USB-C to HDMI Active Adapter Cable (M/M), 4K,
Black, 3 ft. (0.9 m)
MODEL NUMBER: U444-003-H
Highlights
Supports USB DisplayPort
Alternate Mode for transmitting
audio/video
Supports UHD video resolutions
up to 4K x 2K @ 30 Hz
Supports USB 3.1 Gen 1 data
transfer rates up to 5 Gbps
Reversible USB-C plug
connects in either direction
Plug-and-play operation with no
software or drivers required
System Requirements
Source device with USB-C or
Thunderbolt 3 port that supports
USB DisplayPort Alternate
Mode
Display device with HDMI input
Package Includes
Connects your existing HDMI TV, monitor or projector to the USB-C or Thunderbolt 3 port on your tablet,
laptop, notebook, smartphone or PC.
Features
Connects an HDMI Display to Your USB-C or Thunderbolt 3 Device
● Compatible with USB-C or Thunderbolt 3 source devices that support USB DisplayPort Alternate Mode
Ideal for giving video presentations, editing multiple documents or streaming 4K video for digital signage
Supports USB 3.1 Gen 1 data transfer rates up to 5 Gbps
Common Applications
● Extends 4K video from your primary display to another
Duplicates the same video on 2 displays
Converts a secondary display to your primary display
Crystal-Clear 4K Video and Digital Audio
● Supports UHD video resolutions up to 3840 x 2160 (4K x 2K) @ 30 Hz
Supports 36-bit Deep Color (12 bits per channel)
Supports per-lane transfer rates of 5.4 Gbps (HBR2), 2.7 Gbps (HBR) and 1.62 Gbps (RBR)
Reversible USB-C Connector
● Fumble-free reversible USB-C plug connects in either direction for quick connection every time
Premium Construction
● Gold-plated connectors and contacts for maximum conductivity and minimum data loss
Foil and braid shielding protects against EMI/RFI line noise that can distort or destroy data
Integral strain relief helps cable and connectors move freely without stress or cracking
Durable PVC jacket designed to last a long time
1/4
U444-003-H USB 3.1 Gen 1
USB-C to HDMI 4K Adapter
Cable (M/M), 3 ft.
Ready for Instant Use
● Plug-and-play operation with no software, drivers or external power required
3 ft. length easy to manage in crowded environments
Backward compatible with non-4K displays
Specifications
OVERVIEW
UPC Code
037332202475
Product Type
Active Cable
Technology
HDMI
VIDEO
Max Supported Video Resolution
HDMI: 3840 X 2160 (4K X 2K) @ 30HZ
INPUT
Bus Powered
Yes
Product Length (in.)
36
Product Length (cm.)
91.44
Product Length (ft.)
3
Product Length (m.)
0.91
BATTERY
Battery Charging (5V/1.5A Port)
No
POWER
Power Consumption (Watts)
0.6
PHYSICAL
Color
Black
Material of Construction
PVC, ABS
Cable Jacket Color
Black
Cable Jacket Rating
VW-1
Cable Length (ft.)
3
Cable Length (m)
0.91
Shipping Dimensions (hwd / in.)
1.00 x 7.00 x 9.50
Shipping Dimensions (hwd / cm)
2.54 x 17.78 x 24.13
2/4
Shipping Weight (lbs.)
0.19
Shipping Weight (kg)
0.09
Unit Dimensions (hwd / in.)
0.000 x 0.000 x 0.000
Unit Packaging Type
Polybag
Unit Weight (lbs.)
0.15
Unit Weight (kg)
0.07
ENVIRONMENTAL
Operating Temperature Range
32 to 113 F (0 to 45 C)
Storage Temperature Range
14 to 158 F (-10 to 70 C)
BTUs
2.1 BTU/Hr
Operating Humidity Range
10% to 85% RH, Non-Condensing
Storage Humidity Range
5% to 90% RH, Non-Condensing
CONNECTIONS
Side A - Connector 1
USB C (MALE)
Side B - Connector 1
HDMI (MALE)
Connector Plating
Gold
FEATURES & SPECIFICATIONS
HDCP Specification
1.4
USB Specification
USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps)
Driver Required
No
UASP Support
No
Auto MDIX Support
No
Full Duplex Support
No
Suspend Mode Support
No
Remote Wakeup Support
No
IP68 Rated
No
IP20 Rated
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA)
WARRANTY
Product Warranty Period
(Worldwide)
3-year limited warranty
3/4
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
4/4
很抱歉,暂时无法提供与“U444-003-H”相匹配的价格&库存,您可以联系我们找货
