Technical Data 4410
Effective November 2015
Supersedes May 2011
CTX01-18738-R
High current, high frequency power inductors
Applications
Voltage Regulator Module (VRM)
Multi-phase and Vcore regulators
Point-of-load modules
Desktop and server VRMs and EVRDs
Base station equipment
Battery power systems
Graphics cards
Data networking and storage systems
Environmental Data
Description
High current carrying capacity, low core losses
Tight tolerance DCR for sensing circuits
11 x 8.0mm footprint surface mount package
in a 7.5mm height
Frequency range up to 2MHz
Halogen free, lead free, RoHS compliant
Storage temperature range: -40°C to +125°C
Operating temperature range: -40°C to +125°C
(ambient plus self-temperature rise)
Solder reflow temperature: J-STD-020D
compliant
HALOGEN
Pb HF
FREE
CTX01-18738-R
Technical Data 4410
Product Specifications
Part Number6
OCL1
(nH) ±10%
FLL2
(nH) minimum
Irms3
(amps)
Isat14
(amps)
Isat25
(amps)
DCR (mΩ)
@20°C
CTX01-18738-R
210
151
50
55
45
0.29 ± 5%
1.Open Circuit Inductance (OCL) Test Parameters: 300kHz, 0.10Vrms, 0.0Adc @ 25°C.
2. Full Load Inductance (FLL) Test Parameters: 300kHz, 0.10Vrms, Isat1 @ 25°C.
3. Irms: DC current for an approximate temperature rise of 20°C without core loss. Derating is necessary for AC currents.
PCB layout, trace thickness and width, air-flow and proximity of other heat generating components will affect the
temperature rise. It is recommended that the temperature of the part not exceed 125°C under worst case operating
conditions verified in the end application.
4. Isat1: Peak current for approximately 20% rolloff at +25°C.
5. Isat2: Peak current for approximately 20% rolloff at +125°C.
6. Part Number Definition: CTX01-18738-R
- CTX01-18738 = Product code and size
- “-R” suffix = RoHS compliant
Dimensions (mm)
6.70
typ.
Part marking: CTX01-18738, wwllyy = Date Code, R = Revision Level
All soldering surfaces must be coplanar within 0.102 millimeters.
Tolerances are ±0.1 millimeters unless stated otherwise.
The DCR is measured from point “a” to point “b”
Packaging information (mm)
Temperature rise vs. total loss
Temperature Rise (°C)
60
50
40
30
0.5
1.0
1.5
Total Loss (W)
2
www.eaton.com/elx
2.0
2.5
CTX01-18738-R
Technical Data 4410
Core loss
Core Loss vs. Ip-p
500kHz
1MHz
300kHz
10
200kHz
100kHz
Core Loss (W)
1
0.1
0.01
0.001
0.0001
0.00001
1
10
100
Ip-p (Amps)
Inductance characteristics
% of OCL vs. Isat1
100.0%
90.0%
80.0%
70.0%
% of OCL
60.0%
50.0%
-40°C
+25°C
+125°C
40.0%
30.0%
20.0%
10.0%
0.0%
www.eaton.com/elx
10
40
Isat1 (Amps)
50
60
70
80
CTX01-18738-R
Technical Data 4410
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb Solder (Tc)
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“CTX01-18738-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+12.712981+1.64462
- 10+10.4511110+1.35201
- 100+8.59156100+1.11145
- 国内价格 香港价格
- 240+4.48117240+0.57971
- 国内价格 香港价格
- 240+4.40435240+0.56977
- 国内价格
- 500+8.92316
- 5000+4.78804
