PS2828AB0203S
PS2828AB0203S
    PARLEXUSALLC
    CABLE ASSY 41POS RCPT-RCPT 8"
PS2828AB0203S 数据手册
RESPECTIVE END ORIENTATIONS SAME SIDE- DESIGNATED "S" OPPOSITE SIDE- DESIGNATED "O" CREATING A PART NUMBER HEADER CONNECTOR LENGTH PART NUMBER FORMAT (mm) CL (15 CHARACTERS MAXIMUM) LENGTH P S 2 8 2 8 A B X X X X S _ - (mm) CL CL CL CONNECTOR ORIENTATION WITH RESPECT TO CABLE STYLE A DRAWING NUMBER STYLE B END 1 STYLE (A OR B) 0.200" 0.120" END 2 STYLE (A OR B) ASSEMBLY LENGTH IN MILLIMETERS RESPECTIVE END ORIENTATIONS (S OR O) SPACE CURRENT DRAWING REVISION 1.100" PIN #1 i.e. PS2828AA0254O 0.345" ±0.010" PIN #1 0.857" ±0.005" EXAMPLE GIVEN INDICATES A 41 POS. CABLE ASSEMBLY TERMINATED WITH HIROSE CONNECTORS (DF9C-41S-1V(20)) IN WHICH PIN #1 TRACES TO PIN #1, ASSEMBLY IS 10.000" IN LENGTH, AND CONNECTORS ARE ON OPPOSITE SIDES OF CABLE AS DEFINED AT LEFT. NOTES 1) INSULATION: 0.002" THICK POLYESTER 2) CONDUCTORS: 0.003" X 0.011" (39 PLACES) 0.003" X 0.026" (2 PLACES, OUTER) 3) HEADER MATERIAL: DUPONT 612 NYLON 4) CONNECTOR: HIROSE P/N DF9C-41S-1V(20) 5) CABLE RATING: AWM STYLE 20890 105°C, 90V, VW-1 6) CABLE THICKNESS= 0.010"±0.002" 7) CABLE WIDTH = 0.857"±0.005" PROPRIETARY INFORMATION NOTICE This document and the designs, specifications, and engineering information disclosed herein are the property of Parlex USA LLC, and are not to be disseminated or reproduced without expressed written consent. This document is loaned in confidence and then only for consideration of the matter disclosed hereon. In accepting loan of this document, the recipient agrees to keep it and the matter disclosed hereon in confidence and not to use or permit their use in any way detrimental to Parlex USA LLC. A Johnson Electric Company SPECIFICATION DRAWING FOR .50MM-41-XXXX-HIROSE ASSEMBLIES ROHS COMPLIANT SIZE B SCALE FSCM 18377 PS-2828 SHEET NONE ROHS VERSION OF PS-564 REV - 1 OF 1
PS2828AB0203S 价格&库存
很抱歉,暂时无法提供与“PS2828AB0203S”相匹配的价格&库存,您可以联系我们找货
PS2828AB0203S
    • 1+384.964701+49.80106
    • 10+327.2183910+42.33070
    库存:18
