2420/36GN-1000
2420/36GN-1000
    DABURNELECTRONICS
    ULTRA-FLEXFEP36AWG1000FTGN
2420/36GN-1000 数据手册
Daburn Electronics & Cable 44 Richboynton Road Dover, NJ 07801 Ultra-Flexible Microminiature FEP 150V Lead Wire Ultra flexible high strand count bare copper conductor insulated with a 3.5 mil wall of nonhygroscopic fluoropolymer (FEP). Silver-plated copper can be substituted for a 200°C rating. Used for critical physiological and medical applications where small diameters, long flex-life and non-toxic insulations are of primary consideration. It’s designed for long usage in flow probes and pressure measuring instruments. It also withstands severe, repeated flexing in very high and low temperatures. Description: Single conductor stranded bare copper insulated with non-hygroscopic fluoropolymer (FEP) insulation. This construction allows for a uniform, flexible, concentric, quality construction. Operating Temperature: -150°C to +150°C (specify silver plated copper for 200⁰C) Voltage Rating: 150V. This series is RoHS compliant. Catalog Nom. Wall Number AWG Strand Nom. O.D. Inches mm Inches mm 2420/24 24 105/44 .0035 0.089 0.032 0.813 2420/26 26 105/46 .0035 0.089 0.027 0.686 2420/28 28 65/46 .0035 0.089 0.022 0.559 2420/29 29 52/46 .0035 0.089 0.020 0.508 2420/30 30 41/46 .0035 0.089 0.019 0.483 2420/31 31 75/50 .0035 0.089 0.017 0.432 2420/32 32 65/50 .0035 0.089 0.016 0.406 2420/33 33 52/50 .0035 0.089 0.015 0.381 2420/34 34 41/50 .0035 0.089 0.014 0.356 2420/36 36 26/50 .0035 0.089 0.013 0.330 2420/38 38 17/50 .0035 0.089 0.012 0.305 2420/40 40 10/50 .0035 0.089 0.011 0.279 2420/42 42 7/50 .0035 0.089 0.010 0.254 Standard Put-Ups: 1,000 FT, 500 FT, 100 FT. Available in 10 standard colors. Additional strand constructions are available. 50 AWG strands are made with very fine strands of hard copper. 46 AWG or 48 AWG strand constructions of very fine soft copper are also available for all sizes. Tel: 973-328-3200 Fax: 973-328-3130 www.daburn.com Revision D
2420/36GN-1000
1. 物料型号:文档列出了多个型号,例如2420/24至2420/42,每个型号都有不同的美国线规(AWG)、股线结构、标称壁厚、标称外径等规格。
2. 器件简介:这是一种超柔韧、高股数裸铜导体,外层绝缘材料为3.5密耳的非吸湿性氟塑料(FEP)。若需要200°C的耐温等级,可选用镀银铜。
3. 引脚分配:文档中没有明确提到引脚分配,因为它描述的是线材而非电子元件。
4. 参数特性:线材的工作温度范围为-150°C至+150°C,电压等级为150V。若使用镀银铜,可提高耐温至200°C。该系列产品符合RoHS标准。
5. 功能详解:线材设计用于长期使用在流量探头和压力测量仪器中,能承受极端温度下的重复弯曲。
6. 应用信息:适用于关键的生理和医疗应用,特别是在需要小直径、长弯曲寿命和无毒绝缘材料的地方。
7. 封装信息:提供了标准包装选项,如1000英尺、500英尺和100英尺,并有10种标准颜色可供选择。还提供了额外的股线结构选项。
2420/36GN-1000 价格&库存
很抱歉,暂时无法提供与“2420/36GN-1000”相匹配的价格&库存,您可以联系我们找货
