H3BXG-10110-S4
H3BXG-10110-S4
    HRS(广濑)
    JUMPER-H1505TR/A2015S/X 10"
H3BXG-10110-S4 数据手册
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DF11 Series 2.0mm Pitch, Double-Row Connector (UL/CSA Compliant) Mar. 2021 DF11 Series/2.0mm Pitch, Double-Row Connector (UL/CSA Compliant) Features 1. Space- saving on Board Double row contact arrangement with 2mm pitch has been condensed within a 5mm width. Double the number of signals can be secured in the same space as a conventional 2mm singlerow connector. Rib to Prevent Mis-insertion Friction Lock Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Rib to prevent contact insertion between dissimilar contacts 5mm 2. Wide Varieties There are two types of connection methods : insulation displacement and crimping. Variations are available in cable- to- board, in- line, and board- to- board to expand PCB design freedom. Additionally, both gold and tin plating can be selected based on the application and SMT compatible products are also available. 3. Wide Applicable Wire Range The double 2mm pitch rows are compact while enabling an applicable wire range of 22 to 30 AWG. 4. The IDC Type enables reduced assembly time Since the DF11 insulation displacemention allows double rows IDC with a single part, harnessing can be completed by machine connection alone. Applications Business equipment such as copy machines, printers and so on. 2 4 Wall Box Style DF11 Series/2.0mm Pitch, Double-Row Connector (UL/CSA Compliant) Product Specifications Ratings Crimping Rated Current (Note 1) 22 to 26 AWG 28 AWG 30 AWG 26 AWG 2A 1A 0.5A 1A Rated Voltage Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Insulation Displacement 250V AC Operating Temperature Range -30 to +85℃ (Note 2) Operating Humidity Range 40 to 80% (Note 3) Storage Temperature Range -10 to +60℃ (Note 4) Storage Humidity Range 40 to 70% (Note 4) UL, CSA Safety Standard Approved Specification Wire Size Rated Current ■ UL, CSA Safety Standard File No. 22 AWG 24 to 28 AWG 30 AWG 2A 1A 0.5A Rated Voltage 100V AC   UL : E52653   CSA : LR95109 30V AC Item Specification Condition Insulation Resistance 1000M Ω Min. 500V DC Withstanding Voltage No flashover or insulation breakdown. 650V AC for 1 min. Contact Resistance 30m Ω Max. 100mA Single Insertion/Extraction Force 0.3N (30gf) Min. 4.4N (450gf) Max. Measured by the square steel pin at 0.5 ± 0.002mm Vibration No electrical discontinuity of 1μ s or more Frequency : 10 to 55Hz, single amplitude of 0.75mm, 2 hours in each of the 3 directions. Humidity (Steady State) Contact Resistance : 30m Ω Max. Insulation Resistance : 500M Ω Min. 96 hours at temperature of 40 ± 2℃ and humidity of 90 to 95% Temperature Cycle Contact Resistance : 30m Ω Max. Insulation Resistance : 1000M Ω Min. (-55℃:30 minutes → 5 to 35℃:10 minutes → 85℃:30 minutes → 5 to 35℃:10 minutes) 5 cycles Mating Durability Contact Resistance : 30m Ω Max. Tin Plated : 30 cycles, Gold Plated : 50 cycles Resistance to Soldering Heat Through Hole Flow : 260℃ for 10 seconds Manual soldering : 300℃ for 2 seconds SMT Reflow : At the recommended temperature profile Manual soldering : 300℃ for 3 seconds No deformation of components affecting performance. Note 1 : This is the maximum current rating while all pins are powered or used as all power lines. When isolating power lines into multiple circuits, current ratings may go above the stated current ratings. Please consult Hirose for details before doing this. Current rating of header is 2A. Note 2 : Includes the temperature rise due to current flow. Note 3 : The connector should be completely dry. (no condensation) Note 4 : The term "storage" refers to the long-term storage condition of unused products before PCB mounting. The operating temperature and humidity ranges apply while the connector is in a non-energized state, while in transport or after PCB mounting. 3 DF11 Series/2.0mm Pitch, Double-Row Connector (UL/CSA Compliant) Material / Finish Product Type MateriaI Finish Remarks Crimping Socket Insulator Polyamide Black UL94V-0 Crimping Contact for Socket Contact Phosphor Copper Tin Plated or Gold Plated - Insulator Polyamide Black UL94V-0 Contact Phosphor Copper Tin Plated - Insulator Polyamide Black UL94V-0 Contact Phosphor Copper Tin Plated or Gold Plated - Insulator Polyamide Black UL94V-0 Contact Brass Tin Plated or Gold Plated - Insulator Polyamide Beige UL94V-0 Contact Brass Tin Plated or Gold Plated - Retention Tab Brass Tin Plated - In-line Plug Insulator Polyamide Black UL94V-0 In-line Plug Crimping Contact Contact Phosphor Copper Tin Plated or Gold Plated - Insulator Polyamide Black UL94V-0 Contact Brass Tin Plated - IDC Socket Receptacle Pin Header Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part SMT Header In-line Adaptor 4 DF11 Series/2.0mm Pitch, Double-Row Connector (UL/CSA Compliant) Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ● Connector DF11 - # DS - 2 C Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ❶ ❷ ❸ ❹ ❺ ❶ Series Name DF11 ❷ No. of Pos. 4 to 32 ❸ Connector Type DS : Double Row Socket DP : Double Row Pin Header DEP : Double Row In-line Plug ❹ Contact Pitch 2mm ● ❺ Connection Form/ C : Crimping Socket R26 : IDC Socket for 26 AWG Contact Style DSA : Straight Through Hole DS : Right Angle Through Hole V : Straight SMT A : Adaptor ❹ Plating Type        Contact DF11 - EP 2428 PCF A ❶ ❷ ❸ ❹ ❶ Contact Type EP : For In-line Plug ❷ Applicable Wire Size 22 : 22 AWG 2428 : 24 to 28 AWG 30 : 30 AWG ❸ Contact Type/ Packaging Type SCF : Socket Contact, Embossed Tape SC : Socket Contact, Bag PCF : Plug Contact, Embossed Tape PC : Plug Contact, Bag        5 Blank:Tin Plated A :Gold Plated DF11 Series/2.0mm Pitch, Double-Row Connector (UL/CSA Compliant) IDC Socket No. 2 6.5 3.0 2.0 1.5 P=2.0 A B No. 1 Note 1 Contact No.1 Marking CAV No. Marking 32 Shown Assembled with Cable 1 9.2 A Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. No. of Pos. Indicator Note 2 Note 1 : Port 1-pcs indicates odd numbered rows, and port 2-pcs indicate even numbered rows. Note 2 : Use the following DIP type headers: · Straight angle type : DF11-#DP-2DSA(08) · Angle type : DF11-#DP-2DS(24) Unit : mm Part No. HRS No. No. of Pos. A B DF11-4DS-2R26(05) CL0543-0652-0-05 4 6.0 2.0 DF11-6DS-2R26(05) CL0543-0653-3-05 6 8.0 4.0 DF11-8DS-2R26(05) CL0543-0654-6-05 8 10.0 6.0 DF11-10DS-2R26(05) CL0543-0655-9-05 10 12.0 8.0 DF11-12DS-2R26(05) CL0543-0656-1-05 12 14.0 10.0 DF11-14DS-2R26(05) CL0543-0657-4-05 14 16.0 12.0 DF11-16DS-2R26(05) CL0543-0658-7-05 16 18.0 14.0 DF11-18DS-2R26(05) CL0543-0659-0-05 18 20.0 16.0 DF11-20DS-2R26(05) CL0543-0660-9-05 20 22.0 18.0 DF11-22DS-2R26(05) CL0543-0661-1-05 22 24.0 20.0 DF11-24DS-2R26(05) CL0543-0662-4-05 24 26.0 22.0 DF11-26DS-2R26(05) CL0543-0663-7-05 26 28.0 24.0 DF11-28DS-2R26(05) CL0543-0664-0-05 28 30.0 26.0 DF11-30DS-2R26(05) CL0543-0665-2-05 30 32.0 28.0 DF11-32DS-2R26(05) CL0543-0666-5-05 32 34.0 30.0 Purchase Unit 100pcs per bag [Specific No.] (05) : Tin Plated ■ Applicable Cable Part No. Applicable Cable DF11-#DS-2R26 UL1061 26 AWG (7/0.16mm) Jacket Diameter φ 0.9 to 1.05mm ■ DF11-#DS-2R IDC Machine Type Desktop IDC Machine Part No. Connection Type SA700/DF11 CL0903-0013-5-00 Used for DF11 only, No restricted condition 6 Remarks Desktop machine for small lot DF11 Series/2.0mm Pitch, Double-Row Connector (UL/CSA Compliant) Crimping Socket A B P=2.0 5.0 2.0 No.2 No.1 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 7.3 Shown Assembled with Cable Polarity Mark CAV No. Marking Unit : mm Part No. HRS No. No. of Pos. A B DF11-4DS-2C CL0543-0568-6-00 4 6.0 2.0 DF11-6DS-2C CL0543-0502-8-00 6 8.0 4.0 DF11-8DS-2C CL0543-0503-0-00 8 10.0 6.0 DF11-10DS-2C CL0543-0504-3-00 10 12.0 8.0 DF11-12DS-2C CL0543-0505-6-00 12 14.0 10.0 DF11-14DS-2C CL0543-0506-9-00 14 16.0 12.0 DF11-16DS-2C CL0543-0507-1-00 16 18.0 14.0 DF11-18DS-2C CL0543-0508-4-00 18 20.0 16.0 DF11-20DS-2C CL0543-0509-7-00 20 22.0 18.0 DF11-22DS-2C CL0543-0510-6-00 22 24.0 20.0 DF11-24DS-2C CL0543-0511-9-00 24 26.0 22.0 DF11-26DS-2C CL0543-0512-1-00 26 28.0 24.0 DF11-28DS-2C CL0543-0513-4-00 28 30.0 26.0 DF11-30DS-2C CL0543-0514-7-00 30 32.0 28.0 DF11-32DS-2C CL0543-0515-0-00 32 34.0 30.0 7 Purchase Unit 100pcs per bag DF11 Series/2.0mm Pitch, Double-Row Connector (UL/CSA Compliant) Receptacle (Through Hole) P=2.0 5.0 2.0 No. 2 A B No. 1 Polarity Mark Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3.0 6.2 ● Board Through-hole Diameter : φ0.8+0.1  0 ● Diameter of Board Hole for Kink Pin +0.05 Securing : φ0.8 0 0.6 0.2 Unit : mm Part No. HRS No. No. of Pos. A B DF11-6DS-2DSA(##) CL0543-0553-9-## 6 8.0 4.0 DF11-8DS-2DSA(##) CL0543-0554-1-## 8 10.0 6.0 DF11-10DS-2DSA(##) CL0543-0555-4-## 10 12.0 8.0 DF11-12DS-2DSA(##) CL0543-0556-7-## 12 14.0 10.0 DF11-14DS-2DSA(##) CL0543-0557-0-## 14 16.0 12.0 DF11-16DS-2DSA(##) CL0543-0558-2-## 16 18.0 14.0 DF11-18DS-2DSA(##) CL0543-0559-5-## 18 20.0 16.0 DF11-20DS-2DSA(##) CL0543-0560-4-## 20 22.0 18.0 DF11-22DS-2DSA(##) CL0543-0561-7-## 22 24.0 20.0 DF11-24DS-2DSA(##) CL0543-0562-0-## 24 26.0 22.0 DF11-26DS-2DSA(##) CL0543-0563-2-## 26 28.0 24.0 DF11-28DS-2DSA(##) CL0543-0564-5-## 28 30.0 26.0 DF11-30DS-2DSA(##) CL0543-0565-8-## 30 32.0 28.0 DF11-32DS-2DSA(##) CL0543-0566-0-## 32 34.0 30.0 [Specific No.] -##,(##) (05) : Tin Plated (06) : Gold Plated 8 Purchase Unit 100pcs per bag DF11 Series/2.0mm Pitch, Double-Row Connector (UL/CSA Compliant) Receptacle (SMT) No.2 CAV No. Marking A 0.7 1.5 5.0 2.0 1.5 P=2.0 No.1 B 5.95 4.95 1.5 Polarity Mark ■ PCB Mounting Pattern A±0.1 2.0±0.1 P=2.0±0.05 1.1±0.1 2.8±0.1 5.1±0.1 2.0±0.1 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.5 2.0±0.1 C±0.1 2.0±0.1 Note : If the shaded area has a pattern and is not treated with resist it may touch the connector contact. Unit : mm Part No. HRS No. No. of Pos. A B C DF11CZ-4DS-2V(##) CL0543-2063-0-## 4 2.0 8.5 8.7 DF11CZ-6DS-2V(##) CL0543-2064-3-## 6 4.0 10.5 10.7 DF11CZ-8DS-2V(##) CL0543-2065-6-## 8 6.0 12.5 12.7 DF11CZ-10DS-2V(##) CL0543-2066-9-## 10 8.0 14.5 14.7 DF11CZ-12DS-2V(##) CL0543-2067-1-## 12 10.0 16.5 16.7 DF11CZ-14DS-2V(##) CL0543-2068-4-## 14 12.0 18.5 18.7 DF11CZ-16DS-2V(##) CL0543-2069-7-## 16 14.0 20.5 20.7 DF11CZ-18DS-2V(##) CL0543-2070-6-## 18 16.0 22.5 22.7 DF11CZ-20DS-2V(##) CL0543-2071-9-## 20 18.0 24.5 24.7 DF11CZ-22DS-2V(##) CL0543-2072-1-## 22 20.0 26.5 26.7 DF11CZ-24DS-2V(##) CL0543-2073-4-## 24 22.0 28.5 28.7 DF11CZ-26DS-2V(##) CL0543-2074-7-## 26 24.0 30.5 30.7 DF11CZ-28DS-2V(##) CL0543-2075-0-## 28 26.0 32.5 32.7 DF11CZ-30DS-2V(##) CL0543-2076-2-## 30 28.0 34.5 34.7 DF11CZ-40DS-2V(##) CL0543-0584-2-## 40 38.0 44.5 44.7 [Specific No.] –##, (##) (22) : Tin Plated Embossed Tape Packaging (with Vacuum Pick-up Cap) (52) : Gold Plated Embossed Tape Packaging (with Vacuum Pick-up Cap) Note 1 : The 40pos. connector can only be combined with SMT products. Note 2 : Embossed packaging products have the reel wrapped in polyethylene and include a desiccant. 9 Purchase Unit 500pcs per reel DF11 Series/2.0mm Pitch, Double-Row Connector (UL/CSA Compliant) Straight Pin Header A B P=2.0 5.0 2.0 No.2 No.1 3.0 6.6 3.05 1.6 Polarity Mark 3.0 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ● Board Through-hole Diameter : φ0.8+0.1  0 □0.5 Unit : mm Part No. HRS No. No. of Pos. A B Purchase Unit (##) : (01) Purchase Unit (##) : (08) Purchase Unit (##) : (24) DF11-4DP-2DSA(##) CL0543-0517-5-## 4 6.0 2.0 81pcs per tube DF11-6DP-2DSA(##) CL0543-0518-8-## 6 8.0 4.0 61pcs per tube DF11-8DP-2DSA(##) CL0543-0519-0-## 8 10.0 6.0 49pcs per tube DF11-10DP-2DSA(##) CL0543-0520-0-## 10 12.0 8.0 40pcs per tube DF11-12DP-2DSA(##) CL0543-0521-2-## 12 14.0 10.0 34pcs per tube DF11-14DP-2DSA(##) CL0543-0522-5-## 14 16.0 12.0 30pc per tube DF11-16DP-2DSA(##) CL0543-0523-8-## 16 18.0 14.0 27pcs per tube DF11-18DP-2DSA(##) CL0543-0524-0-## 18 20.0 16.0 DF11-20DP-2DSA(##) CL0543-0525-3-## 20 22.0 18.0 22pcs per tube DF11-22DP-2DSA(##) CL0543-0526-6-## 22 24.0 20.0 20pcs per tube DF11-24DP-2DSA(##) CL0543-0527-9-## 24 26.0 22.0 18pcs per tube DF11-26DP-2DSA(##) CL0543-0528-1-## 26 28.0 24.0 17pcs per tube DF11-28DP-2DSA(##) CL0543-0529-4-## 28 30.0 26.0 16pcs per tube DF11-30DP-2DSA(##) CL0543-0530-3-## 30 32.0 28.0 15pcs per tube DF11-32DP-2DSA(##) CL0543-0531-6-## 32 34.0 30.0 14pcs per tube [Specific No.] -##,(##) (01) : Gold Plated (08) : Tin Plated (24) : Tin Plated 10 100pcs per bag 100pcs per bag 24pcs per tube DF11 Series/2.0mm Pitch, Double-Row Connector (UL/CSA Compliant) Right Angle Pin Header □0.5 5.0 2.0 3.0 No.2 P=2.0 3.0 2.0 1.45 7.7 Polarity Mark 10.0 6.45 3.05 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ● Board Through-hole Diameter : φ0.8+0.1  0 No.1 B A Unit : mm Part No. HRS No. No. of Pos. A B Purchase Unit DF11-4DP-2DS(##) CL0543-0533-1-## 4 6.0 2.0 81pcs per tube DF11-6DP-2DS(##) CL0543-0534-4-## 6 8.0 4.0 61pcs per tube DF11-8DP-2DS(##) CL0543-0535-7-## 8 10.0 6.0 48pcs per tube DF11-10DP-2DS(##) CL0543-0536-0-## 10 12.0 8.0 40pcs per tube DF11-12DP-2DS(##) CL0543-0537-2-## 12 14.0 10.0 34pcs per tube DF11-14DP-2DS(##) CL0543-0538-5-## 14 16.0 12.0 30pcs per tube DF11-16DP-2DS(##) CL0543-0539-8-## 16 18.0 14.0 27pcs per tube DF11-18DP-2DS(##) CL0543-0540-7-## 18 20.0 16.0 24pcs per tube DF11-20DP-2DS(##) CL0543-0541-0-## 20 22.0 18.0 22pcs per tube DF11-22DP-2DS(##) CL0543-0542-2-## 22 24.0 20.0 20pcs per tube DF11-24DP-2DS(##) CL0543-0543-5-## 24 26.0 22.0 18pcs per tube DF11-26DP-2DS(##) CL0543-0544-8-## 26 28.0 24.0 17pcs per tube DF11-28DP-2DS(##) CL0543-0545-0-## 28 30.0 26.0 16pcs per tube DF11-30DP-2DS(##) CL0543-0546-3-## 30 32.0 28.0 15pcs per tube DF11-32DP-2DS(##) CL0543-0547-6-## 32 34.0 30.0 14pcs per tube [Specific No.] -##,(##) (24) : Tin Plated (52) : Gold Plated 11 DF11 Series/2.0mm Pitch, Double-Row Connector (UL/CSA Compliant) 1.5 No.1 No.1 1.5 ■ PCB Mounting Pattern 2.0±0.1 A±0.1 P=2.0±0.05 1.1±0.1 6.3±0.1 2.8±0.1 2.0±0.1 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2.25 7.2 B No.2 No.2 2.0 2.0 ø0 . 5 A 0.65 0.65 6.2 A A 1.5 P=2.0 P=2 1.5 Straight Pin Header (SMT) C±0.1 2.0±0.1 2.0±0.1 Note : If the shaded area has a pattern and is not treated with resist it may touch the connector contact. 12 DF11 Series/2.0mm Pitch, Double-Row Connector (UL/CSA Compliant) Unit : mm Tin Plated Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. Gold Plated HRS No. Part No. HRS No. No. of Pos. A B C DF11CZ-4DP-2V(27) CL0543-2047-4-27 DF11C-4DP-2V(57) CL0543-0682-1-57 4 2.0 8.5 8.7 DF11CZ-6DP-2V(27) CL0543-2048-7-27 DF11C-6DP-2V(57) CL0543-0683-4-57 6 4.0 10.5 10.7 DF11CZ-8DP-2V(27) CL0543-2049-0-27 DF11C-8DP-2V(57) CL0543-0684-7-57 8 6.0 12.5 12.7 DF11CZ-10DP-2V(27) CL0543-2050-9-27 DF11C-10DP-2V(57) CL0543-0685-0-57 10 8.0 14.5 14.7 DF11CZ-12DP-2V(27) CL0543-2051-1-27 DF11C-12DP-2V(57) CL0543-0686-2-57 12 10.0 16.5 16.7 DF11CZ-14DP-2V(27) CL0543-2052-4-27 DF11C-14DP-2V(57) CL0543-0687-5-57 14 12.0 18.5 18.7 DF11CZ-16DP-2V(27) CL0543-2053-7-27 DF11C-16DP-2V(57) CL0543-0688-8-57 16 14.0 20.5 20.7 DF11CZ-18DP-2V(27) CL0543-2054-0-27 DF11C-18DP-2V(57) CL0543-0689-0-57 18 16.0 22.5 22.7 DF11CZ-20DP-2V(27) CL0543-2055-2-27 DF11C-20DP-2V(57) CL0543-0690-0-57 20 18.0 24.5 24.7 DF11CZ-22DP-2V(27) CL0543-2056-5-27 DF11C-22DP-2V(57) CL0543-0691-2-57 22 20.0 26.5 26.7 DF11CZ-24DP-2V(27) CL0543-2057-8-27 DF11C-24DP-2V(57) CL0543-0692-5-57 24 22.0 28.5 28.7 DF11CZ-26DP-2V(27) CL0543-2058-0-27 DF11C-26DP-2V(57) CL0543-0693-8-57 26 24.0 30.5 30.7 DF11CZ-28DP-2V(27) CL0543-2059-3-27 DF11C-28DP-2V(57) CL0543-0694-0-57 28 26.0 32.5 32.7 DF11CZ-30DP-2V(27) CL0543-2060-2-27 DF11C-30DP-2V(57) CL0543-0695-3-57 30 28.0 34.5 34.7 DF11CZ-32DP-2V(27) CL0543-2061-5-27 DF11C-32DP-2V(57) CL0543-0696-6-57 32 30.0 36.5 36.7 DF11CZ-40DP-2V(27) CL0543-2062-8-27 DF11C-40DP-2V(57) CL0543-0697-9-57 40 38.0 44.5 44.7 Purchase Unit 500pcs per reel [Specific No.] -##,(##) (27) : Tin Plated Embossed Tape Packaging (with Vacuum Pick-up Cap) (57) : Gold Plated Embossed Tape Packaging (with Vacuum Pick-up Cap) Note 1 : The 40pos. connector can only be combined with SMT products. Note 2 : Embossed packaging products have the reel wrapped in polyethylene and include a desiccant. Note 3 : There may be blisters on the mold surfaces excluding the mating face during mounting. However this does not affect the product performance. 13 DF11 Series/2.0mm Pitch, Double-Row Connector (UL/CSA Compliant) In-line Plug A B C D No.2 6.0 2.0 0.9 P=2.0 No.1 13.0 1 1.8 A Polarity Mark CAV No. Marking ■ In-line Plug Panel Cutouts E +0.1 0 F +0.1 0 パネル Panel 3.9 +0.1 0 6.3 +0.1 0 2.5 +0.1 0 7.3 +0.1 0 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 5.0 Shown Assembled with Cable Note 1 Note 1 : Please use the non-radius side for the panel hooking area. Note 2 : Applicable panel thickness is 1.6 to 1.0mm (Slight misalignment may occur for the panel thicknesses excluding 1.6 and 1.2mm.) Unit : mm Part No. HRS No. No. of Pos. A B C D E F DF11-4DEP-2C CL0543-0619-5-00 4 11.0 9.2 6.0 2.0 9.4 6.3 DF11-6DEP-2C CL0543-0620-4-00 6 13.0 11.2 8.0 4.0 11.4 8.3 DF11-8DEP-2C CL0543-0621-7-00 8 15.0 13.2 10.0 6.0 13.4 10.3 DF11-10DEP-2C CL0543-0622-0-00 10 17.0 15.2 12.0 8.0 15.4 12.3 DF11-12DEP-2C CL0543-0623-2-00 12 19.0 17.2 14.0 10.0 17.4 14.3 DF11-14DEP-2C CL0543-0624-5-00 14 21.0 19.2 16.0 12.0 19.4 16.3 DF11-16DEP-2C CL0543-0625-8-00 16 23.0 21.2 18.0 14.0 21.4 18.3 DF11-18DEP-2C CL0543-0626-0-00 18 25.0 23.2 20.0 16.0 23.4 20.3 DF11-20DEP-2C CL0543-0627-3-00 20 27.0 25.2 22.0 18.0 25.4 22.3 DF11-22DEP-2C CL0543-0628-6-00 22 29.0 27.2 24.0 20.0 27.4 24.3 DF11-24DEP-2C CL0543-0629-9-00 24 31.0 29.2 26.0 22.0 29.4 26.3 DF11-26DEP-2C CL0543-0630-8-00 26 33.0 31.2 28.0 24.0 31.4 28.3 DF11-28DEP-2C CL0543-0631-0-00 28 35.0 33.2 30.0 26.0 33.4 30.3 DF11-30DEP-2C CL0543-0632-3-00 30 37.0 35.2 32.0 28.0 35.4 32.3 DF11-32DEP-2C CL0543-0633-6-00 32 39.0 37.2 34.0 30.0 37.4 34.3 14 Purchase Unit 100pcs per bag DF11 Series/2.0mm Pitch, Double-Row Connector (UL/CSA Compliant) In-line Adaptor A B C D 2.0 No.2 6.0 2.0 0.9 P=2.0 CAV No.Marking 表示 CAV No. □0.5 No.1 12.0 5.0 2.0 ↑ Note : The insertion and extraction force is higher on this side. No.2 □0.5 No.1 ■ In-line Adaptor Panel Cutouts E +0.1 0 F +0.1 0 Panel パネル 3.9 +0.1 0 7.3 +0.1 0 2.5 +0.1 0 6.3 +0.1 0 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 5.0 Polarity Mark Note 注1 1 Note 1 : Please use the non-radius surface in the panel hooking area. Note 2 : Applicable panel thickness is 1.6 to 1.0mm (Slight misalignment may occur for the panel thicknesses excluding 1.6 and 1.2mm.) Unit : mm Part No. HRS No. No. of Pos. A B C D E F DF11-4DEP-2A CL0543-0698-1-00 4 11.0 9.2 6.0 2.0 9.4 6.3 DF11-6DEP-2A CL0543-0699-4-00 6 13.0 11.2 8.0 4.0 11.4 8.3 DF11-8DEP-2A CL0543-0700-1-00 8 15.0 13.2 10.0 6.0 13.4 10.3 DF11-10DEP-2A CL0543-0701-4-00 10 17.0 15.2 12.0 8.0 15.4 12.3 DF11-12DEP-2A CL0543-0702-7-00 12 19.0 17.2 14.0 10.0 17.4 14.3 DF11-14DEP-2A CL0543-0703-0-00 14 21.0 19.2 16.0 12.0 19.4 16.3 DF11-16DEP-2A CL0543-0704-2-00 16 23.0 21.2 18.0 14.0 21.4 18.3 DF11-18DEP-2A CL0543-0705-5-00 18 25.0 23.2 20.0 16.0 23.4 20.3 DF11-20DEP-2A CL0543-0706-8-00 20 27.0 25.2 22.0 18.0 25.4 22.3 DF11-22DEP-2A CL0543-0707-0-00 22 29.0 27.2 24.0 20.0 27.4 24.3 DF11-24DEP-2A CL0543-0708-3-00 24 31.0 29.2 26.0 22.0 29.4 26.3 DF11-26DEP-2A CL0543-0709-6-00 26 33.0 31.2 28.0 24.0 31.4 28.3 DF11-28DEP-2A CL0543-0710-5-00 28 35.0 33.2 30.0 26.0 33.4 30.3 DF11-30DEP-2A CL0543-0711-8-00 30 37.0 35.2 32.0 28.0 35.4 32.3 DF11-32DEP-2A CL0543-0712-0-00 32 39.0 37.2 34.0 30.0 37.4 34.3 15 Purchase Unit 100pcs per bag DF11 Series/2.0mm Pitch, Double-Row Connector (UL/CSA Compliant) Crimping Contact for Socket (Header Area) 1.35 0.7 3.0 1.5 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 9.9 0.7 0.8 1.2 6.2 1.0 3.1 1.85 ◆ Reel Contact (Applicable Tool : Applicator) Part No. HRS No. Finish Purchase Unit Applicable Wire (Tin Plated Annealed Copper Wire) (Note 2) UL Wire Size Standed Wire Conductor Calculated Cross-section Jacket Outer Dia. DF11-22SCF CL0543-0601-0-00 Tin Plated 1061 22 AWG 17 / 0.16mm 0.342mm2 1.2 to 1.45mm DF11-22SCFA(04) CL0543-0603-5-04 Gold Plated 1061 22 AWG 17 / 0.16mm 0.342mm2 1.2 to 1.45mm Tin Plated 1061, 1007 24 AWG 26 AWG 28 AWG 11 / 0.16mm 7 / 0.16mm 7 / 0.127mm 0.221mm2 0.141mm2 0.089mm2 0.9 to 1.45mm 1061, 1007 24 AWG 26 AWG 28 AWG 11 / 0.16mm 7 / 0.16mm 7 / 0.127mm 0.221mm2 0.141mm2 0.089mm2 0.9 to 1.45mm DF11-2428SCF DF11A-2428SCF (Note 1) CL0543-0500-2-00 10,000pcs per reel CL0543-0634-9-00 Tin Plated DF11-2428SCFA(04) CL0543-0550-0-04 Gold Plated 1061, 1007 24 AWG 26 AWG 28 AWG 11 / 0.16mm 7 / 0.16mm 7 / 0.127mm 0.221mm2 0.141mm2 0.089mm2 0.9 to 1.45mm DF11-30SCF CL0543-0605-0-00 Tin Plated 1061, 1007 30 AWG 7 / 0.1mm 0.055mm2 0.75 to 1.2mm DF11-30SCFA(04) CL0543-0607-6-04 Gold Plated 1061, 1007 30 AWG 7 / 0.1mm 0.055mm2 0.75 to 1.2mm ● Strip Length : 1.7 to 2.3mm Note 1 : DF11A-2428SCF is the low insertion/extraction tin plated type. Note 2 : Contact your Hirose representative if considering use of non-specified cables. Note 3 : The strip length is a reference value. Adjust so that each dimension after crimping meets the specified value. Refer to the Crimp Quality Standard (ETAD-H0773-00) for details. 16 DF11 Series/2.0mm Pitch, Double-Row Connector (UL/CSA Compliant) ◆ Loose Contact (Applicable Tool : Hand Crimping Tool) Part No. Finish Purchase Unit Applicable Wire (Tin Plated Annealed Copper Wire) (Note 2) UL Wire Size Standed Wire Conductor Calculated Cross-section Jacket Outer Dia. DF11-22SC CL0543-0602-2-00 Tin Plated 1061 22 AWG 17 / 0.16mm 0.342mm2 1.3mm DF11-22SCA CL0543-0604-8-00 Gold Plated 1061 22 AWG 17 / 0.16mm 0.342mm 2 1.3mm 1061 24 AWG 26 AWG 28 AWG 11 / 0.16mm 7 / 0.16mm 7 / 0.127mm 0.221mm 0.141mm2 0.089mm2 1.1mm 1.0mm 0.9mm 1007 24 AWG 26 AWG 28 AWG 11 / 0.16mm 7 / 0.16mm 7 / 0.127mm 0.221mm2 0.141mm2 0.089mm2 1.45mm 1.3mm 1.2mm 1061 24 AWG 26 AWG 28 AWG 11 / 0.16mm 7 / 0.16mm 7 / 0.127mm 0.221mm2 0.141mm2 0.089mm2 1.1mm 1.0mm 0.9mm 1007 24 AWG 26 AWG 28 AWG 11 / 0.16mm 7 / 0.16mm 7 / 0.127mm 0.221mm2 0.141mm2 0.089mm2 1.45mm 1.3mm 1.2mm 1061 24 AWG 26 AWG 28 AWG 11 / 0.16mm 7 / 0.16mm 7 / 0.127mm 0.221mm2 0.141mm2 0.089mm2 1.1mm 1.0mm 0.9mm 1007 24 AWG 26 AWG 28 AWG 11 / 0.16mm 7 / 0.16mm 7 / 0.127mm 0.221mm2 0.141mm2 0.089mm2 1.45mm 1.3mm 1.2mm DF11-2428SC Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. HRS No. DF11A-2428SC (Note 1) DF11-2428SCA CL0543-0501-5-00 CL0543-0635-1-00 CL0543-0551-3-00 Tin Plated Tin Plated 100pcs per bag Gold Plated 2 DF11-30SC CL0543-0606-3-00 Tin Plated 1061 30 AWG 7 / 0.1mm 0.055mm2 0.8mm DF11-30SCA CL0543-0608-9-00 Gold Plated 1061 30 AWG 7 / 0.1mm 0.055mm2 0.8mm Note 1 : DF11A-2428SC is the low insertion/extraction tin plated type. Note 2 : When crimping using a hand crimping tool, only the above wires are applicable. Note 3 : The strip length is a reference value. Adjust so that each dimension after crimping meets the specified value. Refer to the Crimp Quality Standard (ETAD-H0773-00) for details. 17 DF11 Series/2.0mm Pitch, Double-Row Connector (UL/CSA Compliant) Crimping Contact for In-line Plug (Header Area) 0.9 0.9 1.3 14.1 0.7 3.0 1.5 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.7 0.5 10.4 1.58 ◆ Reel Contact (Applicable Tool : Applicator) Part No. DF11-EP2428PCF HRS No. CL0543-0615-4-00 Finish Tin Plated 10,000pcs per reel DF11-EP2428PCFA CL0543-0617-0-00 Applicable Wire (Tin Plated Annealed Copper Wire) (Note 1) Purchase Unit Gold Plated Wire Size Standed Wire Conductor Calculated Cross-section Jacket Outer Dia. 1061, 1007 24 AWG 26 AWG 28 AWG 11 / 0.16mm 7 / 0.16mm 7 / 0.127mm 0.221mm2 0.141mm2 0.089mm2 0.9 to 1.45mm 1061, 1007 24 AWG 26 AWG 28 AWG 11 / 0.16mm 7 / 0.16mm 7 / 0.127mm 0.221mm2 0.141mm2 0.089mm2 0.9 to 1.45mm UL ● Strip Length : 1.9 to 2.3mm Note 1 : Contact your Hirose representative if considering use of non-specified cables. Note 2 : The strip length is a reference value. Adjust so that each dimension after crimping meets the specified value. Refer to the Crimp Quality Standard (ETAD-H0935-00) for details. ◆ Loose Contact (Applicable Tool : Hand Crimping Tool) Part No. DF11-EP2428PC HRS No. CL0543-0616-7-00 Finish Purchase Unit Tin Plated Applicable Wire (Tin Plated Annealed Copper Wire) (Note 1) UL Wire Size Standed Wire Conductor 1007 24 AWG 26 AWG 28 AWG 11 / 0.16mm 7 / 0.16mm 7 / 0.127mm 0.221mm2 0.141mm2 0.089mm2 1.45mm 1.3mm 1.2mm 1007 24 AWG 26 AWG 28 AWG 11 / 0.16mm 7 / 0.16mm 7 / 0.127mm 0.221mm2 0.141mm2 0.089mm2 1.45mm 1.3mm 1.2mm 100pcs per bag DF11-EP2428PCA CL0543-0618-2-00 Gold Plated Note 1 : When crimping using a hand crimping tool, only the above wires are applicable. Note 2 : The strip length is a reference value. Adjust so that each dimension after crimping meets the specified value. Refer to the Crimp Quality Standard (ETAD-H0935-00) for details. 18 Calculated Cross-section Jacket Outer Dia. DF11 Series/2.0mm Pitch, Double-Row Connector (UL/CSA Compliant) Embossed Carrier Tape Dimensions (JIS-C-0806 Standard) ● Straight Pin Header (SMT) 0.2 (8) 2± 0.5 2±0.5 ø21± (ø80) ø370±2 0.8 A±0.3 B±0.1 ø1.5 Lead hole depth 0. 75 n+20 D+2 0 (D+6)MAX  (D+6)MAX R +0.15 0 1.7 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (5.8) ( 5.8) Reel 3± E 7.8±0.3 7.8± 0.3 0.4±0.1 0.4± 0.1 ø1 .1 +0 0 2±0.15 2± 0.15 16±0.1 16± 0.1 9.4±0.3 9.4± 0.3 C±0.1 5 1. 4±0.1 4± 0.1 1.75±0.1 E-E E E +0.1 1.5 1.5 00 +0.1 Unreeling Direction Unit : mm Product Type DF11CZ-##DP-2V(27) DF11C-##DP-2V(57) No. of Pos. A B C D 4 to 8 24.0 - 11.5 24.4 10 to 12 32.0 28.4 14.2 32.4 14 to 22 44.0 40.4 20.2 44.4 24 to 32 56.0 52.4 26.2 56.4 40 72.0 68.4 34.2 72.4 19 DF11 Series/2.0mm Pitch, Double-Row Connector (UL/CSA Compliant) Receptacle (SMT) ø1.5 Lead hole depth 0.8 ø21± ø370±2 (ø80) 2± 0.5 2±0.5 C±0.1 (5.5) 1.75±0.1 Contact No.1 E-E 0.2 E ø1 .1 +0 0 4±0.1 4 ± 0.1 B±0.1 A±0.3 5 1. 16±0.1 16± 0.1 E 3± 2±0.1 2± 0.1 1.75±0.1 ● R0 .7 (5) E +0.15 0 1.7 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 5 (5) +0.1 0 +0.1 E 1.5 1.5 (D+6)MAX  (D+6)MAX 0.4±0.1 Unreeling Direction D +20 D+2 0 6.6±0.3 8.4±0.3 Unit : mm Product Type DF11CZ-##DS-2V No. of Pos. A B C D 4 to 8 24.0 - 11.5 24.4 10 to 12 32.0 28.4 14.2 32.4 14 to 18 44.0 40.4 20.2 44.4 20 56.0 52.4 26.2 56.4 22 44.0 40.4 20.2 44.4 24 to 32 56.0 52.4 26.2 56.4 40 72.0 68.4 34.2 72.4 20 DF11 Series/2.0mm Pitch, Double-Row Connector (UL/CSA Compliant) Application Pattern DF11-#DP-2DS(24) 14.2 6.5 5.0 10.8 11.45 DF11-#DS-2R##(05) DF11-πDS-2R**(05) 2.0 DF11#Z-#DP-2V 1.6 4.2 5.0 8.9 9.55 DF11#Z-#DP-2V  DF11-#DP-2DSA(08) 1.8 7.7 DF11-#DP-2DS(24) DF11-#DS-2C 2.0 10.0 13.8(注 1) 7.8 1.6 11.0 DF11-#DS-2R##(05) Panel DF11-#DEP-2C DF11-πDS-2R**(05) DF11-#DS-2R##(05) Panel DF11-#DEP-2A DF11-#DS-2R##(05) (Note 1)DF11-#DS-2C : 11.9 7.55 7.8 DF11-#DS-2DSA(05) DF11Z-#DS-2V 8.2 DF11#Z-#DS-2V 8.45 DF11-#DS-2DSA(05) DF11Z-πDS- DF11#Z-*DS-2V DF11-πDS-2DSA(05) DF11-πDS-2DSA(05) DF11#Z-#DP-2V DF11-#DP-2DSA(08) DF11-#DP-2DS(24) 5.0 DF11-#DS-2DSA(05) 2.0 8.65 10.95 8.9 2.0 5.0 11.2 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DF11-#DP-2DSA(08) DF11Z-#DS-2V 21 DF11 Series/2.0mm Pitch, Double-Row Connector (UL/CSA Compliant) Applicable Crimping Tool Type Part No. HRS No. AP105-DF11-22S CL0901-4529-7-00 DF11-22SCF DF11-22SCFA(04) AP105-DF11-2428S CL0901-4511-1-00 DF11-2428SCF DF11A-2428SCF DF11-2428SCFA(04) AP105-DF11-30S CL0901-4532-1-00 DF11-30SCF DF11-30SCFA(04) AP105-DF11-EP2428P CL0901-4528-4-00 DF11-EP2428PCF DF11-EP2428PCFA CM-105C CL0901-0001-0-00 ― HT801/DF11-22S(A) CL0550-0407-5-00 DF11-22SC DF11-22SCA HT801/DF11-2428S(A) CL0550-0403-4-00 DF11-2428SC DF11A-2428SC DF11-2428SCA HT801/DF11-30S(A) CL0550-0408-8-00 DF11-30SC DF11-30SCA HT801/DF11-EP2428P(A) CL0550-0409-0-00 DF11-EP2428PC DF11-EP2428PCA DF-C-PO(B) CL0550-0179-2-00 DF11(A)-####SC(F)(A)(##) DF11-EP2428PC(F)(A) Applicator Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Press Hand Crimping Tool Contact Extraction Tool Applicable Contact Note 1 : Please do the crimping operations according to the table in the Crimp Quality Standard (ETAD-H0773-00, ETAD-H0935-00). Note 2 : Problems with tools other than those specified by Hirose are outside the scope of warranty. 22 DF11 Series/2.0mm Pitch, Double-Row Connector (UL/CSA Compliant) Crimping ■ Items required prior to starting crimping The work- related documents shown below are required before starting harness assembly. ( The ● mark represents required documents. ) Please contact your Hirose sales representative if you do not have these documents. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Document Title Automatic Hand Crimping Crimping Machine Tool Description Remarks Crimping Machine Main Unit Instruction Manual Explanation of Main Press Machine Unit ● - Bundled with purchase of main press machine unit Applicator Spare Parts Identification Explanation for Applicator Installation ● - Crimp Conditions Standard Crimp Height and Tensile Strength Values ● - Crimp Quality Standards Various Standards for Crimping Conditions ● - Operating Instructions for Hand Tool Crimp Height, Tensile Strength, and Other Inspection Items - ● Bundled with purchase of hand tool. Harness Procedure Manual ETAD-H0965-00 Harness Procedure ● ● Ask a Hirose sales personnel to provide them. Bundled with purchase of applicator. ■ Tools Use tools specified by Hirose for crimping. * Crimping performed with tools other than those designated should be avoided as it may result in contact failure, disconnection of cable, etc. * Operating instructions are available for the crimping machine and the applicator. Be sure to carefully read the operating instructions manual before beginning work. ■ Applicable Cables Check that the cables to be used are within the applicable range. If you intend to use a cable other than those recommended, contact a sales representative. [ Precautions] - Cables applicable to crimping connectors are tin- plated stranded soft- copper wire. - Avoid crimping solid wire, wires with polyester threads or tin coated wires. - Avoid crimping two cables together. - The crimp height setting values ( Note 1) may vary between tin- plated and gold- plated terminals even if the same electric wires are used. - The crimp height setting values ( Note 1) may vary depending on the difference in the core wire configuration even if the computed cross- sectional area is the same. Note 1 : The crimp height is an important item that determines crimping quality. We execute crimping tests for each electric wire to ensure the optimal value for the crimp height with high precision, thereby ensuring optimal setup values. 23 DF11 Series/2.0mm Pitch, Double-Row Connector (UL/CSA Compliant) Precautions 1. Recommended Temperature Profile (SMT) Temperature (℃) 10s Max. 250 230 200 180±10 60s Max. 150 100 to 120s Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 100 Time (S) Note 1 : Up to 2 cycles of Reflow soldering are possible under the same conditions, provided that there is a return to normal temperature between the first and second cycle. Note 2 : The temperature profile indicates the board surface temperature of the contact leads. Note 3 : This reflow profile is for the connectors packaged in embossed tape (reel), with desiccant in the package. (Within 168 hours of opening) Temperature (℃) 10s Max. 240 230 200 150 165±5 60s Max. 90 to 120s 100 Time (S) Note 4 : Reflow temperature conditions for embossed packaged products without desiccant and for embossed packaged products with desiccant that have been opened 168 hours ago or longer. 24 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DF11 Series/2.0mm Pitch, Double-Row Connector (UL/CSA Compliant) 2. Recommended Manual Soldering Condition (SMT) Soldering iron temperature: 290 ± 10℃ , Soldering time: Within 2 seconds 3. Recommended Screen Thickness (SMT) 0.15 to 0.2mm 4. Board Warpage (SMT) Based on the both connector edges, 0.03mm Max. is allowed in the connector center area. 5. Recommended Soldering Condition (Throughhole) Flow : 250 ± 5℃ for 10 seconds Manual soldering : Soldering iron temperature 290 ± 10℃ for 2 seconds 6. Cleaning Condition Refer to the "Wire-to-Board Connector Use Handbook". 7. Connection Condition Refer to the "Wire-to-Board Connector Use Handbook". 8. Precautions ■ When inserting the crimp terminal into the IDC socket, do not insert diagonally in order to maintain performance reliability. ■ Refer to the DF11 Series Cable Assembly Procedure (ETAD-H0965-00), DF11#-##SC##(##) Crimp Quality Standard (ETAD-H0773-00), DF11#-EP####PC##(##) (ETAD-H0935-00) and Crimp Condition for the cable assembly procedures. ■ Please refrain from insertion and removal when not mounted to the board as it may result in damage or deformation of the contacts. ■ Do not remove the product by holding the cable as it may result in damage. ■ When soldering by hand do not apply flux that may result in flux rising. ■ There may be slight variation in the mold coloration based on production lot but this does not affect the product performance. 9. Handling Instructions Refer to the following documents when handling this product. ■ Crimp Quality Standard (ETAD-H0773-00, ETAD-H0935-00) ■ Cable Assembly Procedure (ETAD-H0965-00) ■ Wire-to-Board Connector Use Handbook While taking in consideration Specifications mentioned in this catalog are reference values. When considering to order or use this product, please confirm the " Drawing" and " Product Specifications" sheets. Use an appropriate cable when using the connector in combination with cables. If considering usage of a non- specified cable, please contact your sales representative. If assembly process is done by jigs & tools which are not identified by Hirose assurance will not be given. Please consult with your Hirose sales representative if you are planning to use the product for any of the following applications. ( Automotive, medical, public infrastructure, aerospace/ defense, etc. ) Hirose will consider the validity of the warranty depending on the conditions. 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN        https://www.hirose.com https://www.hirose-connectors.com ※ The contents of this catalog are current as of date of 3/ 2021. Contents are subject to change without notice for the purpose of improvements. 25
H3BXG-10110-S4
物料型号: - 型号包括DF11-4DS-2R26(05)至DF11-32DS-2R26(05),涵盖从4位到32位的不同配置。
器件简介: - DF11系列是2.0mm间距的双排连接器,符合UL/CSA安全标准。 - 特点包括节省空间、多种连接方式、适用电线范围宽、IDC类型减少组装时间。
引脚分配: - 提供了详细的引脚分配图和说明,包括位置和极性标记。
参数特性: - 额定电流范围从0.5A至2A,取决于接线方式和电线规格。 - 额定电压为AC 250V(除了30AWG为30V AC)。 - 操作温度范围为-30至+85°C。
功能详解: - 提供了详细的产品规格,包括绝缘电阻、耐电压、接触电阻、插拔力、振动、湿度、温度循环、配对耐久性和耐焊接热性。
应用信息: - 适用于商业设备,如复印机、打印机等。
封装信息: - 材料包括聚酰胺绝缘体和磷青铜接触件,有锡镀层或金镀层可选。 - 提供了详细的产品编号结构,方便用户根据产品编号确定产品规格。
H3BXG-10110-S4 价格&库存
很抱歉,暂时无法提供与“H3BXG-10110-S4”相匹配的价格&库存,您可以联系我们找货
