RESPECTIVE END ORIENTATIONS
SAME SIDE- DESIGNATED "S"
OPPOSITE SIDE- DESIGNATED "O"
CREATING A PART NUMBER
HEADER
CONNECTOR
LENGTH
PART NUMBER FORMAT
(mm)
CL
(15 CHARACTERS MAXIMUM)
LENGTH
P S 2 8 2 8 A B X X X X S _ -
(mm)
CL
CL
CL
CONNECTOR ORIENTATION WITH RESPECT TO CABLE
STYLE A
DRAWING NUMBER
STYLE B
END 1 STYLE (A OR B)
0.200"
0.120"
END 2 STYLE (A OR B)
ASSEMBLY LENGTH IN MILLIMETERS
RESPECTIVE END ORIENTATIONS (S OR O)
SPACE
CURRENT DRAWING REVISION
1.100"
PIN #1
i.e. PS2828AA0254O 0.345"
±0.010"
PIN #1
0.857"
±0.005"
EXAMPLE GIVEN INDICATES A 41 POS. CABLE ASSEMBLY
TERMINATED WITH HIROSE CONNECTORS (DF9C-41S-1V(20))
IN WHICH PIN #1 TRACES TO PIN #1, ASSEMBLY IS
10.000" IN LENGTH, AND CONNECTORS ARE ON OPPOSITE
SIDES OF CABLE AS DEFINED AT LEFT.
NOTES
1) INSULATION: 0.002" THICK POLYESTER
2) CONDUCTORS: 0.003" X 0.011" (39 PLACES)
0.003" X 0.026" (2 PLACES, OUTER)
3) HEADER MATERIAL: DUPONT 612 NYLON
4) CONNECTOR: HIROSE P/N DF9C-41S-1V(20)
5) CABLE RATING: AWM STYLE 20890 105°C, 90V, VW-1
6) CABLE THICKNESS= 0.010"±0.002"
7) CABLE WIDTH = 0.857"±0.005"
PROPRIETARY INFORMATION NOTICE
This document and the designs, specifications, and engineering
information disclosed herein are the property of Parlex USA LLC,
and are not to be disseminated or reproduced without expressed
written consent. This document is loaned in confidence and then
only for consideration of the matter disclosed hereon. In accepting
loan of this document, the recipient agrees to keep it and the matter
disclosed hereon in confidence and not to use or permit their use in
any way detrimental to Parlex USA LLC.
A Johnson Electric Company
SPECIFICATION DRAWING FOR
.50MM-41-XXXX-HIROSE ASSEMBLIES ROHS COMPLIANT
SIZE
B
SCALE
FSCM
18377
PS-2828
SHEET
NONE
ROHS VERSION OF PS-564
REV
1 OF 1
很抱歉,暂时无法提供与“PS2828AB0102S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+384.964701+49.80106
- 10+327.2183910+42.33070
- 25+316.9936125+41.00797
