1000 Eaton Boulevard
Cleveland, OH 44122
United States
DisplayPort Extension Cable with Latch, 4K @ 60
Hz, HDCP 2.2 (M/F), 15 ft. (4.57 m)
MODEL NUMBER: P579-015
Highlights
Supports 4K x 2K video
resolutions @ 60 Hz
Latching DisplayPort plug
ensures secure connection
Molded nickel-plated connectors
with gold-plated contacts
Supports DisplayPort v1.2,
DPCP and HDCP 2.2
Smaller connector footprint than
VGA or DVI
Package Includes
Extends your existing DisplayPort™ connection by 15 ft. Latching male connector prevents accidental
disconnections.
Description
The P579-015 DisplayPort Extension Cable (M/F) attaches to your current DisplayPort cable to extend it
by 15-ft. (4.57 m). To ensure a continuous audio/video signal, the latching male end prevents the cable
from coming loose or getting accidentally disconnected. This 15-ft. (4.57 m) cable supports UHD video
resolutions up to 3840 x 2160 (4K x 2K) at 60 Hz, allowing you to stream digital video and audio from a
DisplayPort computer to a monitor or television with a DisplayPort input.
Premium foil and braid shielding delivers reliable, error-free signal quality and protection from EMI/RFI
interference. Molded nickel-plated connectors with corrosion-resistant gold-plated contacts provide
maximum conductivity and minimize data loss. Integral strain relief with ridges on each end gives the
cable extra flexibility, reduces stress, and helps the cable and connectors move freely without cracking.
Features
Extends an Existing DisplayPort Cable an Extra 15-ft. (4.57 m)
● Female connector attaches to current DisplayPort cable to add length
Supports UHD video resolutions up to 3840 x 2160 (4K x 2K) @ 60 Hz
Supports DisplayPort v1.2, DPCP and HDCP 2.2
Latching Male Connector Ensures Continuous A/V Signal
● Prevents cable from coming loose or getting accidentally disconnected
Easy one-touch release button allows unplugging
First-Rate Construction for Superior Signal Transfer
● Premium foil and braid shielding for EMI/RFI noise protection
Gold-plated contacts for maximum conductivity and minimum data loss
Integral strain relief reduces stress and adds flexibility
Flexible PVC jacket
Smaller connector footprint than VGA or DVI saves space
1/3
Cable with Latch (M/F), 15-ft.
(4.57 m)
Cleveland, OH 44122
United States
Specifications
OVERVIEW
UPC Code
037332202024
Product Type
Passive
Technology
DisplayPort
PHYSICAL
Color
Black
Cable Jacket Color
Black
Cable Length (ft.)
15
Cable Length (m)
4.57
Cable Length (in.)
180
Shipping Dimensions (hwd / in.)
10.00 x 8.00 x 0.50
Shipping Dimensions (hwd / cm)
25.40 x 20.32 x 1.27
Shipping Weight (lbs.)
0.58
Shipping Weight (kg)
0.26
ENVIRONMENTAL
Operating Temperature Range
-4 F TO 140 F (-20 C TO 60 C)
Storage Temperature Range
5 F TO 122 F (-15 C TO 50 C)
Relative Humidity
10% TO 80% RH, NON-CONDENSING
CONNECTIONS
Side A - Connector 1
DISPLAYPORT (MALE)
Side B - Connector 1
DISPLAYPORT (FEMALE)
Latching or Gripping Connector
Yes
FEATURES & SPECIFICATIONS
IP68 Rated
No
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
2/3
Cleveland, OH 44122
United States
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“P579-015”相匹配的价格&库存,您可以联系我们找货
