N053-024-RBGY
N053-024-RBGY
    TRIPPLITE
    24-PORT1URACK-MOUNT110-TYPEC
N053-024-RBGY 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 24-Port 1U Rack-Mount 110-Type Color-Coded Patch Panel, RJ45 Ethernet, 568B, Cat5/5e MODEL NUMBER: N053-024-RBGY Highlights ● 4 color-coded banks for convenient zone cabling ● Color-coded rear 110 connections for EIA/TIA 568A/B wiring ● Supports 22 to 26 AWG stranded and solid wire ● Ports numbered front and rear for easy ID of cable runs ● Mounts into 1U of EIA-standard 19 in. rack Package Includes Manages and organizes up to 24 input and output Cat5/5e network cable connections in just 1U of an EIA-standard 19 in. rack. Recommended for Ethernet, Fast Ethernet and Gigabit Ethernet network applications. Description The UL-approved N053-024-RBGY 24-Port 1U Rack-Mount 110-Type Color-Coded Patch Panel manages and organizes up to 24 input and output UTP Cat5/5e network cable connections in just 1U of an EIAstandard 19 in. rack. The 24 RJ45 ports are split into four banks of six ports each that are color-coded—red, blue, green and yellow—for easily identifiable zones. Rear 110 connections are also color-coded for convenient EIA/TIA 568A/B wiring. All ports are numbered front and rear for quick identification of connections. Recommended for Ethernet, Fast Ethernet and Gigabit Ethernet network applications, this durable metal patch panel supports 22 to 26 AWG stranded and solid wire. Features Manages and Organizes 24 UTP Cat5/5e Network Connections ● Recommended for Ethernet, Fast Ethernet and Gigabit Ethernet network applications ● Ports split into 4 color-coded banks of 6 ports each for convenient zone cabling ● Color-coded 110 connections for EIA/TIA 568A/B wiring ● Ports numbered front and rear for easy ID of cable runs ● Supports 22 to 26 AWG stranded and solid wire Reliable Construction and Easy Installation ● Mounts easily into 1U of EIA-standard 19 in. rack ● UL-approved and RoHS-compliant ● Durable metal construction ● Meets or exceeds EIA/TIA TSB-40 Cat5e connecting hardware specifications Specifications 1/2 ● N053-024-RBGY 24-Port 1U Rack-Mount 110-Type ColorCoded Patch Panel ● Mounting hardware ● Quick Start Guide 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332197467 Product Type Punchdown Technology Cat5/5e PHYSICAL Shipping Dimensions (hwd / in.) 3.90 x 2.90 x 21.90 Shipping Dimensions (hwd / cm) 9.91 x 7.37 x 55.63 Shipping Weight (lbs.) 1.50 Shipping Weight (kg) 0.68 CONNECTIONS Number of Ports 24 Side A - Connector 1 110 IDC Side B - Connector 1 RJ45 (FEMALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
N053-024-RBGY
物料型号:N053-024-RBGY
器件简介: - 该24口1U机架安装110型彩色编码配线板适用于管理并组织多达24个输入和输出的Cat5/5e网络电缆连接。 - 适用于以太网、快速以太网和千兆以太网网络应用。
引脚分配: - 24个RJ45端口被分成四个颜色编码的组,每组6个端口,颜色分别为红色、蓝色、绿色和黄色,便于识别不同的区域。 - 后部的110连接也进行了颜色编码,以方便EIA/TIA 568A/B接线。
参数特性: - 支持22至26 AWG的绞合和实心线。 - 所有端口前后都编号,方便快速识别连接。
功能详解: - 管理并组织24个UTP Cat5/5e网络连接。 - 端口分为4个颜色编码的组,便于区域布线。 - 110连接颜色编码,适配EIA/TIA 568A/B接线。 - 支持22至26 AWG的绞合和实心线。 - 端口前后编号,便于识别电缆运行。
应用信息: - 推荐用于以太网、快速以太网和千兆以太网网络应用。
封装信息: - 该配线板可以安装在1U的EIA标准19英寸机架中。 - 产品符合UL认证和RoHS合规性。 - 结构耐用,金属材质。 - 满足或超过EIA/TIA TSB-40 Cat5e连接硬件规格。
包装内容: - N053-024-RBGY 24口1U机架安装110型彩色编码配线板 - 安装硬件 - 快速入门指南
其他信息: - UPC代码:037332197467 - 产品类型:打线 - 技术:Cat5/5e - 运输尺寸:3.90x2.90x21.90英寸 / 9.91x7.37x55.63厘米 - 运输重量:1.50磅 / 0.68千克 - 端口数量:24 - Side A - 连接器1:110IDC - Side B - 连接器1:RJ45(FEMALE) - 产品保修期(全球):终身有限保修
N053-024-RBGY 价格&库存
很抱歉,暂时无法提供与“N053-024-RBGY”相匹配的价格&库存,您可以联系我们找货
