U344-001-DP-4K
U344-001-DP-4K
    TRIPPLITE
    U344-001-DP-4K
U344-001-DP-4K 数据手册
USB 3.0 SuperSpeed to 4K DisplayPort DualMonitor External Video Graphics Card Adapter, 512 MB SDRAM MODEL NUMBER: U344-001-DP-4K Highlights ● Supports UHD video resolutions up to 3840 x 2160 (4K x 2K) ● Displayport 1.2 ● Data transfer rates up to 5 Gbps ● Connect up to 6 adapters at a time ● Auto-resume from hibernation and suspend modes ● Backward compatible with USB 2.0 System Requirements Connects an Ultra High Definition (UHD) 4K x 2K DisplayPort display to your computer or laptop’s USB 3.0 port, even if the device’s graphics card doesn’t support UHD. Ideal for office workstations and presentations. ● Windows 7 and later (32- and 64-bit), Mac OS X 10.8.5 and later (32- and 64-bit), or Surface tablets running non-RT Windows 8 and later ● USB 2.0 or 3.0 port (USB 3.0 port required for USB 3.0 speeds and 4K resolution) ● DisplayPort monitor Package Includes ● U344-001-DP-4K USB 3.0 SuperSpeed to DisplayPort Dual-Monitor External Video Graphics Card Adapter ● Driver CD ● Owner’s manual Description The U344-001-DP-4K USB 3.0 SuperSpeed to DisplayPort Dual-Monitor External Video Graphics Card Adapter allows you to connect a UHD 4K x 2K DisplayPort monitor, projector or television to your computer or laptop’s USB 3.0 port, even if your device’s graphics card doesn’t support UHD resolutions. Ideal for office workstations and on-the-road presentations where using multiple computers isn’t an option, this cable lets you extend video across the primary display to a second display, clone the same video on both displays, or set the new display as the primary. It resumes automatically from hibernation and suspend modes. You can add as many as six total U344-001-DP-4K adapters at a time. The U344-001-DP-4K supports UHD video resolutions up to 3840 x 2160 (4K x 2K) @ 30 Hz, as well as 5.1 surround sound audio and video streaming up to 1080p. Using the latest USB 3.0 SuperSpeed standard, it shares data at speeds up to 5 Gbps, which is ten times faster than USB 2.0. The bus-powered adapter is ready to use right from the box. Just install the driver using the included CD, and connect the unit to your source’s USB port and your display’s DisplayPort cable. Backward compatible with USB 2.0. Features 512 MB DDR2 SDRAM of memory. Compatible with the latest Windows and Mac operating systems, as well as Surface tablets. Features Add a UHD DisplayPort Display via Your Computer or Laptop’s USB 3.0 Port ● Connects 4K x 2K DisplayPort monitor, projector or TV to computer’s USB 3.0 port, even if source device doesn’t support Ultra High Definition ● Ideal for offices and presentations where using multiple computers isn’t an option ● Extend video across displays, clone video to both displays, or set new display as the primary display ● Auto-resume from hibernation and suspend modes ● Add as many as 6 units to add more DisplayPort displays Enjoy High Video and Audio Standards ● Supports UHD video resolutions up to 3840 x 2160 (4K x 2K) @ 30 Hz ● Supports video streaming up to 1080p 1/3 ● Supports 5.1 surround sound audio ● Displayport 1.2 ● Supports USB 3.0 data transfer rates up to 5 Gbps—10 times faster than USB 2.0 Plug-and-Play Convenience ● Works right from the box with no external power supply needed ● Install driver from included CD ● Backward compatible with USB 2.0 ● Features 512 MB DDR2 SDRAM of memory ● Compatible with Windows 7 and later, Mac OS X 10.8.5 and later, and Surface tablets running non-RT Windows 8 and later Specifications OVERVIEW UPC Code 037332192134 Technology DisplayPort VIDEO Max Supported Video Resolution 3840 x 2160 (4K x 2K) @ 30Hz INPUT Bus Powered Yes PHYSICAL Material of Construction Polycarbonate, ABS Color Black Cable Jacket Rating VW-1 Shipping Dimensions (hwd / cm) 13.79 x 16.51 x 3.99 Shipping Dimensions (hwd / in.) 5.43 x 6.50 x 1.57 Shipping Weight (kg) 0.17 Shipping Weight (lbs.) 0.37 Unit Dimensions (hwd / in.) 0.6 x 3.2 x 1.8 Unit Packaging Type Box Unit Weight (lbs.) 0.10 Unit Weight (kg) 0.05 ENVIRONMENTAL Operating Temperature Range 32° to 104° F (0° to 40° C) 2/3 Storage Temperature Range -4° to 158° F -(20° to 70° C) Relative Humidity 0% to 85 RH, Non-Condensing COMMUNICATIONS EDID Compatible No CONNECTIONS Number of Ports 1 Side A - Connector 1 USB 3.0 A (MALE) Side B - Connector 1 DISPLAYPORT (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS Displayport Specification 1.2 USB Specification USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps) Driver Required Yes STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 3/3
U344-001-DP-4K 价格&库存
很抱歉,暂时无法提供与“U344-001-DP-4K”相匹配的价格&库存,您可以联系我们找货
