x 17.78 x 1.27
Shipping Weight (lbs.)
0.33
Shipping Weight (kg)
0.15
ENVIRONMENTAL
Operating Temperature Range
-4 TO 140 F (- 20° TO 60°C)
Storage Temperature Range
Operating Humidity Range
20-80% RH
Storage Humidity Range
20-80% RH
CONNECTIONS
Side A - Connector 1
IEC-320-C14
Side B - Connector 1
IEC-320-C15
FEATURES & SPECIFICATIONS
High Voltage
Yes
Locking Plug
No
Antibacterial
No
Angled Plug
No
Coiled Power Cord
No
STANDARDS & COMPLIANCE
2/3
Cleveland, OH 44122
United States
Product Certifications
cUL Listed; UL Listed
Product Compliance
RoHS
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“P018-002-AOR”相匹配的价格&库存,您可以联系我们找货
