SmartRack 12U Low-Profile Switch-Depth-Plus
Wall-Mount Small Rack Enclosure
Highlights
Maximum load capacity of 200
lbs (90.7 kgs)
MODEL NUMBER: SRW12UDP
Locking steel cabinet vented at
sides, front, top and bottom
Flow-through ventilation keeps
equipment cool
Secures 12U of 19 in. rack
equipment up to 20.5 in. deep
Mounts to wall or rolls on floor
(with optional SRCASTER)
Package Includes
SRW12UDP SmartRack 12U
Wall-Mount Rack Enclosure
Cabinet
Wall-mount cabinet secures and organizes 12U of 19-inch rack equipment in network closets, classrooms
and other locations with limited floor space. Houses network switches and patch panels up to 20.5 inches
(20) M6 screws
deep.
(20) M6 cage nuts
(20) M6 washers
The SRW12UDP SmartRack 12U Low-Profile Switch-Depth-Plus Wall-Mount Rack Enclosure Cabinet is
(20) 12-24 screws
designed to house EIA-standard 19-inch rack equipment in network wiring closets, retail locations,
(2) Keys
classrooms, back offices and other areas with limited floor space where you need equipment to be secure,
Owner’s manual
Description
organized and out of the way. Constructed from heavy-duty steel with a durable black powder-coated
finish, the cabinet has a maximum load capacity of 200 lbs (90.7 kgs).
To ensure your valuable equipment stays secure, the side panels and front door lock securely to help
prevent damage, tampering or theft. The front, top, bottom and removable side panels are vented, which
allows air to flow freely through the cabinet toand keep equipment cool. The reversible front door can
open left or right by rotating the cabinet 180° before mounting. Convenient top and bottom ports allow
easy cable routing through the cabinet.
The SRW12UDP comes fully assembled and ready to mount to the wall, or use Tripp Lite's optional
SRCASTER rolling caster kit to make it a mobile rack. Square and threaded mounting holes and
numbered rack spaces make equipment installation easy. The vertical mounting rails adjust in 7/8-inch
increments to accommodate equipment up to 20.5 inches deep, such as such as network switches and
patch panels.
Features
Saves Valuable Workspace
Perfect for network wiring closets, retail locations, classrooms, back offices and other areas with limited
floor space where you need equipment to be secure, organized and out of the way
1/3
Houses EIA-standard 19 in. rack equipment in 12U of space
Maximum load capacity of 200 lbs (90.7 kgs)
Keeps Important Equipment Secure
Side panels and front door lock securely to help prevent damage, tampering or theft
Vented panels allow generous airflow that keeps equipment cool
Rotate cabinet 180° before mounting to open reversible front door left or right
Convenient ports with removable covers allow cable routing through top and bottom
Easy Enclosure and Equipment Installation
Ships fully assembled for quick installation
Mounts to wall or rolls on floor with Tripp Lite's optional SRCASTER caster kit
Wall-mounting holes spaced 16 in. apart for standard wall stud placement
Vertical mounting rails adjust in 7/8 in. increments to accommodate equipment up to 20.5 in. deep, such
as network switches and patch panels
Rails support square-hole or 12-24 threaded-hole mounting
Rack spaces numbered for easy reference
Meets Payment Card Industry Standards
Provides physical equipment and media security required for PCI DSS (Payment Card Industry Data
Security Standard) compliance
Specifications
OVERVIEW
UPC Code
037332191472
Device Compatibility
Patch Panel; Network Switch; UPS
Rack Type
Enclosure
PHYSICAL
Color
Black
Maximum Device Depth (cm)
52.07
Maximum Device Depth (in.)
20.5
Maximum Device Depth (mm)
521
Minimum Device Depth (cm)
7.62
Minimum Device Depth (in.)
3
Minimum Device Depth (mm)
76
2/3
Cable Access Hole Measurement
(inches)
9.812 x 2.35 (l x w)
Rack Height
12U
Shipping Dimensions (hwd / cm)
75.49 x 73.02 x 67.49
Shipping Dimensions (hwd / in.)
29.72 x 28.75 x 26.57
Shipping Weight (kg)
25.85
Shipping Weight (lbs.)
57.00
Unit Dimensions (hwd / cm)
63,70 x 60,00 x 55,25
Unit Dimensions (hwd / in.)
25.08 x 23.62 x 21.75
Unit Weight (kg)
26.49
Unit Weight (lbs.)
58.4
Weight Capacity - Stationary (kg)
91
Weight Capacity - Stationary (lbs.)
200
Rack Depth
Shallow
Number of Vertical Mounting Rails
4
SPECIAL FEATURES
Grounding Lug
Front and Back door frames
STANDARDS & COMPLIANCE
Certifications
EIA-310-E; IP20 Protection Rating
Approvals
RoHS
WARRANTY
Product Warranty Period
(Worldwide)
5-year limited warranty
© 2021 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
3/3
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Tripp Lite:
SRW12UDP
很抱歉,暂时无法提供与“SRW12UDP”相匹配的价格&库存,您可以联系我们找货
