Customer Specification
PART NO: EW1200126
M23 Female 90 Degree
Drawings
Issue: 1 Issue Date: 7/29/2016 Effective Date: 7/29/2016
Technical Data
Cordage Construction
Cordage Part Number
Component 1
a) Conductor
b) Insulation
Insulation Colors
Component 2
b) Conductor
b) Insulation
Insulation Colors
Jacket
a) Color(s)
Cord Configuration
End 1
End 2
Insert
Mold Color
Contact
Coupling Nut
Available Lengths
Applicable SpecificationsCable
Diameters (In)
256
8 COND
0,50mm² (64 x 0,10mm), Bare Copper (20
AWG)
Polypropylene
White, Green, Yellow, Grey, Grey/Pink,
Red/Blue, White/Green & Brown/Green
3 COND
1,00mm², (128 x 0,10mm), Bare Copper
(18 AWG)
Polypropylene
Blue, Brown & Yellow/Green
0.057” Wall, Nom. PUR, Zero Halogen
Black
0.057
0.077
0.366
Cut End
White PBT
Black TPU
Copper Alloy, Gold plated
Copper Alloy, Nickel plated
0.6, 1, 3, 5, 10, 15, 20 Meters
Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207
www.alphawire.com | 1-800-52 ALPHA
1
PART NO: EW1200126
UL
CSA International
Applicable SpecificationsCord Set
Nominal Voltage
Rated Voltage
Ingress Protection
Environmental Compliance
CE
REACH Regulation (EC
1907/2006)
Physical & Mechanical
Properties
Temperature Range, Cord
Temperature Range,
Connector
Bend Radius
Current Rating
Ordering Information
EW1200126 BK355
EW1200126 BK356
EW1200126 BK357
EW1200126 BK358
EW1200126 BK359
EW1200126 BK400
EW1200126 BK401
Standard Package
AWM/STYLE 20549/21198
C(RU) AWM I/II A/B FT2
80°C / 300 VRMS
80°C / 300 VRMS
240 V
250 V
IP67/NEMA 6P
All materials used in the manufacture of
this part meet the requirements of
European Directive 2011/65/EU regarding
the restriction of use of certain hazardous
substances in electrical and electronic
equipment. Exemption used; 6a.
This product does not contain Substances
of Very High Concern (SVHC) listed on the
European Union’s REACH candidate list in
excess of 0.1% mass of the item.
-50 to 80°C(static), -25 to 80°C (dynamic)
-25°C to +80°C
5X Cable Diameter (static), 10X Cable
Diameter (dynamic)
5.6 Amps @ 50°C (1,00mm² Conductors)
0.6 Meters
1.0 Meters
3.0 Meters
5.0 Meters
10.0 Meters
15.0 Meters
20.0 Meters
Each
Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of this publication, information and
specifications described herein are subject to error or omission and to change without notice, and the listing of such information and
specifications does not ensure product availability. Alpha provides the information and specification herein on an “AS IS” basis, with no
representations or warranties, whether express, statutory or implied. In no event will Alpha be liable any damages (including consequential,
indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Alpha has been advised of the possibility of such damages,
whether in an action under contact, negligence or any other theory, arising out of or in connection with the use, or inability to use, the
information or specification described herein.
2
