U444-003-D
U444-003-D
    TRIPPLITE
    USBCTODVIADAPTERCABLE(M/M)
U444-003-D 数据手册
USB-C to DVI Active Adapter Cable (USB-C to DVI-D Dual Link M/M), 3 ft. (0.9 m) MODEL NUMBER: U444-003-D Highlights ● Supports USB DisplayPort Alternate Mode for transmitting video ● Supports HD video resolutions up to 1920 x 1080 (1080p) @ 60 Hz ● Supports USB 3.1 Gen 1 data transfer rates up to 5 Gbps ● Reversible USB-C plug connects in either direction ● Plug-and-play operation with no software or drivers required ● Note: This cable is unidirectional. Will only work from a USB-C port to DVI port System Requirements Connects your existing DVI monitor or projector to the USB-C or Thunderbolt 3 port on your tablet, laptop, notebook, smartphone or PC. ● Ideal for giving video presentations, editing multiple documents or streaming 1080p video for digital signage ● Supports USB 3.1 Gen 1 data transfer rates up to 5 Gbps Common Applications ● Extends video from your primary display to another Duplicates the same video on 2 displays Converts a secondary display to your primary display Crystal-Clear 1080p Video ● Supports HD video resolutions up to 1920 x 1080 (1080p) @ 60 Hz ● Supports 36-bit Deep Color (12 bits per channel) ● Supports DVI digital transfer rates of 6.75 Gbps (2.25 Gbps per channel) ● Display device with DVI input ● Connects a DVI Display to Your USB-C or Thunderbolt 3 Device ● Compatible with USB-C or Thunderbolt 3 source devices that support USB DisplayPort Alternate Mode ● Source device with USB-C or Thunderbolt 3 port that supports USB DisplayPort Alternate Mode Package Includes Features ● ● Reversible USB-C Connector ● Fumble-free reversible USB-C plug connects in either direction for quick connection every time Premium Construction ● Gold-plated connectors and contacts for maximum conductivity and minimum data loss ● Foil and braid shielding protects against EMI/RFI line noise that can distort or destroy data ● Integral strain relief helps cable and connectors move freely without stress or cracking ● Durable PVC jacket designed to last a long time 1/4 U444-003-D USB 3.1 Gen 1 USB-C to DVI Adapter Cable (M/M), 3 ft. Ready for Instant Use ● Plug-and-play operation with no software, drivers or external power required ● 3 ft. length easy to manage in crowded environments ● Backward compatible with non-1080p displays Specifications OVERVIEW UPC Code 037332202499 Product Type Active Cable Technology DVI VIDEO Max Supported Video Resolution DVI: 1920 x 1080 (1080p) @ 60Hz INPUT Bus Powered Yes Product Length (in.) 36 Product Length (cm.) 91.44 Product Length (ft.) 3 Product Length (m.) 0.91 BATTERY Battery Charging (5V/1.5A Port) No POWER Power Consumption (Watts) 0.50 PHYSICAL Color Black Material of Construction PVC, ABS Cable Jacket Color Black Cable Jacket Rating VW-1 Cable Length (ft.) 3 Cable Length (m) 0.91 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 2/4 Shipping Weight (lbs.) 0.17 Shipping Weight (kg) 0.08 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Dimensions (hwd / cm) 0x0x0 Unit Packaging Type Polybag Unit Weight (lbs.) 0.17 Unit Weight (kg) 0.08 ENVIRONMENTAL Operating Temperature Range 32 to 113 F (0 to 45 C) Storage Temperature Range 14 to 158 F (-10 to 70 C) BTUs 1.7 BTU/Hr Operating Humidity Range 10% to 85% RH, Non-Condensing Storage Humidity Range 5% to 90% RH, Non-Condensing CONNECTIONS Side A - Connector 1 USB C (MALE) Side B - Connector 1 DVI-D SINGLE LINK (MALE) Connector Plating Gold FEATURES & SPECIFICATIONS HDCP Specification 1.3 USB Specification USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps) Driver Required No UASP Support No Auto MDIX Support No Full Duplex Support No Suspend Mode Support No Remote Wakeup Support No IP68 Rated No IP20 Rated No STANDARDS & COMPLIANCE Product Certifications UL Listed Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY 3/4 Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 4/4
U444-003-D 价格&库存
很抱歉,暂时无法提供与“U444-003-D”相匹配的价格&库存,您可以联系我们找货
