P569-010-CERT
P569-010-CERT
    TRIPPLITE
    P569-010-CERT
P569-010-CERT 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 4K HDMI Cable with Ethernet (M/M) - 4K 60 Hz, Gripping Connectors, 10 ft. MODEL NUMBER: P569-010-CERT Highlights ● Supports UHD video resolutions up to 4K for crystal-clear video ● Ideal for connecting 4K televisions ● Tested for highest performance and ultra reliability ● Special high-grip plugs prevent accidental disconnections System Requirements ● Video source with HDMI output ● Display with HDMI input Package Includes P569-010-CERT 4K HDMI Cable with Ethernet (M/M), 10 ft. HDMI cable with high-grip connectors transmits digital audio/video and Ethernet signals to a 4K-enabled television, projector or monitor. Ideal for all multimedia applications that display UHD video. Description The P569-010-CERT 4K HDMI Cable with Ethernet (M/M) is recommended for home theater systems and other applications that display Ultra High Definition (UHD) video and multi-channel audio. It connects an HDMI-enabled source device, such as a Blu-ray player, video game system or computer, to a 4K-enabled television, monitor or projector. This 10-foot (3.1-meter) cable supports true 4K video resolutions up to 4096 x 2160 at 60 Hz, as specified in HDMI 2.0. Distinctive high-grip male connectors ensure a secure, tight fit to prevent the cable from coming loose accidentally. The P569-010-CERT also supports data transfer speeds up to 18 Gbps and 3D video and works in all HDMI cabling scenarios. This HDMI cable supports Ethernet data connectivity, which allows web-capable devices to share their internet connection with other connected devices. An audio return channel simplifies setups between displays and A/V receivers. When used with an Apple digital A/V adapter, it supports iPad2 video mirroring for playing games, watching videos or displaying presentations. The 28 AWG cable features premium foil and braid shielding to deliver top-of-the-line signal quality and protection from EMI/RFI interference. Gold-plated connectors and contacts ensure excellent conductivity. Features Connects HDMI Source to 4K TV, Projector or MonitorRecommended for home theater systems, classrooms, conference rooms, data centers, digital signage and other applications that display UHD video and multi-channel audio Ready for True 4K TransmissionSupports Ultra HD video resolutions up to 4K Distinctive High-Grip ConnectorsMale plugs specifically designed for secure, tight fit that prevents accidental disconnection High Performance and Wide CompatibilitySupports 3D video while audio return channel simplifies setup between display and receiverSupports iPad2 video mirroring when used with Apple digital A/V adapterWorks in all HDMI cabling scenarios Superior Construction Ensures a Flawless SignalFully molded 28 AWG construction with integral strain relief for durability and long lifePremium foil and braid shielding for EMI/RFI noise 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States protectionCorrosion-resistant gold-plated connectors and contacts for optimal signal transferFlexible PVC jacket easy to install in tight spaces Specifications OVERVIEW UPC Code 037332199218 Product Type Passive Technology HDMI VIDEO Max Supported Video Resolution 3840 x 2160 @ 60Hz Max Supported Color Depth 48-bit Deep Color HDR Support Yes 3D Video Supported Yes Chroma Sub Sampling 4:4:4 EDID Support Yes Signal Transmission Bidirectional AUDIO Audio Specification ARC USER INTERFACE, ALERTS & CONTROLS LED Indicators 0 PHYSICAL Color Black Material of Construction PVC Cable Jacket Color Black Connector Color Burgundy Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 7.3mm Wire Gauge (AWG) 28 Cable Length (ft.) 10 Cable Length (m) 3.05 Cable Length (in.) 120 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Ferrite Core No Cable Length (cm) 304.80 Minimum Bend Radius 36.5mm Shipping Dimensions (hwd / in.) 7.00 x 9.00 x 0.50 Shipping Dimensions (hwd / cm) 17.78 x 22.86 x 1.27 Shipping Weight (lbs.) 0.50 Shipping Weight (kg) 0.23 ENVIRONMENTAL Operating Temperature Range 14 to 122 F (-10 to 50 C) Storage Temperature Range 5 to 140 F (-15 to 60 C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing COMMUNICATIONS EDID Compatible Yes Consumer Electronics Control (CEC) Supported Yes CONNECTIONS Side A - Connector 1 HDMI (MALE) Side B - Connector 1 HDMI (MALE) Connector Plating Gold Contact Plating Gold Connector Style Straight Latching or Gripping Connector Yes FEATURES & SPECIFICATIONS HDCP Specification 1.4; 2.2 EMI/RFI Line Noise Protection Yes MST Support No IP68 Rated No Antibacterial No Armored Cable No Ethernet Support Yes IP20 Rated No STANDARDS & COMPLIANCE 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
P569-010-CERT 价格&库存
很抱歉,暂时无法提供与“P569-010-CERT”相匹配的价格&库存,您可以联系我们找货
