LR05KR109YL355
LR05KR109YL355
    ALPHAWIRE(阿尔法电线)
    MINIMSTRTOMINIFSTR18AWG05P
LR05KR109YL355 数据手册
Customer Specification PART NO: LR05KR109 Mini Male 7/8” to Mini Female 7/8” Drawings End 1 Issue: 1 Issue Date: 7/29/2016 Effective Date: 7/29/2016 End 2 Technical Data Cordage Construction Cordage Part Number Component 1 a) Conductor b) Insulation Insulation Colors Jacket a) Color(s) Cord Configuration End 1 End 2 Insert Mold Color Contact Diameters (In) 109 5 COND 18 (41/34) AWG Bare Copper 0.010” Wall, Nom. PVC, Semi Rigid Blue, Black, Green/Yellow, Brown, White 0.037” Wall, Nom. TPE YELLOW 0.043 0.063 0.252 Mini Male 7/8”, External Threads Mini Female 7/8” Yellow TPU Yellow TPU Copper Alloy, Gold over Silver plated ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 1 Customer Specification PART NO: LR05KR109 Mini Male 7/8” to Mini Female 7/8” Coupling Nut Available Lengths Applicable SpecificationsCable UL CSA International Applicable SpecificationsCord Set UL CSA Ingress Protection Environmental Compliance CE REACH Regulation (EC 1907/2006) Physical & Mechanical Properties Temperature Range, Cord Bend Radius Pull Tension Current Rating Ordering Information LR05KR109 YL355 LR05KR109 YL356 LR05KR109 YL357 LR05KR109 YL358 LR05KR109 YL359 LR05KR109 YL400 LR05KR109 YL401 Standard Package Aluminum, anodized black 0.6, 1, 3, 5, 10, 15, 20 Meters PLTC AWM/STYLE 20327 C(RU) AWM I/II A/B FT4 105°C 105°C / 300 V RMS 105°C / 300 V RMS ANSI/UL 2238, Cable Assembly Extension RU, UL File Number E485156 CSA-C22.2 No. 182.3, Special Use Attachment Plugs, Receptacles and Connectors cRU, UL File Number E485156 IP67 All materials used in the manufacture of this part meet the requirements of European Directive 2011/65/EU regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. Exemption used; 6a. This product does not contain Substances of Very High Concern (SVHC) listed on the European Union’s REACH candidate list in excess of 0.1% mass of the item. -35 to 90°C(static), -15 to 90°C (dynamic) 7X Cable Diameter (static), 10X Cable Diameter (dynamic) 64 Lbs, Maximum 5.1 Amps @ 50°C 0.6 Meters 1.0 Meters 3.0 Meters 5.0 Meters 10.0 Meters 15.0 Meters 20.0 Meters Each ••••••••••••••••••••••••••••••••••••••• Although Alpha Wire (“Alpha”) makesWire every|reasonable effort to ensure accuracy at time of this publication, information and Alpha 711 Lidgerwood Ave,their Elizabeth, NJthe07207 specifications described herein are subject to error or omission and |to1-800-52 change without notice, and the listing of such information and 2 www.alphawire.com ALPHA specifications does not ensure product availability. Alpha provides the information and specification herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Alpha has been advised of the possibility of such damages,
LR05KR109YL355 价格&库存
很抱歉,暂时无法提供与“LR05KR109YL355”相匹配的价格&库存,您可以联系我们找货
