P569-003-SLIM
P569-003-SLIM
    TRIPPLITE
    P569-003-SLIM
P569-003-SLIM 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Slim High-Speed HDMI Cable with Ethernet and Digital Video with Audio, UHD 4K (M/M), 3 ft. (0.91 m) Highlights ● Supports UHD video resolutions up to 4K ● Easy to install around corners and through management panels ● Premium foil and braid shielding protects against EMI/RFI noise ● Gold-plated connectors and contacts for optimal signal transfer MODEL NUMBER: P569-003-SLIM Package Includes ● Transmits digital audio/video and Ethernet signals from an HDMI source to a 4K-enabled television, projector or monitor. Recommended for home theater systems and digital signage. Slim design increases airflow in tight spaces. Features Connects HDMI Source to 4K TV, Projector or Monitor ● Ideal for home theater systems, digital signage and other applications that display UHD video and multichannel audio High Performance and Wide Compatibility ● Supports UHD video resolutions up to 4K, and 3D ● Audio return channel simplifies setup between display and receiver ● Supports iPad2 video mirroring when used with Apple digital A/V adapter ● Backward compatible with previous HDMI generations ● Works in all HDMI cabling scenarios Special Slim Design ● Improved airflow in tight spaces ● Better flexibility for installing around corners and through cable management panels Superior Construction Ensures a Flawless Signal ● Fully molded 36 AWG construction with integral strain relief for durability and long life ● Premium foil and braid shielding for EMI/RFI noise protection ● Corrosion-resistant gold-plated connectors and contacts for optimal signal transfer ● Flexible PVC jacket easy to install in tight spaces 1/4 P569-003-SLIM Slim HighSpeed HDMI Cable with Ethernet and Digital Video with Audio (M/M), 3 ft. 1000 Eaton Boulevard Cleveland, OH 44122 United States Specifications OVERVIEW UPC Code 037332199355 Product Type Passive Technology HDMI VIDEO Max Supported Video Resolution 3840 x 2160 @ 30Hz Max Supported Color Depth 24-bit True Color HDR Support No 3D Video Supported Yes Chroma Sub Sampling 4:4:4 EDID Support Yes Signal Transmission Bidirectional AUDIO Audio Specification Stereo Audio USER INTERFACE, ALERTS & CONTROLS LED Indicators 0 PHYSICAL Color Black Cable Jacket Color Black Connector Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 3.6mm Wire Gauge (AWG) 34 Cable Length (ft.) 3 Cable Length (m) 0.91 Ferrite Core No Minimum Bend Radius 36mm Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.20 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Weight (kg) 0.09 ENVIRONMENTAL Operating Temperature Range 32 TO 113 F (0 TO 45 C) Storage Temperature Range -40 - 80 °C (-40 - 176 °F) Operating Humidity Range 10 to 85% RH, Non-Condensing Storage Humidity Range 5 to 90% RH, Non-Condensing COMMUNICATIONS Consumer Electronics Control (CEC) Supported Yes CONNECTIONS Side A - Connector 1 HDMI (MALE) Side B - Connector 1 HDMI (MALE) Connector Plating Gold Contact Plating Gold Connector Style Straight Latching or Gripping Connector No FEATURES & SPECIFICATIONS HDCP Specification 1.4 EMI/RFI Line Noise Protection No MST Support No IP68 Rated No Antibacterial No Armored Cable No Ethernet Support Yes IP20 Rated No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
P569-003-SLIM 价格&库存
很抱歉,暂时无法提供与“P569-003-SLIM”相匹配的价格&库存,您可以联系我们找货
