2451/30BK-1000
2451/30BK-1000
    DABURNELECTRONICS
    2451/30BK-1000
2451/30BK-1000 数据手册
Daflon Microminiature PTFE Hook-Up Wire Daflon Microminiature PTFE hook-up wire is chemically inert, weather resistant and nonflammable; it resists soldering irons and moisture; maintaining the benefits of PTFE wires, while in a tiny package. The Daflon microminiature series of ultra thin walled PTFE insulation offers savings of space and weight for applications ranging from medical, aircraft, missile, space and compact electronic components. . Description: Single conductor stranded silver plated copper covered with multiple layers of PTFE insulation. This construction allows for a uniform, flexible, concentric, quality construction. Operating Temperature: -90°C to +250°C Voltage Rating: 300V. This series is RoHS compliant. Nom. Wall Nom. O.D. DAFLON Cat. No. AWG Strand IN. MM IN. MM 2451/38 38 7/46 .0019 0.048 .0089 0.218 2451/36 36 7/44 .0020 0.051 .0101 0.257 2451/34 34 7/42 .0027 0.069 .0129 0.328 2451/32 32 7/40 .0030 0.076 .0153 0.389 2451/30 30 7/38 .0034 0.086 .0188 0.478 Standard Put-Ups: 500 FT, 1,000 FT. Stock Colors: Black, Red, Green, White Additional colors are available to order. Additional Stranding (including solid conductors) are available. Note: Above items can be laminated into a flat ribbon cable and twisted into multi-conductor cables.
2451/30BK-1000
- 物料型号:Daflon Microminiature PTFE Hook-Up Wire - 器件简介:这种电线具有化学惰性、耐候性和不燃性,能够抵抗烙铁和湿气,同时保持PTFE电线的优点,并且体积小巧。 - 引脚分配:文档中没有提供引脚分配信息,因为它是关于电线的,而不是集成电路或其他有引脚的电子元件。 - 参数特性: - 描述:单根导体,由银镀铜线组成,外覆多层PTFE绝缘。 - 工作温度:-90°C至+250°C - 电压等级:300V - 符合RoHS标准 - 功能详解:文档中没有提供详细的功能解释,但提到了电线的构造允许其具有均匀、灵活、同心的质量构造。 - 应用信息:适用于医疗、航空、导弹、太空和紧凑电子元件等领域。 - 封装信息:提供了不同AWG尺寸的电线规格,包括美国线规、股线结构、标称壁厚、标称外径等。
2451/30BK-1000 价格&库存
很抱歉,暂时无法提供与“2451/30BK-1000”相匹配的价格&库存,您可以联系我们找货
