164LTCH0.B3.04
164LTCH0.B3.04
    GENERALCABLE
    CABLE 4COND 16AWG ORANGE
164LTCH0.B3.04 数据手册
LIGHTING CABLE Architectural lighting has evolved into an equally critical and complex integrated system within modern residential and commercial spaces. Lighting system cabling no longer consists of simple building wire. Instead, each system has its own unique requirements for power and signal distribution between the supplies and control panels. To provide individual system solutions, Sheer Wire lighting cables are produced in a variety of control, power, and hybrid designs to meet the unique requirements of each system type. By combining these application-specific designs with time saving features and premium materials, Sheer Wire lighting cables reliably control and simplify the wiring of complex lighting systems. LUTRON HOMEWORKS: POWER LUTRON HOMEWORKS: KEYPAD LUTRON HOMEWORKS: VAREO LUTRON GRAFIK EYE LUTRON SIVOIA VANTAGE CONTROL LITE TOUCH: CONTROL STATIONS LITE TOUCH: ENCLOSURES & MODULES Specialized Designs that Deliver Solutions Sheer Wire lighting cables are produced in a variety of specific designs to provide complete solutions for almost every type of residential lighting system. Meets or Exceeds Industry Standards Each cable type is designed to meet or exceed the required industry or manufacturer standards. Certified Specifications that Ensure Performance Each reel of cable is tested and verified to deliver consistent performance and ensure reliable cable interconnect systems. Premium Materials Sheer Wire’s innovate plastic and dielectric compounds deliver both exceptional physical and electrical properties such as low attenuation, flexibility, low friction when pulling, and flame retardancy. Time Saving Features Features such as easy-to-strip jackets, footage markers, and flexible packaging allow for quick and simplified installation. LIGHTING Lutron Homeworks: Power Lo w - lo s s Po w er C a b le fo r Lu tro n Sys tems 18 Gage Conductors Two and Four Conductor Versions Shielded with Drain Wire Color Striped for Easy Identification UL Rated for Permanent Installation Mechanical Specifications Part # # of Cond. Nominal OD Conductors (Type, DCR) 182LUTDS 2 .268" 18 AWG (7x26) Stranded BC, 6.0 6/Mft Insulation (Type, Wall Thick, Color Code, Capacitance) Shield DrainWire (Type, DCR) Jacket (Type, Color) UL Type Approx. Weight PVC, .015", Nylon, .005", 600 Volt, Black & Red, 39 pF/ft Between Conductors 100% Foil 20 AWG (7x28) Stranded TC, 10.2 6/Mft PVC, Blue with Pink Stripe TC SunlightResistant, Direct Burial 44 lbs/Mft PVC, .015", Nylon, .005", 600 Volt, Black, Red, White, Green, 39 pF/ft Between Conductors 100% Foil 20 AWG (7x28) Stranded TC, 10.2 6/Mft PVC, Blue with White Stripe TC SunlightResistant, Direct Burial 69 lbs/Mft Lutron Homeworks™ Power Cable: Two-conductor 184LUTDS 4 .314" 18 AWG (7x26) Stranded BC, 6.0 6/Mft Lutron Homeworks™ Power Cable: Four-conductor Lutron Homeworks: Keypad Da ta a n d Po w er C a b le fo r Lu tro n Keyp a d s 22 Gage Shielded Single-pair 18 Gage Power Conductors Low-loss PE Insulation Yellow Stripe for Easy Identification UL Rated for Permanent Installation Mechanical Specifications Part # Overall Diameter Communication Elements Conductors: 1 Pair 22 AWG (7x30) Stranded BC, 15.3 6/Mft 18/22KYP .253” Insulation: PE, .013”, White & Violet, 22 pF/ft Shield: 100% Foil with 24 AWG (7x32) TC Drain Power Elements Conductors: 1 Pair 18 AWG (16x30) Stranded BC 16.7 6/Mft Insulation: PVC, .015” Black & Red Jacket (Type, Color) UL Type Approx. Weight PVC, Blue with Yellow Stripe CL3 & CM 40 lbs/Mft Lutron Homeworks™ Keypad Cable 37 www.sheerwire.com LIGHTING Lutron Homeworks: Vareo Sin g le - p a ir C a b le fo r Lu tro n Va reo Dimm e r s 22 Gage Conductors Foil Shield with Drain Wire Orange Stripe for Easy Identification UL Rated for Permanent Installation Mechanical Specifications Part # # of Cond. Nominal OD Conductors (Type, DCR) 222LUTDS 1 .176" 22 AWG (7x30) Stranded BC, 15.3 6/Mft Insulation (Type, Wall Thick, Color Code, Capacitance ) PVC, .015”, Black & Red, 35 pF/ft Between Conductors Shield 100% Foil DrainWire (Type, DCR) Jacket (Type, Color) UL Type Approx. Weight 24 AWG (7x32) Stranded TC, 23.8 6/Mft PVC, Blue with Orange Stripe CL3, CM 19 lbs/Mft Lutron Homeworks™ Vareo Dimmer Cable Lutron Grafik Eye Da ta a n d Po w er C a b le fo r Lu tro n Gra fik Eye Sys tems 22 Gage Shielded Single-pair 18 or 12 Gage Power Conductors Ground Wire (12/22LGRX Only) Color Stripe for Easy Identification UL Rated for Permanent Installation Mechanical Specifications Part # Overall Diameter Communication Elements Conductors: 1 Pair 22 AWG (7x30) Stranded BC, 15.3 6/Mft 18/22GFE .253” Insulation: PE, .013”, White & Violet, 22 pF/ft Shield: 100% Foil with 24 AWG (7x32) TC Drain Power Elements Ground Elements Jacket (Type, Color) UL Type Approx. Weight Conductors: 1 Pair 18 AWG (16x30) Stranded BC, 6.7 6/Mft N/A PVC, Blue with Green Stripe CL3 & CM 40 lbs/Mft PVC, Blue with Blue Stripe CL3 & CM 85 lbs/Mft Insulation: PVC, .015”, Black & Red Lutron Grafik Eye™: 18 AWG Power Conductors Conductors: 1 Pair 22 AWG (7x30) Stranded BC, 15.3 6/Mft 12/22LGRX 38 .300” Insulation: PE, .013”, White & Violet, 22 pF/ft Shield: 100% Foil with 24 AWG (7x32) TC Drain Conductors: 1 Pair 12 AWG (19x25) Stranded BC, 1.8 6/Mft Conductors: 1 Cond. 18 AWG (7x26) Stranded BC, 6.0 6/Mft Insulation: PVC, .015”, Black & Red Insulation: PVC, .010”, Orange Lutron Grafik Eye™: 12 AWG Power Conductors with Ground Wire www.sheerwire.com LIGHTING Lutron Sivoia Multi-element Cable for Lutron QED Shading Systems 18 Gage Shielded Conductors 16 Gage Power Conductors Ground Wire Red Stripe for Easy Identification UL Rated for Permanent Installation Mechanical Specifications Overall Diameter Part # Communication Elements Conductors: 4 x 18 AWG (16x30) Stranded BC, 6.7 6/Mft 16/18SVA .380” Insulation: PE, .015”, Violet, Yellow, Gray, Blue, 17.5 pF/ft 100% Foil Shield with 20 AWG Drain Wire (10x30) TC Master Jacket (Type, Color) Power Elements Ground Elements Conductors: 2 x 16 AWG (26x30) Stranded BC, 4.0 6/Mft Conductors: 1 x 18 AWG (16x30) Stranded BC, PVC, Blue 6.7 6/Mft with Red Stripe Insulation: PVC, .015” Green/Yellow Insulation: PVC, .015” Red/White & Red UL Type Weight CL3 & CM 95 lbs/Mft Lutron Sivoia QED Cable Vantage Control Lo w - lo s s Po w er a n d Da ta C a b le f o r Van t a g e C o n t r o l S y s t e m s Low-loss 16 AWG Conductors Dual-layer Dielectric Power and Data are Transmitted Over a Single Pair Purple Jacket with Yellow Stripe for Easy Identification UL Rated for Permanent Installation Mechanical Specifications Part # # of Cond. Nominal OD Conductor (Type, DCR) 162VANT65 2 .285” 16 AWG (65x34) Stranded BC, 4.0 6/Mft Insulation (Type, Wall Thick, Color Code, Capacitance) PVC, .016” Nylon, .005”, Black & Red 25.7 pF/ft between conductors Jacket (Type, Color) UL Type Approx. Weight PVC, Violet with Yellow Stripe (UL) TC 600 volt or (UL) CL3 or CM 300 volt 46 lbs/Mft 16 AWG Vantage Control Cable 39 www.sheerwire.com LIGHTING Lite Touch: Control Stations Fo u r C o n d u c to r 1 6 Ga g e C a b le f o r L i t e To u c h S y s t e m s Four 16 Gage Conductors Orange Jacket for Easy Identification UL Rated for Permanent Installation Mechanical Specifications Insulation (Type, Wall Thick Color Code, Capacitance) Part # # of Cond. Nominal OD Conductors (Type, DCR) 164LTCH 4 .300” 16 AWG (65x34) Stranded BC, 4 6/Mft PVC, .015", Black, Blue, Red, White Jacket (Type, Color) UL Type Approx. Weight PVC, Orange CL3/PLTC 64 lbs/Mft Lite Touch: Control Station Cable Lite Touch: Enclosures & Modules Fo u r C o n d u c to r 2 2 Ga g e C a b le f o r L i t e To u c h S y s t e m s Four 22 Gage Conductors Foil Shield with Drain Wire UL Rated for Permanent Installation Mechanical Specifications Part # # of Cond. Nominal OD Conductors (Type, DCR) Insulation (Type, Wall Thick Color Code, Capacitance) 224SLTCH 4 .222" 22 AWG (7x30) Stranded BC, 15.3 6/Mft PVC, .015", Black, Red, White & Green 35 pF/ft between conductors Shield 100% Foil Drain Wire (Type, DCR) Jacket (Type, Color) UL Type Approx. Weight 24 AWG (7x32) Stranded BC, 23.8 6/Mft PVC, Green CL3 & CM 32 lbs/Mft Lite Touch: Enclosures & Modules Cable 40 www.sheerwire.com
164LTCH0.B3.04 价格&库存
很抱歉,暂时无法提供与“164LTCH0.B3.04”相匹配的价格&库存,您可以联系我们找货
