Technical Data DS4312
Effective December 2015
Supersedes December 2007
HC9
High current power inductors
Applications
Product description
Surface mount inductors designed for higher
speed switch mode applications requiring lower
inductance, low voltage and high current
Design utilizes high temperature powder iron
material with a non-organic binder to eliminate
thermal aging
Inductance Range from 0.2μH to 47.0μH
Current Range from 3.65 amps to 95.0 amps
Frequency Range 1kHz to 500kHz
Multi-phase regulators
Voltage Regulator Modules (VRMs)
Distributed power systems DC-DC converters
Desktop and server VRMs and EVRDs
Point-of-Load (POL) modules
Field Programmable Gate Array (FPGA) DC-DC
converters
Battery power systems
High current power supplies
Data networking and storage systems
Environmental data
Storage temperature range (component): -40°C
to +155°C
Operating temperature range: -40°C to +155°C
(Ambient plus self-temperature rise)
Solder reflow temperature: J-STD-020D
compliant
Pb
HC9
Product specifications
Part number6
OCL1 (μH) ±15%
lrms2 (amps)
lsat3 (amps) 20%
rolloff
lsat4 (amps) 30%
rolloff
DCR (mΩ)
maximum @ 20°C
Volt-μsec5 (V-μs)
HC9-R20-R
0.218
46.7
65
95
0.50
2.87
HC9-R47-R
0.544
33.7
40
57
0.88
4.78
HC9-1R0-R
1.04
23.7
28
41
1.87
6.70
HC9-1R5-R
1.70
21.0
22
32
2.27
8.46
HC9-2R2-R
2.53
17.2
18
26
3.37
10.4
HC9-3R3-R
3.52
14.3
15
22
4.87
12.4
HC9-4R3-R
4.67
13.0
13.2
19.1
5.90
14.4
HC9-6R8-R
7.45
10.3
11.4
15.1
9.40
18.1
HC9-100-R
10.9
8.50
8.6
12.5
14.0
22.0
HC9-220-R
22.4
6.30
6.0
8.7
25.7
31.5
HC9-330-R
34.5
4.42
4.8
7.0
48.8
37.3
HC9-470-R
49.2
3.65
3.9
5.7
72.3
44.8
1. Open Circuit Inductance (OCL) Test Parameters: 100kHz, 1.0Vrms, 0.0Adc, @ +25°C
2. Irms: DC current for an approximately ∆T of 40°C without core loss. Derating is necessary for
AC currents. Pad layout, trace thickness and width, airflow, and proximity of other heat generating
components will affect the temperature rise. It is recommended that the temperature of the part
not exceed 155°C under worst case conditions verified in the end application.
3. Peak current for approximately 20% rolloff @20°C
4. Peak current for approximately 30% rolloff @20°C
5. Applied Volt-Time product (V-μs) across the inductor. This value represents the applied V-μs at
operating frequency necessary to generate additional core loss which contributes to the 40°C
temperature rise. De-rating of the Irms is required to prevent excessive temperature rise.
The 100% Vμs rating is equivalent to a ripple current Ip-p of 20% of Isat (30% rolloff option).
6. Part number definition: HC9-xxx-R
HC9= Product code and size
xxx = Inductance in μH. R = decimal point. If no R is present last character equals number of zeros.
-R suffix = RoHS compliant
Dimensions–mm
Part marking: HC9= (Product code and size)-xxx=(inductance value
in uH, R= decimal point. If no R is present then last character equals
number of zeros. wwlyly=date code, R=revision level
Tolerances are ±0.2 millimeters unless stated otherwise
Do not route traces or vias underneath the inductor
Packaging information–mm
Supplied in tape and reel packaging, 450 parts per reel, 13” diameter reel.
2
www.eaton.com/elx
HC9
Rolloff
Core loss
www.eaton.com/elx
3
HC9
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb Solder (Tc)
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“HC9-470-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 450+24.51709450+3.17789
- 900+23.12343900+2.99724
- 1350+22.346361350+2.89652
- 2250+21.568132250+2.79564
- 3150+20.347293150+2.63740
- 国内价格 香港价格
- 1+40.809521+5.28969
- 10+33.5364910+4.34697
- 100+27.57995100+3.57489
