KMC3S010RC
KMC3S010RC
    OTHER
    PTC自恢复保险丝 1206 Vmax=60V Imax=100A Ihold=0.1A
KMC3S010RC 数据手册
THINKING ELECTRONIC INDUSTRIAL CO., LTD. HEAD OFFICE: 12F, No.93, Dashun 1st Rd., Zuoying Dist., Kaohsiung, Taiwan TEL: 886-7-5577660 FAX: 886-7-5570560 MANUFACTURING SITE □ KAOHSIUNG FACTORY 1:No. 51, Kaifa Rd., N.E.P.Z, Kaohsiung City 81170, Taiwan TEL: 886-7-9616668 □ KAOHSIUNG FACTORY 2:No. 2-2, Xinjian S. Rd., N.E.P.Z., Kaohsiung City 81170, Taiwan TEL: 886-7-9630001 R FAX: 886-7-9616698 FAX: 886-7-3635113 CHANGZHOU FACTORY: No.6 Longmen Rd., Wujin High & New-Tech Industrial Development Zone, Changzhou, Jiangsu, China 213161 TEL:86-519-86578999 FAX:86-519-86558643 □ DONG GUAN FACTORY: No.45, East Rd., Sha-Tao Dist., Chang-An Town, Dongguan City, Guangdong, China 523863 TEL:86-769-85542016 FAX:86-769-85546890 □ YICHANG FACTORY: No. 283 Xiaoting Avenue, Xiaoting Dist., Yichang City 443007, Hubei, China TEL:86-717-6510010 FAX:86-717-6511430 □ JIANGXI FACTORY:Tangying Road, Ceramics Industry Garden, Jingdezhen City, Jiangxi, China 333400 TEL:86-798-2621372 FAX:86-798-2126372 SPECIFICATION FOR CUSTOMER 湖南华秋数字科技有限公司 CERTIFIED MODEL/TYPE KMC3S010 PART NO. KMC3S010RC(RoHS+HF) APPROVAL APPLICATION CUSTOMER P/N ISSUE DATE Jan.11.2023 REV. NO. REV. DATE FOR CUSTOMER APPROVAL CHECKED BY Haili Gong APPROVED BY Huaifang Zhang Polymer PTC Resettable Fuse KMC Type Part No.: KMC3S010RC REVISED RECORD SHEET REV. NO REV. DATE REVISED CONTENT Polymer PTC Resettable Fuse KMC Type Part No.: KMC3S010RC INDEX Page ■ Part Number Code 1 ■ Structure and Dimensions 2 ■ Electrical Characteristics 2 ■ Soldering Recommendation 3 ■ Typical Time-to-Trip Curves at 23℃ 4 ■ Thermal Derating Curve 4 ■ RoHS Compliant Declaration 5 ■ Warehouse Storage Conditions of Products 5 ■ Safety Approvals 6 ■ Certificates 6 ■ Packaging 7 Polymer PTC Resettable Fuse KMC Type Part No.: KMC3S010RC Page 1 Part Number Code Example : K MC 3 S 010 R C (1) (2) (3) (4) (5) (6) (7) Item No. Specification Digit Thinking Polymer PTC Resettable Fuse (1) Product Type (2) Type Series (3) Size (EIA) 3 1206 (4) Structure S S type (5) I hold (6) (7) K MC SMD series 010 0.1A @ 23℃ Packaging R Taping & Reel Optional Suffix C RoHS+HF compliance Automotive Polymer PTC Resettable Fuse KMC Type Part No.: KMC3S010RC Page 2 Structure and Dimensions E D CY B A C ( unit : mm ) Item A B C D E MIN. 3.00 1.50 0.70 0.125 0.08 MAX. 3.50 1.80 1.15 0.750 0.45 Electrical Characteristics (23 ℃ ) Part No. KMC3S010RC Part No. KMC3S010RC V max. I max. I hold @ 23℃ I trip @ 23℃ Pd (Max.) (V) (A) (A) (A) (W) 60 100 0.100 0.250 0.40 Max.time to trip Resistance (W) Operating / storage temperature Initial (Ri) Post trip (R1) (A) (Sec.) min. max. (℃) 0.50 1.00 1.60 15.00 -40 ~ +85 Ihold=Hold current :maximum current device will pass without interruption at 23℃ still air unless otherwise specified. Itrip=Trip current :minimum current that will switch the device from low resistance to high resistance at 23℃ still air unless otherwise specified. Vmax=Maximum voltage device can withstand without damage at rated current. Imax=Maximum current device can withstand without damage at rated voltage . Pd=Power dissipated from device while the tripped state at 23℃ still air unless otherwise specified. Rimin=Minimum resistance of device prior to tripping at 23℃ . R1max=Maximum resistance of the device one hour after tripping at 23℃ . Caution:Operation beyond the specified rating or improper use may result in damage and possible arcing and flame. Polymer PTC Resettable Fuse KMC Type Part No.: KMC3S010RC Page 3 Soldering Recommendation █ IR-Reflow Soldering Profile Cooling Peak Temp Preheating 溫度 Temperature 255~260℃ 60 ~150 sec 217℃ 150~200℃ Tamb 60~180 sec 3℃/sec (max.) 20~40 sec 3℃/sec (max.) t 6℃/sec (max.) 8 min Max Time The welding method of the product is reflow welding, wave soldering is not recommended * Recommended reflow methods: IR, Vapor phase, hot air oven. * Devices can be cleaned using standard industry methods and solvents. Notes: If reflow temperatures exceed the recommended profile,devices may not meet the performance requirements. Devices are not designed to be wave soldered to the bottom side of the board. █ Recommended Reworking Conditions with Soldering Iron Item Conditions Temperature of Soldering Iron-tip 360 ℃(max.) Soldering Time 3 sec (max.) Diameter of Soldering Iron-tip f 3 mm (max.) █ Recommended Soldering Pad Dimensions (Nominal) (Unit:mm) C B A B SIZE A B C 1206 2.00 1.00 1.90 Polymer PTC Resettable Fuse KMC Type Part No.: KMC3S010RC Page 4 Typical Time- to-Trip Curves at 23 ℃ Thermal Derating Curve Thermal derating curve for SMD1206 series Percentage of Rated Current (%) 180 160 140 120 100 80 60 40 20 0 -40 -20 0 20 40 60 80 100 Ambient Temperature(℃ ) Model KMC3S010 -40℃ 0.14 -20℃ 0.13 0℃ 0.11 Ambient Operation Temperature 23℃ 40℃ 50℃ 0.1 0.08 0.07 60℃ 0.07 70℃ 0.06 85℃ 0.055 Polymer PTC Resettable Fuse KMC Type Part No.: KMC3S010RC Page 5 RoHS Compliant Declaration We hereby declare that the components delivered to your company are compliant with RoHS directive 2015/863/EU. Warehouse Storage Conditions of Products (I) Storage Conditions : 1.Storage Temperature : -10℃~+40℃ 2.Relative Humidity : ≦75%RH 3.Keep away from corrosive atmosphere and sunlight. (II) Period of Storage : 1 year Polymer PTC Resettable Fuse KMC Type Part No.: KMC3S010RC Safety Approvals (Certified Model/Type : KMC3S010) * UL 1434 / cUL recognized (File # E138827) * TUV recognized (File # R50143386) Certificates (1) IATF 16949 certificate (2) ISO 9001 certificate Test Report (1) RoHS test report (2) Halogen-free test report Page 6 Polymer PTC Resettable Fuse KMC Type Part No.: KMC3S010RC Page 7 Packaging ■ Taping specification ( 1206 type) Unit : mm Index Type 1206 A0 B0 K0 P0 P1 P2 T E F D0 +0.1/-0 +0.1/-0 ±0.05 ±0.1 ±0.1 ±0.1 ±0.05 ±0.1 ±0.1 ±0.05 1.95 3.55 1.40 4.00 4.00 2.00 0.23 1.75 3.50 1.55 ■ Quantity ( 2500 pcs / reel ) D1 W 10P0 min ±0.3 ±0.2 1.00 8.00 40.00
KMC3S010RC 价格&库存
很抱歉,暂时无法提供与“KMC3S010RC”相匹配的价格&库存,您可以联系我们找货
