LR03KR107YL357
LR03KR107YL357
    ALPHAWIRE(阿尔法电线)
    MINIMSTRTOMINIFSTR18AWG03P
LR03KR107YL357 数据手册
Customer Specification PART NO: LR03KR107 Mini Male 7/8” to Mini Female 7/8” Drawings End 1 Issue: 1 Issue Date: 7/29/2016 Effective Date: 7/29/2016 End 2 Technical Data Cordage Construction Cordage Part Number Component 1 a) Conductor b) Insulation Insulation Colors Jacket a) Color(s) Cord Configuration End 1 End 2 Insert Mold Color Contact Diameters (In) 107 3 COND 18 (41/34) AWG Bare Copper 0.010” Wall, Nom. PVC, Semi Rigid Black, Brown & Blue 0.037” Wall, Nom. TPE YELLOW 0.043 0.063 0.216 Mini Male 7/8”, External Threads Mini Female 7/8” Yellow TPU Yellow TPU Copper Alloy, Gold over Silver plated ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 1 Customer Specification PART NO: LR03KR107 Mini Male 7/8” to Mini Female 7/8” Coupling Nut Available Lengths Applicable SpecificationsCable UL CSA International Applicable SpecificationsCord Set UL CSA Ingress Protection Environmental Compliance CE REACH Regulation (EC 1907/2006) Physical & Mechanical Properties Temperature Range, Cord Bend Radius Pull Tension Current Rating Ordering Information LR03KR107 YL355 LR03KR107 YL356 LR03KR107 YL357 LR03KR107 YL358 LR03KR107 YL359 LR03KR107 YL400 LR03KR107 YL401 Standard Package Aluminum, anodized black 0.6, 1, 3, 5, 10, 15, 20 Meters PLTC AWM/STYLE 20327 C(RU) AWM I/II A/B FT4 ANSI/UL 2238, Cable Assembly Extension RU, UL File Number E485156 CSA-C22.2 No. 182.3, Special Use Attachment Plugs, Receptacles and Connectors cRU, UL File Number E485156 IP67 105°C 105°C / 300 V RMS 105°C / 300 V RMS CSA All materials used in the manufacture of this part meet the requirements of European Directive 2011/65/EU regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. Exemption used; 6a. This product does not contain Substances of Very High Concern (SVHC) listed on the European Union’s REACH candidate list in excess of 0.1% mass of the item. -35 to 90°C(static), -15 to 90°C (dynamic) 7X Cable Diameter (static), 10X Cable Diameter (dynamic) 38 Lbs, Maximum 6.4 Amps @ 50°C 0.6 Meters 1.0 Meters 3.0 Meters 5.0 Meters 10.0 Meters 15.0 Meters 20.0 Meters Each ••••••••••••••••••••••••••••••••••••••• Although Alpha Wire (“Alpha”) makesWire every|reasonable effort to ensure accuracy at time of this publication, information and Alpha 711 Lidgerwood Ave,their Elizabeth, NJthe07207 specifications described herein are subject to error or omission and |to1-800-52 change without notice, and the listing of such information and 2 www.alphawire.com ALPHA specifications does not ensure product availability. Alpha provides the information and specification herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Alpha has been advised of the possibility of such damages,
LR03KR107YL357
物料型号为LR03KR107,是AlphaWire公司生产的一种电缆。
该电缆为Mini Male 7/8英寸至Mini Female 7/8英寸的规格,两端分别为Mini Male和Mini Female,外部螺纹。
导体由18 AWG裸铜制成,绝缘层为0.010英寸壁厚的PVC,半硬质。
绝缘颜色有黑色、棕色和蓝色。
护套为0.037英寸壁厚的TPE,黄色。
引脚分配参数特性包括: - 连接器类型:Mini Male和Mini Female - 导体规格:18 AWG裸铜 - 绝缘材料:PVC - 护套材料:TPE - 颜色:黄色 - 额定温度:静态-35至90°C,动态-15至90°C - 弯曲半径:静态7倍电缆直径,动态10倍电缆直径 - 拉力:最大38磅 - 电流额定值:50°C时6.4安培
功能详解: - 该电缆符合UL PLTC AWM/STYLE 20327标准,105°C/300VRMS。
- CSA International认证,C(RU) AWM I/II A/B FT4,105°C/300VRMS。
- 符合UL ANSI/UL 2238和CSA-C22.2 No. 182.3标准,适用于特殊用途。
应用信息: - 可用于需要IP67防护等级的应用环境。
- 符合CE标准,所有材料均符合2011/65/EU指令,限制在电子电气设备中使用某些有害物质。
封装信息: - 可用长度:0.6米、1米、3米、5米、10米、15米和20米。
- 订购信息示例:LR03KR107 YL355为0.6米,LR03KR107 YL401为20.0米。
Alpha Wire保留随时更改信息和规格的权利,且不保证产品可用性。
LR03KR107YL357 价格&库存
很抱歉,暂时无法提供与“LR03KR107YL357”相匹配的价格&库存,您可以联系我们找货
