PR03KR113YL400
PR03KR113YL400
    ALPHAWIRE(阿尔法电线)
    MINIMINTTHRTOMINIFSTR16AWG
PR03KR113YL400 数据手册
Customer Specification PART NO: PR03KR113 Mini Male 7/8” Internal Thread to Mini Female Drawings End 1 Issue: 1 Issue Date: 8/1/2016 Effective Date: 8/1/2016 End 2 Technical Data Cordage Construction Cordage Part Number Component 1 a) Conductor b) Insulation Insulation Colors Jacket a) Color(s) Cord Configuration End 1 End 2 Insert Mold Color Contact Coupling Nut Diameters (In) 113 3 COND 16 (65/34) AWG Bare Copper 0.016" Wall, Nom. PVC/ 0.005" Wall Nylon Black, White, Green/Yellow 0.050” Wall, Nom. TPE YELLOW 0.059 0.101 0.324 Mini Male 7/8”, Internal Thread Mini Female 7/8” Yellow TPU Yellow TPU Copper Alloy, Gold over Silver plated Aluminum, anodized black ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 1 Customer Specification PART NO: PR03KR113 Mini Male 7/8” Internal Thread to Mini Female Available Lengths Applicable SpecificationsCable UL CSA International Applicable SpecificationsCord Set UL CSA Ingress Protection Environmental Compliance CE REACH Regulation (EC 1907/2006) Physical & Mechanical Properties Temperature Range, Cord Bend Radius Pull Tension Current Rating Ordering Information PR03KR113 YL355 PR03KR113 YL356 PR03KR113 YL357 PR03KR113 YL358 PR03KR113 YL359 PR03KR113 YL400 PR03KR113 YL401 Standard Package 0.6, 1, 3, 5, 10, 15, 20 Meters TC-ER SUN RES OIL RES I/II AWM/STYLE 20327 C(UL) CIC Control/TC FT4 90°C Dry/75°C Wet 600 V RMS 90°C Dry/75°C Wet 600 V RMS ANSI/UL 2238, Cable Assembly Extension RU, UL File Number E485156 CSA-C22.2 No. 182.3, Special Use Attachment Plugs, Receptacles and Connectors cRU, UL File Number E485156 IP67 All materials used in the manufacture of this part meet the requirements of European Directive 2011/65/EU regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. Exemption used; 6a. This product does not contain Substances of Very High Concern (SVHC) listed on the European Union’s REACH candidate list in excess of 0.1% mass of the item. -30 to 90°C(static), -15 to 90°C (dynamic) 7X Cable Diameter (static), 10X Cable Diameter (dynamic) 61 Lbs, Maximum 9.1 Amps @ 50°C 0.6 Meters 1.0 Meters 3.0 Meters 5.0 Meters 10.0 Meters 15.0 Meters 20.0 Meters Each ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 2 Customer Specification PART NO: PR03KR113 Mini Male 7/8” Internal Thread to Mini Female Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specification herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Alpha has been advised of the possibility of such damages, whether in an action under contact, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specification described herein. ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 3
PR03KR113YL400 价格&库存
很抱歉,暂时无法提供与“PR03KR113YL400”相匹配的价格&库存,您可以联系我们找货
