P134-06N-MDP
P134-06N-MDP
    TRIPPLITE
    DISPLAYPORTTOMINIDISPLAYPORT
P134-06N-MDP 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States DisplayPort to Mini DisplayPort Adapter Video Converter , 4K 60 Hz (M/F), 6 in. (15.2 cm) MODEL NUMBER: P134-06N-MDP Highlights ● Supports UHD video resolutions up to 3840 x 2160 (4K x 2K) @ 60Hz ● Works with both Single-Mode and Dual-Mode graphics cards ● Gold-plated connectors and contacts ● Integral strain relief ● Plug and play—no software or drivers required System Requirements ● Computer with a DisplayPort or Mini DisplayPort output ● Monitor with a Mini DisplayPort or DisplayPort input Package Includes ● Connects a Mini DisplayPort (mDP) monitor to a computer with a DisplayPort output. Features Sends UHD DisplayPort Audio/Video to a Mini DisplayPort Monitor or an mDP Computer to a DisplayPort Monitor ● Connects a DisplayPort computer to an mDP monitor or a mDP computer to a DisplayPort monitor ● Recommended for displaying DisplayPort video on a large monitor or digital sign ● Allows you to continue using an existing mDP display, instead of buying a new monitor Vibrant, Superior Video Quality ● Supports UHD video resolutions up to 3840 x 2160 (4K x 2K) @ 60 Hz, including 1080p ● 3840 x 2160 (4K x 2K) @ 60 Hz video resolutions supported up to 10 ft. (Including P134 adapter cable) ● 3840 x 2160 (4K x 2K) @ 30 Hz video resolutions supported up to 16 ft. (Including P134 adapter cable) ● Works with both Single-Mode and Dual-Mode (DP++) DisplayPort graphics cards Superior Materials for Superior Performance ● Gold-plated connectors and contacts for excellent conductivity ● Integral strain relief for long life ● Plug and play—no software or drivers require Specifications OVERVIEW UPC Code 037332198624 Technology DisplayPort PHYSICAL 1/2 P134-06N-MDP DisplayPort to Mini DisplayPort Cable Adapter (M/F), 6 in. 1000 Eaton Boulevard Cleveland, OH 44122 United States Color White Cable Length (ft.) 0.05 Cable Length (m) 0.02 Cable Length (in.) 6 Cable Length (cm) 15.24 Shipping Dimensions (hwd / in.) 9.15 x 7.25 x 0.50 Shipping Dimensions (hwd / cm) 23.24 x 18.42 x 1.27 Shipping Weight (lbs.) 0.10 Shipping Weight (kg) 0.05 CONNECTIONS Side A - Connector 1 DISPLAYPORT (MALE) Side B - Connector 1 MINI DISPLAYPORT (FEMALE) STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P134-06N-MDP
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光隔离集成电路。
2. 器件简介:EL817是光隔离集成电路,用于实现电信号的隔离。
3. 引脚分配:EL817有8个引脚,分别为Vcc、Vo、GND、A、B、C、D、E。
4. 参数特性:工作温度范围为-40℃至+85℃,工作电压范围为5V至15V。
5. 功能详解:EL817通过光电耦合实现输入信号的隔离和传输。
6. 应用信息:广泛应用于工业控制、仪器仪表等领域。
7. 封装信息:EL817采用DIP-8封装。
P134-06N-MDP 价格&库存
很抱歉,暂时无法提供与“P134-06N-MDP”相匹配的价格&库存,您可以联系我们找货
P134-06N-MDP
  • 1+65.709591+8.49717
