144NCAT0.A5.A6
144NCAT0.A5.A6
    GENERALCABLE
    CABLE 4COND 14AWG
144NCAT0.A5.A6 数据手册
NETWORK & AUTOMATION Smart homes require intelligent cable designs. The backbone of any high-speed data interconnect, network cables must meet an exceptionally high performance level to ensure that the system operates reliably and at full data-rates. Produced in a variety of specialized and general purpose designs, Sheer Wire network and automation cables deliver solutions for a multitude of cross-platform and manufacturer specific standards and systems. As with all other Sheer Wire cables, each cable features leading-edge designs and comprehensive quality verification to deliver the foundation and bandwidth required for leading-edge data and control system integration. AMX AXLINK TOUCH PANEL CONTROL TOUCH PANEL HYBRID ELAN VIA! KEYPAD & VOLUME CONTROL TOTAL HOME HYBRID CATEGORY 5E UTP CATEGORY 5E 360MHz UTP CATEGORY 6 UTP LOW-SKEW UTP MULTI-MODE BREAKOUT FIBER MULTI-MODE DISTRIBUTION FIBER SINGLE-MODE BREAKOUT FIBER SINGLE-MODE DISTRIBUTION FIBER Certified Specifications that Ensure Performance Each reel of cable is tested and verified to deliver consistent performance and ensure reliable cable interconnect systems. Extended Bandwidth for High Speed Data Applications Many types are offered with extended bandwidth ratings for high-speed data applications such as Gigabit Ethernet, video over twisted-pair, and other proprietary system formats. Specialized Designs that Deliver Solutions Sheer Wire automation and network cables are produced in a variety of specific designs to provide complete networking solutions for almost every type of residential control and data system. Meets or Exceeds Industry Standards Each cable type is designed to meet or exceed the required industry or manufacturer standards. Time Saving Features Features such as easy-to-strip jackets, footage markers, and flexible packaging allow for quick and simplified installation. NETWORK AMX AXLink & AUTOMATION Da ta a n d Po w er C a b le fo r AMX AXLin k Syst e m s 22 Gage Low-cap, Shielded Single-pair For AMX AXLink Systems Low-loss Foam Dielectric (Data Pair) 18 Gage Power Conductors UL Rated for Permanent Installation Mechanical Specifications # of Pairs Part # 18/22AXL 18/22AXLP Nominal Conductor OD 2 22 AWG .242” (One Power, (7x30) One Data) Stranded BC AXLink™ Control Cable 2 22 AWG .195” (One Power, (7x30) One Data) Stranded BC AXLink™ Control Cable: Plenum Data Insulation (Type, OD) Data Shield & Drain Power Conductors Power Insulation Overall Jacket UL Type Approx. Weight Foam PE, .022” Blue & White 100% Foil with 24 AWG (7x32) Stranded TC 18 AWG (7x26) Stranded BC PVC, .010” Red & Black PVC, Black CL3R, FT-4 41 lbs/Mft Foam FEP, .020” Blue & White 100% Foil with 24 AWG (7x32) Stranded TC 18 AWG (16x30) Stranded BC Plenum PVC, .009” Red & Black Plenum, PVC, Black CMP 29 lbs/Mft Electrical Specifications Data Pair Power Pair Part # Impedance Capacitance Conductor DCR Drain DCR Velocity of Propagation Capacitace Power Conductor DCR 18/22AXL 95 6 12.5 pF/ft between conductors 15.3 6/Mft 23.8 6/Mft 79% 31.7 pF/ft between conductors 6.0 6/Mft 18/22AXLP 95 6 12.5 pF/ft between conductors 15.3 6/Mft 23.8 6/Mft 82% 31.7 pF/ft between conductors 6.7 6/Mft Touch Panel Control Da ta a n d Po w er C a b le fo r To u c h Pan el Syst e m s 22 Gage Low-cap, Shielded Single-pair Low-loss Foam Dielectric (Data Pair) 18 Gage Power Conductors Yellow Stripe for Easy Identification UL Rated for Permanent Installation Mechanical Specifications Part # 18/22CRT 18/22CRTP # of Pairs Nominal Conductor OD Data Insulation (Type, OD) Data Shield & Drain Power Conductors Power Insulation Overall Jacket UL Type Approx. Weight 2 22 AWG .242” (One Power, (7x30) One Data) Stranded BC Touch Panel Control Cable Foam PE, .022” Blue & White 100% Foil with 24 AWG (7x32) Stranded TC 18 AWG (7x26) Stranded BC PVC, .010” Red & Black PVC, Blue with Yellow Stripe CL3R, FT-4 41 lbs/Mft 2 (One Power, One Data) Foam FEP, .020” Blue & White 100% Foil with 24 AWG (7x32) Stranded TC 18 AWG (16x30) Stranded BC Plenum PVC, .009” Red & Black Plenum, PVC, Blue with Yellow Stripe CMP 29 lbs/Mft .195” 22 AWG (7x30) Stranded BC Touch Panel Control Cable: Plenum Electrical Specifications Data Pair Part # Impedance Power Pair Capacitance Conductor DCR Drain DCR Velocity of Propagation Capacitace Power Conductor DCR 6.0 6/Mft 6.7 6/Mft 18/22CRT 95 6 12.5 pF/ft between conductors 15.3 6/Mft 23.8 6/Mft 79% 31.7 pF/ft between conductors 18/22CRTP 95 6 12.5 pF/ft between conductors 15.3 6/Mft 23.8 6/Mft 82% 31.7 pF/ft between conductors 29 www.sheerwire.com NETWORK & AUTOMATION Touch Panel Hybrid Hyb rid Da ta C a b les fo r To u c h Pan el Sy s t e m s Touch Panel Elements Cat5E Elements RG6Q Coax Elements (Optional) Common Outer Jacket for Easy Pulling UL Rated for Permanent Installation Mechanical Specifications Part # Control Elements (#, Color) Cat5E Elements (#, Color) RG6Q Elements (#, Color) Master Jacket (Type, Color) Overall Diameter UL Type Approx. Weight 18/22CCT 1, Teal with Yellow Stripe 1, White N/A PVC, Teal with Red Stripe .524” CL3/FT-4 98 lbs/Mft 18/22CCD 1, Teal with Yellow Stripe 2, One White, One Gray N/A PVC, Teal with Black Stripe .547” CL3/FT-4 130 lbs/Mft 18/22CCQ 1, Teal with Yellow Stripe 4, One White, One Green, One Gray, One Blue N/A PVC, Teal with White Stripe .652” CL3/FT-4 189 lbs/Mft 18/22CDC 1, Teal with Yellow Stripe 2, One White, One Gray 2, Black & White PVC, Teal with Orange Stripe .750” CL3/FT-4 177 lbs/Mft 18/22QM 1 1 (15ns/100m skew) N/A Dual-zip PVC, Teal .462” x .242” CL3/FT-4 70 lbs/Mft 18/22QMP 1 1 (15ns/100m skew) N/A Dual-zip Plenum PVC, Teal .385” x .195” CMP 66 lbs/Mft Touch Panel Control ELEMENT SPECIFICATIONS, See Page #29 (pn#18/22CRT) Cat5E ELEMENT SPECIFICATIONS, See Page #32 (pn#244CAT5E360 except on QM amd QMP Types) RG6Q ELEMENT SPECIFICATIONS, Consult Factory for Detailed Specifications (pn#181VQ6) Elan Via! C o a xia l a n d Da ta C a b le fo r Ela n Via ! S ys t e m s Cat5E Element RG59 Coax Element 18 Gage Power Conductors Common Outer Jacket with Color Stripe UL Riser Rated for Permanent Installation Mechanical Specifications Part # Cat5E Elements (#, Color) RG59 Elements (#, Color) Power Elements (#, Color) Master Jacket (Type, Color) Overall Diameter UL Type Approx. Weight 182R59C5 1, White 1, Black 2x18 AWG (7x26), Stranded BC, Black & Red 6.4 6/Mft PVC, Blue .467” CL3R FT-4 83 lbs/Mft Cat5E ELEMENT SPECIFICATIONS, See Page #32 (pn#244CAT5E360) RG59 ELEMENT SPECIFICATIONS, See Page #18 (pn#IR201V59) 30 www.sheerwire.com NETWORK Keypad & Volume Control & AUTOMATION Gen era l Pu rp o s e C a t5 E a n d A u d io Hyb rid Cabl e Cat5E Element Four Audio Conductors Common Outer Jacket with Color Stripe UL Rated for Permanent Installation Mechanical Specifications Part # Cat5E Elements (#, Color) 164NCAT 1, Gray 144NCAT Audio Conductors (#, Color, DCR, Capacitance) 4x16 AWG (65x34), Stranded BC, Black, Red, White, Green, 4.0 6/Mft, 48.4 pF/ft Keypad & Volume Control Cable: 16 Gage 4x14 AWG (105x34), Stranded BC, 1, Gray Black, Red, White, Green, 2.5 6/Mft, 40.5 pF/ft Keypad & Volume Control Cable: 14 Gage Master Jacket (Type, Color) Overall Diameter UL Type Approx. Weight PVC, Teal with Gray Stripe .388” CL3 & CM 93 lbs/Mft PVC, Blue with Gray Stripe .415” CL3 & CM 125 lbs/Mft Cat5E ELEMENT SPECIFICATIONS, See Page #32 (pn#244CAT5E360) Total Home Hybrid Hyb rid C a b le fo r Sma rt Ho me Video and Network Distribution Cat5E Elements RG6Q Coax Elements Multi-mode Fiber (Optional) Common Outer Jacket for Easy Pulling UL Rated for Permanent Installation Mechanical Specifications Part # Cat5E Elements (#, Color) RG6Q Elements (#, Color) Muli-mode Fiber Elements (#, Color) Master Jacket (Type, Color) Overall Diameter UL Type Approx. Weight DV5E6U02 1, Gray 1, Black N/A PVC, Blue .485” CMG/CMR 89 lbs/Mft DV5E6U03 2, Gray & White 1, Black N/A PVC, Blue .575” CMG/CMR 121 lbs/Mft DV5E6U04 2, Gray & White 2, Black & White N/A PVC, Blue .660” CMG/CMR 156 lbs/Mft 2, Black & White 1, (2 Fiber Distribution), Orange PVC, Blue .670” CMG/CMR 175 lbs/Mft DV5E6U04F 2, Gray & White Cat5E ELEMENT SPECIFICATIONS, See Page #32 ( pn#244CAT5E360) RG6Q ELEMENT SPECIFICATIONS, Consult Factory for Detailed Specifications (pn#181VQ6) Multi-mode Fiber ELEMENT SPECIFICATIONS, See Page #34 (pn#FMD2R) 31 www.sheerwire.com NETWORK & AUTOMATION Category 5e UTP TIA /EIA C a t5 e 1 0 0 MHz Fo u r- p a ir Netw o rk C a b le Precision Cat5e Electrical Characteristics 100MHz Bandwidth 24 Gage Solid Copper Conductors Meets or Exceeds TIA/EIA-568-B.2 Standards UL Rated for Permanent Installation Mechanical Specifications Part # # of Pairs Nominal OD Conductors Insulation Jacket UL Type Approx. Weight 244CAT5 4 .208” 24 AWG Solid BC Polyolefin PVC CMR/MPR 26 lbs/Mft 24 AWG Solid BC Plenum Thermoplastic Plenum PVC CMP 23.5 lbs/Mft Category 5e Four-pair 100MHz 244CAT5P 4 .180” Category 5e Four-pair 100MHz: Plenum Electrical Specifications DCR Max Part # DCR Unbal. Max Mutual Capac. Max Char. Imped. Prop. Delay (Skew) Max Vel. of Prop. (Non-plenum, Plenum) 17 pF/ft 100 6 45 ns/100m 68%, 72% Freq. (MHz) 244CAT5 244CAT5P 28.6 6 5% Standards Exceeds TIA/EIA-568-B.2Cat 5e, ISO/IEC 11801 0.772 1 4 8 10 16 20 25 31.25 62.5 100 Insertion Loss (dB/100m) 1.8 2.0 4.1 5.8 6.5 8.2 9.3 10.4 11.7 17.0 22.0 PSNEXT (dB) 64.0 62.3 53.3 48.8 47.3 44.3 42.8 41.3 39.9 35.4 32.3 PSACR (dB/100m) 62.2 60.3 49.2 43.0 40.8 36.1 33.5 30.9 28.2 18.4 10.3 PSELFEXT (dB/100m) 63.0 60.8 48.7 42.7 40.8 36.7 34.7 32.8 30.9 24.8 20.8 --- 19.0 20.8 21.7 22.0 22.0 22.0 21.3 20.6 18.5 17.1 RL (dB) Category 5E 360MHz UTP TIA /EIA C a t5 E 3 6 0 MHz Fo u r- p a ir Netw o rk C a b le Precision Cat5E Electrical Characteristics 360MHz Bandwidth 24 Gage Solid Copper Conductors Meets or Exceeds TIA/EIA-568-B.2 Standards UL Rated for Permanent Installation Mechanical Specifications Part # # of Pairs Nominal OD Conductors Insulation Jacket UL Type Approx. Weight 244CAT5E360 4 .210” 24 AWG Solid BC PE PVC CMR 27 lbs/Mft Plenum Thermoplastic Plenum PVC CMP 23.5 lbs/Mft Category 5E Four-pair 360MHz 244CAT5E360P 4 .180” 24 AWG Solid BC Category 5E Four-pair 360MHz: Plenum Electrical Specifications Part # DCR Max DCR Unbal. Max Mutual Capac. Max 5% 17 pF/ft Freq. (MHz) 244CAT5E360 Series 28.6 6 Char. Imped. Prop. Delay (Skew) Max Vel. of Prop. (Non-plenum, Plenum) 18 ns/100m 100 6 Standards Exceeds TIA/EIA-568-B.2 Cat 5e, ISO/IEC 11801 69%, 72% 0.772 1 4 8 10 16 20 25 31.25 62.5 100 155 200 250 300 360 Insertion Loss (dB/100m) 1.8 2.0 4.1 5.8 6.5 8.2 9.3 10.4 11.7 17.0 22.0 28.1 32.4 36.9 41.0 45.6 PSNEXT (dB) 70.0 68.3 59.3 54.8 53.3 50.3 48.8 47.3 45.9 41.4 38.3 35.5 33.8 32.3 31.2 30.0 PSACR (dB/100m) 68.2 66.3 55.2 49.0 46.8 42.1 39.5 36.9 34.2 24.4 16.3 7.4 1.4 -4.6 -9.8 -15.6 PSELFEXT (dB/100m) 63.0 60.8 48.7 42.7 40.8 36.7 34.7 32.8 30.9 24.8 20.8 16.9 14.7 12.8 11.2 9.6 --- 20.0 23.0 24.5 25.0 25.0 25.0 24.3 23.6 21.5 20.1 18.8 18.0 17.3 16.8 16.2 RL (dB) 32 www.sheerwire.com NETWORK Category 6 UTP & AUTOMATION TIA/EIA C a t6 2 5 0 MHz Fo u r- p a ir Netw o rk C a b le Precision Cat6 Electrical Characteristics 250MHz Bandwidth 23 Gage Solid Copper Conductors Meets or Exceeds TIA/EIA-568-B.2 Standards UL Rated for Permanent Installation Mechanical Specifications Part # # of Pairs Nominal OD Conductors Insulation Jacket UL Type Approx. Weight 234CAT6 4 .240” 23 AWG Solid BC Polyolefin PVC with Central Spacer CMR/MPR 27 lbs/Mft 23 AWG Solid BC Plenum Thermoplastic Plenum PVC with Central Spacer CMP 28 lbs/Mft Category 6 Four-pair 250MHz 234CAT6P 4 .220” Category 6 Four-pair 250MHz: Plenum Electrical Specifications DCR Max Part # DCR Unbal. Max Mutual Capac. Max Char. Imped. Prop. Delay (Skew) Max Vel. of Prop. (Non-plenum, Plenum) 17 pF/ft 100 6 18 ns/100m 69%, 72% Freq. (MHz) 234CAT6 234CAT6P 3% 28.6 6 Standards Meets or Exceeds TIA/EIA-568-B.2-1 Cat 6, ISO/IEC 11801 0.772 1 4 8 10 16 20 25 31.25 62.5 100 155 200 250 Insertion Loss (dB/100m) 1.8 2.0 3.8 5.3 6.0 7.6 8.5 9.5 10.7 15.4 19.8 25.2 29.0 32.8 PSNEXT (dB) 74.0 72.3 63.3 58.8 57.3 54.3 52.8 51.3 49.9 45.4 42.3 39.5 37.8 36.3 PSACR (dB/100m) 72.2 70.3 59.5 53.5 51.3 46.7 44.3 41.8 39.2 30.0 22.5 14.3 8.8 3.5 PSELFEXT (dB/100m) 67.0 61.8 52.7 46.7 44.8 40.7 38.7 36.8 34.9 28.8 24.8 20.9 18.7 16.8 --- 20.0 23.0 24.5 25.0 25.0 25.0 24.3 23.6 21.5 20.1 18.8 18.0 17.3 RL (dB) Low-skew UTP Fo u r- p a ir C a b le fo r A n a lo g Vid eo Tra n s mis s i o n Low 2ns Skew For RGB Analog Video Transmission 23 Gage Solid Copper Conductors Cost Effective UL Rated for Permanent Installation Mechanical Specifications Part # # of Pairs Nominal OD Conductors Insulation Jacket UL Type Approx. Weight 234ULS 4 .228” 23 AWG Solid BC Polyethylene PVC CMR 24 lbs/Mft 23 AWG Solid BC Plenum Thermoplastic Plenum PVC CMP 25 lbs/Mft Low Skew Four-pair UTP: Riser 234ULSP 4 .228” Low Skew Four-pair UTP: Plenum Electrical Specifications Part # 234ULS 234ULSP DCR Max DCR Unbal. Max 28.6 6 5% Mutual Capac. Max Char. Imped. Prop. Delay (Skew) Max 17 pF/ft 100 6 2.0 ns/100m Freq. (MHz) Insertion Loss (dB/100m) Vel. of Prop. (Non-plenum, Plenum) 69%, 72% 0.772 1 4 8 10 16 20 25 31.25 62.5 100 1.7 1.9 3.9 5.5 6.2 7.9 8.9 10.0 11.3 16.3 21.2 33 www.sheerwire.com NETWORK & AUTOMATION Multi-mode Breakout Fiber In d o o r/O u td o o r Brea ko u t O p tic a l Fib er Distribution Type Construction 62.5 Multi-mode Fiber Elements Individual Kevlar Fillers and Tube Jackets for Additional Strength Overall Jacket UL Rated for Permanent Installation Fiber Specifications Type Mode Field Diameter Cladding Diameter Maximum Attenuation Multi-mode 62.5 μ 125 μ 3.50 dB/km @ 850nm/1.00db/km @1300nm Mechanical Specifications Maximum Tension Part # FMB**R *=Number of Elements Minimum Bend Radius Operating Installation (Pulling) Operating Maximum Vertical Rise Approx. Weight UL Type lbs lbs lbs lbs lbs 112 250 250 250 270 lbs lbs lbs lbs lbs 2” 6.5” 7.54” 8.9” 11.34” 1.0” 3.3” 3.8” 4.5” 5.7” 11,200’ 5000’ 3509’ 2564’ 2097’ 8 lbs/Mft 40 lbs/Mft 57 lbs/Mft 78 lbs/Mft 129 lbs/Mft OFNR OFN FT4 lbs lbs lbs lbs lbs 112 250 250 250 270 lbs lbs lbs lbs lbs 2” 5.44” 6.46” 8.0” 10.46” 11,200’ 6667’ 4545’ 3077’ 1728’ 8 lbs/Mft 30 lbs/Mft 44 lbs/Mft 65 lbs/Mft 125 lbs/Mft OFNP OFN FT6 Fiber Buffer Outer Jacket Number of Elements Nominal OD Installation (Pulling) PVC Tight Buffer Coating ( .9mm OD) with Kevlar Filler & PVC Tube Jacket (2.5mm OD) PVC (Orange) 2 (Duplex) 4 6 8 12 .113”x.241” .325” .377” .445” .567” 225 450 600 600 788 2 (Duplex) 4 6 8 12 .113”x.241” .272” .323” .400” .523” 225 450 600 600 788 Multi-mode Breakout Fiber: Riser Rated FMB**P *=Number of Elements Plenum PVC Tight Buffer Plenum Coating ( .9mm OD) with PVC Kevlar Filler & PVC Tube (Orange) Jacket (2.5mm OD) 1.0” 2.7” 3.2” 4.0” 5.2” Multi-mode Breakout Fiber: Plenum Rated Multi-mode Distribution Fiber Indoor/Outdoor Distribution Optical Fiber Distribution Type Construction 62.5 Multi-mode Fiber Elements Kevlar Filler for Strength Overall Jacket UL Rated for Permanent Installation Fiber Specifications Type Mode Field Diameter Cladding Diameter Maximum Attenuation Multi-mode 62.5 μ 125 μ 3.50 dB/km @ 850nm/1.00db/km @1300nm Mechanical Specifications Maximum Tension Part # FMD**R *=Number of Elements Fiber Buffer Outer Jacket Number of Elements Nominal OD Installation (Pulling) PVC Tight Buffer Coating with Overall Kevlar Filler ( .9mm OD) PVC (Orange) 2 4 6 8 12 .187” .220” .235” .245” .275” 180 225 225 315 405 .150” .180” .195” .205” .215” 180 225 225 315 405 Minimum Bend Radius Operating Maximum Vertical Rise Approx. Weight UL Type 3.74” 4.4” 4.7” 4.9” 5.5” 1.9” 2.2” 2.4” 2.5” 2.8” 2987’ 3832’ 3467’ 3617’ 3600’ 15 19 21 23 30 lbs/Mft lbs/Mft lbs/Mft lbs/Mft lbs/Mft OFNR OFN FT4 3” 3.6” 3.9” 4.1” 4.5” 1.5” 1.8” 2.0” 2.1” 2.3” 4978’ 5200’ 4853’ 4622’ 4909’ 9 lbs/Mft 14 lbs/Mft 15 lbs/Mft 18 lbs/Mft 22 lbs/Mft OFNP OFN FT6 Operating Installation (Pulling) lbs lbs lbs lbs lbs 56 lbs 91 lbs 91 lbs 104 lbs 135 lbs lbs lbs lbs lbs lbs 56 lbs 91 lbs 91 lbs 104 lbs 135 lbs Multi-mode Distirbution Fiber: Riser Rated FMD**P *=Number of Elements 34 Plenum PVC Tight Buffer Coating with Overall Kevlar Filler ( .9mm OD) Plenum PVC (Orange) 2 4 6 8 12 Multi-mode Distribution Fiber: Plenum Rated www.sheerwire.com NETWORK Single-mode Breakout Fiber & AUTOMATION In d o o r/O u td o o r Brea ko u t O p tic a l Fib er Breakout Type Construction 8.3m Single-mode Fiber Elements Individual Kevlar Fillers and Tube Jackets for Added Strength Overall Jacket UL Rated for Permanent Installation Fiber Specifications Type Mode Field Diameter Cladding Diameter Maximum Attenuation Single Mode 8.3 μ 125 μ d0.70 dB/km @ 1310/1550nm Mechanical Specifications Maximum Tension Part # FSB**R *=Number of Elements Minimum Bend Radius Operating Installation (Pulling) Operating Maximum Vertical Rise Approx. Weight UL Type lbs lbs lbs lbs lbs 112 250 250 250 270 lbs lbs lbs lbs lbs 2” 6.5” 7.54” 8.9” 11.34” 1.0” 3.3” 3.8” 4.5” 5.7” 11,200’ 5000’ 3509’ 2564’ 2097’ 8 lbs/Mft 40 lbs/Mft 57 lbs/Mft 78 lbs/Mft 129 lbs/Mft OFNR OFN FT4 lbs lbs lbs lbs lbs 112 250 250 250 270 lbs lbs lbs lbs lbs 2” 5.44” 6.46” 8.0” 10.46” 11,200’ 6667’ 4545’ 3077’ 1728’ 8 lbs/Mft 30 lbs/Mft 44 lbs/Mft 65 lbs/Mft 125 lbs/Mft OFNP OFN FT6 Fiber Buffer Outer Jacket Number of Elements Nominal OD Installation (Pulling) PVC Tight Buffer Coating ( .9mm OD) with Kevlar Filler & PVC Tube Jacket (2.5mm OD) PVC (Yellow) 2 (Duplex) 4 6 8 12 .113”x.241” .325” .377” .445” .567” 225 450 600 600 788 .113”x.241” .272” .323” .400” .523” 225 450 600 600 788 Single-mode Breakout Fiber: Riser Rated FSB**P *=Number of Elements Plenum PVC Tight Buffer Plenum Coating ( .9mm OD) with PVC Kevlar Filler & PVC Tube (Yellow) Jacket (2.5mm OD) 2 (Duplex) 4 6 8 12 1.0” 2.7” 3.2” 4.0” 5.2” Single-mode Breakout Fiber: Plenum Rated Single-mode Distribution Fiber Indoor/Outdoor Distribution Optical Fiber Distribution Type Construction 8.3m Single-mode Fiber Elements Kevlar Filler for Strength Overall Jacket UL Rated for Permanent Installation Fiber Specifications Type Mode Field Diameter Cladding Diameter Maximum Attenuation Single Mode 8.3 μ 125 μ d0.70 dB/km @ 1310/1550nm Mechanical Specifications Maximum Tension Part # FSD**R *=Number of Elements Fiber Buffer Outer Jacket Number of Elements Nominal OD Installation (Pulling) PVC Tight Buffer Coating with Overall Kevlar Filler ( .9mm OD) PVC (Yellow) 2 4 6 8 12 .187” .220” .235” .245” .275” 180 225 225 315 405 .150” .180” .195” .205” .215” 180 225 225 315 405 Minimum Bend Radius Operating Maximum Vertical Rise Approx. Weight UL Type 3.74” 4.4” 4.7” 4.9” 5.5” 1.9” 2.2” 2.4” 2.5” 2.8” 2987’ 3832’ 3467’ 3617’ 3600’ 15 19 21 23 30 lbs/Mft lbs/Mft lbs/Mft lbs/Mft lbs/Mft OFNR OFN FT4 3” 3.6” 3.9” 4.1” 4.5” 1.5” 1.8” 2.0” 2.1” 2.3” 4978’ 5200’ 4853’ 4622’ 4909’ 9 lbs/Mft 14 lbs/Mft 15 lbs/Mft 18 lbs/Mft 22 lbs/Mft OFNP OFN FT6 Operating Installation (Pulling) lbs lbs lbs lbs lbs 56 lbs 91 lbs 91 lbs 104 lbs 135 lbs lbs lbs lbs lbs lbs 56 lbs 91 lbs 91 lbs 104 lbs 135 lbs Single-mode Distribution Fiber: Riser Rated FSD**P *=Number of Elements Plenum PVC Tight Buffer Coating with Overall Kevlar Filler ( .9mm OD) Plenum PVC (Yellow) 2 4 6 8 12 Single-mode Distribution Fiber: Plenum Rated www.sheerwire.com 35
144NCAT0.A5.A6 价格&库存
很抱歉,暂时无法提供与“144NCAT0.A5.A6”相匹配的价格&库存,您可以联系我们找货
