C3168.41.03
C3168.41.03
    GENERALCABLE
    CABLE 2COND 16AWG RED SHLD 1000'
C3168.41.03 数据手册
Electronics Fire Alarm/Life Safety Cable Mid-Capacitance, Shielded, Plenum NEC Type FPLP for Microprocessor-Controlled Systems Product Construction Conductor: • 18 thru 12 AWG fully annealed solid bare copper per ASTM B-3 Insulation: CATALOG NUMBER NOM. INSULATION THICKNESS NO. OF AWG COND. COND. SIZE STRAND INCHES mm NOM. JACKET THICKNESS INCHES mm NOMINAL O.D. INCHES mm NOMINAL CAP. * pF/ft A B C3167 2 18 Solid 0.014 0.36 0.015 0.38 0.172 4.37 31.0 56.0 C3170 4 18 Solid 0.014 0.36 0.015 0.38 0.202 5.13 28.0 50.0 C3168 2 16 Solid 0.016 0.41 0.015 0.38 0.203 5.16 33.0 59.0 C3171 4 16 Solid 0.016 0.41 0.015 0.38 0.238 6.05 29.0 53.0 C3172 2 14 Solid 0.018 0.46 0.020 0.51 0.247 6.27 35.0 63.0 C3173 4 14 Solid 0.018 0.46 0.020 0.51 0.289 7.34 30.0 56.0 C3174 2 12 Solid 0.020 0.51 0.020 0.51 0.289 7.34 38.0 68.0 C3175 4 12 Solid 0.020 0.51 0.020 0.51 0.340 8.64 33.0 60.0 *A - Capacitance between conductors *B - Capacitance between one conductor and other conductors connected to shield Color Code Chart NO. OF COND. 1 2 3 4 COLOR Black Red Brown Blue • Premium-grade, coIor-coded fluoropolymer • Color code: See chart below Shield: • 100% Flexfoil® aluminum/polyester foil, 25% overlap, minimum • Stranded tinned copper drain wire Jacket: • Premium-grade, red Flexguard® PVC • Temperature range: 0°C to +75°C • Includes ripcord Applications: • Addressable fire alarm systems • Fire alarm systems • Voice communications • Smoke detectors • Pull boxes • Suggested voltage rating: 300 volts Compliances: • NEC Article 760 Type FPLP (UL: 75°C, 300V) • California State Fire Marshall Approved • Designed to meet NFPA 262 and CSA FT-6 Steiner Tunnel Fire Tests for Plenum Applications Features: • Red PVC jacket for easy critical circuit identification Packaging: • Please contact Customer Service for packaging and color options 128
C3168.41.03 价格&库存
很抱歉,暂时无法提供与“C3168.41.03”相匹配的价格&库存,您可以联系我们找货
