EZA-035-P
EZA-035-P
    TRIPPLITE
EZA-035-P 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Easy Pull Long-Run Display Cable - Type-A Analog Plenum Trunk Cable, 35 ft. (10.67 m) MODEL NUMBER: EZA-035-P Highlights ● Versatile trunk cable allows for a variety of connection options ● Plenum-rated jacket to comply with local fire codes ● At a diameter of 7/8 in., it easily pulls through conduit or confined spaces using the included end cap with integrated pull tab ● High quality RGB style VGA cable supports resolutions up to 1600 x 1200, as well as Audio pass through Package Includes ● Features ● Eliminates the need to field terminate VGA connectors ● Plenum-rated jacket to comply with local fire codes ● Detachable, screw-on connectors ● At a diameter of 7/8 in., it makes pulling long cables fast and easy ● Protects entire cable from strain, dirt, debris and damage ● Choose from a variety of connector combinations for the perfect fit ● Available in 35 ft., 50 ft. and 100 ft. lengths, both PVC and plenum rated ● Supports Video and Audio pass through depending on end kit used Specifications OVERVIEW UPC Code 037332141873 Product Type Passive Technology VGA/SVGA PHYSICAL Color Black; Green Cable Jacket Color Black; Green Cable Length (ft.) 35 Cable Length (m) 10.67 1/2 Easy Pull Type-A VGA Analog Plenum Trunk Cable, 35 ft. 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / in.) 1.00 x 8.00 x 8.00 Shipping Dimensions (hwd / cm) 2.54 x 20.32 x 20.32 Shipping Weight (lbs.) 1.90 Shipping Weight (kg) 0.86 CONNECTIONS Side A - Connector 1 DIN 14 PIN (FEMALE) Side B - Connector 1 DIN 14 PIN (FEMALE) Latching or Gripping Connector No FEATURES & SPECIFICATIONS IP68 Rated No WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
EZA-035-P 价格&库存
很抱歉,暂时无法提供与“EZA-035-P”相匹配的价格&库存,您可以联系我们找货
