C6061A.38.01
C6061A.38.01
    GENERALCABLE
    CABLE 3COND 20AWG BLK SHLD 500'
C6061A.38.01 数据手册
Audio/Video & Home Entertainment Cable Electronics Direct Burial, Audio & Communication Product Construction: Conductor: • 20 AWG fully annealed stranded tinned copper per ASTM B-33 • Twisted pairs Insulation: • Premium-grade, coIor-coded polypropylene • Color code: See chart below Shield: • 100% Flexfoil® aluminum/polyester with 25% overlap, minimum, foil facing in • Stranded tinned copper drain wire each pair • Individually shielded pairs Jacket: • Permaline® high-density polyethylene, black • Temperature range: ‑20°C to +80°C Applications: • Suitable for direct burial • Outdoor uses • Applications where total isolation of signal is required • Suggested voltage rating: 350 volts Features: • Permaline® jackets resist deterioration • Sunlight-resistant Compliances: • RoHS Compliant Directive 2002/95/EC Packaging: • Please contact Customer Service for packaging and color options 165 NOM. INSULATION NOM. JACKET THICKNESS THICKNESS CATALOG NO. OF AWG COND. NUMBER PAIRS SIZE STRAND INCHES mm INCHES mm NOMINAL O.D. INCHES mm C6061A 3 20 10/30 0.013 0.33 0.047 1.19 0.340 8.64 22.0 39.0 C6062A 6 20 10/30 0.013 0.33 0.047 1.19 0.442 11.23 22.0 39.0 *A – Capacitance between conductors *B – Capacitance between one conductor and other conductors connected to shield Color Code Chart NO. OF PAIRS 1 2 3 4 5 6 COLOR Black Black Black Black Black Black paired paired paired paired paired paired with with with with with with Red White Green Blue Yellow Brown NOM. CAP.* pF/ft A B
C6061A.38.01 价格&库存
很抱歉,暂时无法提供与“C6061A.38.01”相匹配的价格&库存,您可以联系我们找货
