C1606.38.01
C1606.38.01
    GENERALCABLE
    CABLE 6COND 16AWG BLK SHLD 500'
C1606.38.01 数据手册
Electronics Communication & Control Cable, Multi-Conductor The multi-conductor array of communication and control cable facilitates cable pull-ins and single-site installations. This cable is typically used for industrial equipment control, electric valve actuation and remote signaling, as well as communications and broadcast applications. These designs are available in a wide variety of insulation and jacketing materials, as well as shield designs to alleviate unwanted circuit noise. General Cable’s Carol® Brand products are manufactured to meet the latest UL, CSA and NEC requirements and approvals. A Design To Meet Every Application PVC/PVC designs employ polyvinyl chloride insulations and jackets capable of meeting everyday, general purpose applications. PE or PP/PVC designs employ high quality polyethylene or polypropylene insulations to assure faithful reproduction of transmitted signals across interconnection circuits. 8 Foamed PP/PVC designs use high speed, foamed polypropylene insulations for long distance, critical circuits, which would not perform if higher loss insulations were employed. Rubber/Rubber is typically employed in installations characterized as severely hostile environments, where these designs provide unsurpassed service life. Rubber/Carolprene® offers the ultimate performance for applications that demand the greatest protection from the environment, including physical abuse. The specially formulated Carolprene® jacket has been proven time and again to withstand all types of abuse, both mechanical and chemical. 2 Index Page ____________________________________ Multi-Conductor, Unshielded 9-14 ____________________________________ Power-Limited Tray Cable, Unshielded 15 ____________________________________ Multi-Conductor, Rubber, Unshielded 16 ____________________________________ Multi-Conductor, Foil Shield 17-19 ____________________________________ Power-Limited Tray Cable, Foil Shield 20 ____________________________________ Multi-Conductor, Spiral Shield 21 ____________________________________ Multi-Conductor, Braid Shield 22-25 ____________________________________ Multi-Conductor, Foil/Braid Shield 26 ____________________________________ Multi-Conductor, Rubber, Braid Shield 27 ____________________________________ Multi-Conductor, Carolprene,® Braid Shield 28 ____________________________________ Communication & Control Cable, Multi-Conductor Electronics Multi-Conductor, Carolprene®, Braid Shield Product Construction: Conductor: sTHRU!7'FULLYANNEALEDSTRANDED tinned copper per ASTM B-33 Insulation: s0REMIUM GRADE CO)OR CODEDRUBBER s#OLOR#ODE3EECHARTBELOW Shield: sTINNEDCOPPERBRAID Jacket: CATALOG NO. OF NUMBER COND. AWG SIZE COND. STRAND NOM. INSULATION THICKNESS INCHES mm NOM. JACKET THICKNESS INCHES mm NOMINAL O.D. INCHES mm C1202 2 18 41/34 0.020 0.51 0.035 0.89 0.295 7.49 C1203 C1204 C1206 3 18 41/34 0.020 0.51 0.035 0.89 0.305 7.75 4 18 41/34 0.020 0.51 0.035 0.89 0.330 8.38 6 18 41/34 0.020 0.51 0.035 0.89 0.370 9.39 C1208 8 18 41/34 0.020 0.51 0.035 0.89 0.420 10.67 C1210 C1212 10 18 41/34 0.020 0.51 0.035 0.89 0.425 10.80 12 18 41/34 0.020 0.51 0.065 1.65 0.555 14.10 2 16 65/34 0.025 0.64 0.035 0.89 0.335 8.51 3 16 65/34 0.025 0.64 0.035 0.89 0.355 9.02 4 16 65/34 0.025 0.64 0.035 0.89 0.385 9.78 6 16 65/34 0.025 0.64 0.040 1.02 0.445 11.30 8 16 65/34 0.025 0.64 0.040 1.02 0.510 12.95 s2O(3#OMPLIANT$IRECTIVE%# C1602 C1603 C1604 C1606 C1608 C1612 2 14 41/30 0.030 0.76 0.040 1.02 0.395 10.03 Packaging: C1614 4 14 41/30 0.030 0.76 0.040 1.02 0.455 11.56 s#AROLPRENE®, black s4EMPERATURE2ANGE ª#TO ª# Applications: s#ONTROLCIRCUITS s"ROADCASTANDSTUDIOAPPLICATIONS s!UDIOINTERCONNECTS s3UGGESTEDVOLTAGERATINGVOLTS Features: s)MPACT ANDABRASION RESISTANT s3TRANDEDCONDUCTORSFORSUPERIOR FLEXIBILITY s$ESIGNEDTOMEET5,67 6ERTICAL7IRE Flame Test Compliance: s0LEASECONTACT#USTOMER3ERVICEFOR packaging and color options Color Code Chart NO. OF COND. 1 2 3 4 5 6 28 COLOR Black 7HITE Red Green Blue Brown NO. OF COND. 7 8 9 10 11 12 COLOR Yellow Orange Gray 6IOLET 7HITE"LACK 7HITE2ED
C1606.38.01 价格&库存
很抱歉,暂时无法提供与“C1606.38.01”相匹配的价格&库存,您可以联系我们找货
