P569-003-CERT
P569-003-CERT
    TRIPPLITE
    P569-003-CERT
P569-003-CERT 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 4K HDMI Cable with Ethernet (M/M) - 4K 60 Hz, Gripping Connectors, 3 ft. MODEL NUMBER: P569-003-CERT Highlights ● Supports UHD resolutions up to 4K for crystal-clear video ● Ideal for connecting 4K televisions ● Tested for highest performance and ultra reliability ● Special high-grip plugs prevent accidental disconnections System Requirements ● Video source with HDMI output ● Display with HDMI input Package Includes ● HDMI-certified cable with high-grip connectors transmits digital audio/video and Ethernet signals to a 4Kenabled television, projector or monitor. Ideal for all multimedia applications that display UHD video. Features Connects HDMI Source to 4K TV, Projector or MonitorRecommended for home theater systems, classrooms, conference rooms, data centers, digital signage and other applications that display UHD video and multi-channel audio Ready for True 4K TransmissionCertified to guarantee UHD video resolutions up to 4K Distinctive High-Grip ConnectorsMale plugs specifically designed for secure, tight fit that prevents accidental disconnection High Performance and Wide CompatibilitySupports 3D video while audio return channel simplifies setup between display and receiverSupports iPad2 video mirroring when used with Apple digital A/V adapterWorks in all HDMI cabling scenarios Superior Construction Ensures a Flawless SignalFully molded 28 AWG construction with integral strain relief for durability and long lifePremium foil and braid shielding for EMI/RFI noise protectionCorrosion-resistant gold-plated connectors and contacts for optimal signal transferFlexible PVC jacket easy to install in tight spaces Specifications OVERVIEW UPC Code 037332198600 Product Type Passive Technology HDMI VIDEO 1/3 P569-003-CERT 4K HDMI Cable with Ethernet (M/M), 3 ft. 1000 Eaton Boulevard Cleveland, OH 44122 United States Max Supported Video Resolution 3840 x 2160 @ 60Hz Max Supported Color Depth 48-bit Deep Color HDR Support Yes 3D Video Supported Yes Chroma Sub Sampling 4:4:4 EDID Support Yes Signal Transmission Bidirectional AUDIO Audio Specification ARC USER INTERFACE, ALERTS & CONTROLS LED Indicators 0 PHYSICAL Color Black Material of Construction PVC Cable Jacket Color Black Connector Color Burgundy Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 7.3mm Wire Gauge (AWG) 28 Cable Length (ft.) 3 Cable Length (m) 0.91 Cable Length (in.) 36 Ferrite Core No Cable Length (cm) 91.44 Minimum Bend Radius 36.5mm Shipping Dimensions (hwd / in.) 0.50 x 9.20 x 6.90 Shipping Dimensions (hwd / cm) 1.27 x 23.37 x 17.53 Shipping Weight (lbs.) 0.10 Shipping Weight (kg) 0.05 ENVIRONMENTAL Operating Temperature Range 14 to 122 F (-10 to 50 C) Storage Temperature Range 5 to 140 F (-15 to 60 C) 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing COMMUNICATIONS EDID Compatible Yes Consumer Electronics Control (CEC) Supported Yes CONNECTIONS Side A - Connector 1 HDMI (MALE) Side B - Connector 1 HDMI (MALE) Connector Plating Gold Contact Plating Gold Connector Style Straight Latching or Gripping Connector Yes FEATURES & SPECIFICATIONS HDCP Specification 1.4; 2.2 EMI/RFI Line Noise Protection Yes MST Support No IP68 Rated No Antibacterial No Armored Cable No Ethernet Support Yes IP20 Rated No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P569-003-CERT 价格&库存
很抱歉,暂时无法提供与“P569-003-CERT”相匹配的价格&库存,您可以联系我们找货
