PAM1402CL005
PAM1402CL005
    ALPHAWIRE(阿尔法电线)
    CABLE2COND14AWGCLEAR100'
PAM1402CL005 数据手册
Dearborn™ Marine Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 425 Dearborn™ Marine The Premier Choice for Marine Applications F or tough, seaworthy wire and cable, Alpha Wire’s Dearborn brand of products delivers performance in the most challenging environments for electrical components and electronic systems, with the ever-present potential for corrosion and other harmful effects from moisture, salt, oil, and gases. Whether you are building new pleasure or commercial watercraft or maintaining existing boats, our marine products will satisfy your most stringent requirements. Complete line for every marine application From wiring of engines, batteries, and bilge pumps to cables for communications, instrumentation, and electronics, you will find the exact wire or cable you need. Cables are color-coded to meet boating industry standards. Marine wire High-grade marine wire for the full spectrum of marine applications, including wiring of engines, batteries, and bilge pumps. 426 Marine cable Designed to perform A complete line of multiconductor cables, designed specifically for marine environments. Ideally suited for multiple applications, including communications, instrumentation, and electronics. Dearborn marine wire and cable use corrosion-resistant annealed tinned copper conductors with Type 3 marine stranding for extra flexibility and service life. A choice of round or flat multiconductor cables means easier handling and routing. Marine heat-shrink tubing To protect cable terminations and provide a watertight connection, we offer marine grade heatshrink tubing with an operating temperature range of –55°C to +130°C for protecting electrical connections, and spiral wrap and split ducts for managing and organizing wires and cables. Marine ready Our cables meet various specifications to ensure regulatory compliance and seaworthiness: • R  ugged PVC insulation and jackets, rated to 105°C • Easy circuit identification with color-coded conductors • Shielded cable available for EMI protection • UL VW-1 flame retardant • Convenient, easy to use packaging in lengths as low as 50 feet • Resistant to oil, chemicals, solvents, and sea water • Premium high-performance with tinned conductors • U  L Standard 1426: Electrical Cable for Boats • SAE J378: Marine Propulsion Systems Wiring • SAE J1127: Low-Voltage Battery Cables • SAE J1128: Low-Voltage Primary Cables • ABYC E-11-2008: Standard for AC and DC Electrical Systems on Boats • ABYC E-10-2006: Storage Batteries • USCG: Title 33, CFR 183 Subpart I, Section 183 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. The Premier Choice for Marine Applications Application Configuration No. of Conductors Wire Gauge Range Features Engine wiring Battery Speaker cable Flat (parallel) or round Round Round 1–3 1 1 18 – 6 8 – 4/0 22 – 14 Bonding cable Round 1 6–4 Telephone cable Communications and control RFI shielded cable Duplex shielded cable Round Round Round Round 2–3 2–7 2–3 2 22 18 – 16 18 – 14 16 – 10 Bilge pump Round 3 18 – 14 Trailer cable Flat (parallel) or round 3–4 16 – 12 Color-coded with white jackets Extra flexible stranding Ripcord construction Resists oil, fungus, chemicals, and heat Retards electrolytic corrosion High-density polyethylene insulation Shielded and unshielded Foil shield, 100% coverage Foil + braid for maximum shielding Water-resistant construction Resistant to gasoline, oils, solvents, and salt water See-through insulation for easier installation Required Marine Wiring Color Codes Direct Current Systems, Under 50 Volts Color Use Green White or Black Red Bonding Return, negative main Positive mains, particularly unfused Notes: ( 1) The colors shall be reserved for the uses as indicated, only. (2) When the color (White or Black) is selected for the negative side of the system, it shall be used throughout the system to the exclusion of the other color. Recommended Marine Wiring Color Codes Direct Current Systems, Under 50 Volts Color Item Use Yellow w/Red Stripe Starting circuit Generator or alternator field Bilge blowers Navigation lights Tachometer Generator armature Alternator charge light Pumps Accessory feed Accessory common feed Ignition Instrument feed Cabin and instrument lights Oil pressure Water temperature Fuel gauge Starting switch to solenoid Generator or alternator field to regulator field Terminal fuse or switch to blowers Fuse or switch to lights Tachometer sender to gauge Generator armature to regulator Generator terminal or alternator auxiliary terminal to light to regulator Fuse or switch to pumps Ammeter to alternator or generator output and accessory fuses or switches Distribution panel to accessory switch Ignition switch to coil and electrical instruments Distribution panel to electric instruments Fuse or switch to lights Sender to gauge Water temperature sender to gauge Fuel gauge sender to gauge Yellow Dark Gray Brown Orange Purple Dark Blue Light Blue Tan Pink Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 427 Wire > Dearborn Marine Wire > 50 V Dearborn™ Marine Wire 50 V Standard-Grade Primary Wire Part No. SAE J1128 Type GPT SAE J378B PWM1816 PWM1619 PWM1419 PWM1219 PWM1019 PWM0819 PWM0619 Wire Size AWG 18 16 14 12 10 8 6 mm2 0.81 1.23 1.94 3.08 4.92 7.82 12.4 Stranding AWG 16/30 19/29 19/27 19/25 19/23 19/21 19/19 mm 16 x 0.25 19 x 0.29 19 x 0.36 19 x 0.46 19 x 0.57 19 x 0.72 19 x 0.91 Insulation Thickness Inch mm 0.023 0.58 0.023 0.58 0.023 0.58 0.026 0.66 0.034 0.86 0.037 0.94 0.043 1.09 Nominal Diameter Inch mm 0.093 2.36 0.103 2.62 0.117 2.97 0.142 3.61 0.176 4.47 0.216 5.49 0.337 8.56 Operating Temperature • -40°C to +105°C Insulation Color Coding • B  lack, red, orange, yellow, green, blue, violet, white, brown, slate Materials • S  tranded bare copper conductors • PVC insulation Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) 428 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Wire > Dearborn Marine Wire > 600 V Dearborn™ Marine Wire 600 V Premier Battery Wire Part No. UL AWM 1283 VW-1 UL BC-5W2 UL Oil Res 1 CSA AWM I A/B FT1 CSA TEW-105 ABYC Coast Guard SAE J378B, J1127 Type SGT (50 V) PBM0830 PBM0630 PBM0430 PBM0230 PBM0130 PBM0001 PBM0002 PBM0003 PBM0004 Wire Size AWG 8 6 4 2 1 1/0 2/0 3/0 4/0 mm2 8.51 13.5 21.3 33.7 42.4 53.9 67.0 84.4 107 Insulation Thickness AWG mm Inch mm 168/30 (7 x 24) 168 x 0.25 0.060 1.52 266/30 (7 x 38) 266 x 0.25 0.060 1.52 420/30 (7 x 60) 420 x 0.25 0.065 1.65 665/30 (7 x 95) 665 x 0.25 0.065 1.65 836/30 (19 x 44) 836 x 0.25 0.082 2.08 1064/30 (19 x 56) 1064 x 0.25 0.082 2.08 1323/30 (7 x 7 x 27) 1323 x 0.25 0.082 2.08 1666/30 (7 x 7 x 34) 1666 x 0.25 0.082 2.08 2109/30 (37 x 57) 2109 x 0.25 0.082 2.08 Stranding Nominal Diameter Inch mm 0.294 7.47 0.339 8.61 0.404 10.26 0.471 11.96 0.529 13.44 0.570 14.48 0.648 16.46 0.659 16.74 0.760 19.30 Operating Temperature • -20°C to +105°C Insulation Color Coding • W  hite, black, red, green, yellow, blue, brown, orange, slate, violet Materials • C  orrosion-resistant stranded tinned copper conductors • PVC insulation Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) (Minimums may apply) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 429 Wire > Dearborn Marine Wire > 600 V Dearborn™ Marine Wire 600 V Premier Primary Wire Part No. UL AWM 1015 VW-1 UL AWM 1230 UL Oil Res. 1 UL BC-5W2 CSA AWM I A/B FT1 CSA TEW-105 SAE J1128 Type GPT SAE J378B ABYC Coast Guard PPM1830 PPM1630 PPM1430 PPM1230 PPM1030 PPM0830 Wire Size AWG 18 16 14 12 10 8 Stranding mm2 0.81 1.32 2.08 3.29 5.32 8.51 AWG 16/30 26/30 41/30 65/30 105/30 168/30 (7 x 24) mm 16 x 0.25 26 x 0.25 41 x 0.25 65 x 0.25 105 x 0.25 168 x 0.25 Insulation Thickness Inch mm 0.031 0.79 0.031 0.79 0.031 0.79 0.032 0.81 0.032 0.81 0.032 0.81 Nominal Diameter Inch mm 0.109 2.77 0.122 3.10 0.136 3.45 0.152 3.86 0.185 4.67 0.232 5.89 Operating Temperature • -20°C to +105°C Insulation Color Coding • W  hite, black, red, green, yellow, blue, brown, orange, slate, violet Materials • C  orrosion-resistant stranded tinned copper conductors • PVC insulation Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) (Minimums may apply) 430 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Wire > Dearborn Marine Wire > 600 V Dearborn™ Marine Wire 600 V Bonding Marine Wire Part No. PGM0849 PGM0649 PGM0449 Wire Size AWG 8 6 4 mm2 8.42 13.3 21.2 Stranding AWG 49/0.0184 (7 x 7) 49/0.0231 (7 x 7) 49/0.0292 (7 x 7) mm 49 x 0.47 49 x 0.59 49 x 0.74 Insulation Thickness Inch mm 0.060 1.52 0.060 1.52 0.065 1.65 Nominal Diameter Inch mm 0.286 7.26 0.328 8.33 0.393 9.98 UL AWM 1028 UL BC-5W2 UL VW-1 UL Oil Res I CSA AWM I A/B FT1 CSA TEW-105 SAE J1128 Operating Temperature • -20C to +105°C (dry) • -20C to +60°C (wet or oil) Insulation Color Coding • Green Materials • C  orrosion-resistant stranded tinned copper conductors • PVC insulation Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 431 Cable > Dearborn Marine Cable > Multiconductor > Unshielded > 600 V Dearborn™ Marine Cable 600 V Unshielded, Multiconductor, Premier Duplex Cable UL BC 5W2 UL Oil Res. I UL VW-1 Materials Operating Temperature • -20°C to +105°C (dry) • -20°C to +75°C (wet) Two-Conductor Cable Wire Size Part No. AWG mm2 PDM2002 20 0.50 PDM1802 18 0.81 PDM1602 16 1.32 PDM1402 14 2.08 PDM1202 12 3.29 PDM1002 10 5.32 PDM0802 8 8.51 PDM0602 6 13.5 432 • C  orrosion-resistant stranded tinned copper conductors • White PVC insulation Availability Conductor Color Coding 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) • 1 Black, 2 Red (Minimums may apply) Stranding AWG mm 10/30 10 x 0.25 16/30 16 x 0.25 26/30 26 x 0.25 41/30 41 x 0.25 65/30 65 x 0.25 105/30 105 x 0.25 168/30 168 x 0.25 266/30 266 x 0.25 Insulation Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.048 1.22 0.060 1.52 Jacket Thickness Inch mm 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 Cable Dimension Inch mm 0.161 x 0.260 4.09 x 6.60 0.181 x 0.292 4.60 x 7.42 0.194 x 0.318 4.93 x 8.33 0.208 x 0.346 5.28 x 8.79 0.227 x 0.384 5.77 x 9.75 0.252 x 0.434 6.40 x 11.02 0.334 x 0.598 8.48 x 15.19 0.403 x 0.736 10.24 x 18.69 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Dearborn Marine Cable > Multiconductor > Unshielded > 600 V Dearborn™ Marine Cable 600 V Unshielded, Multiconductor, Premier Duplex Safety Cable UL BC 5W2 UL Oil Res. I UL VW-1 Operating Temperature Materials • C  orrosion-resistant stranded tinned copper conductors • White PVC insulation • -20°C to +105°C (dry) • -20°C to +75°C (wet) Availability Conductor Color Coding (Minimums may apply) 100 ft (30.5 m) 500 ft (152 m) • 1 Yellow, 2 Red Two-Conductor Cable Wire Size Part No. AWG mm2 PDS1802 18 0.81 PDS1602 16 1.32 PDS1402 14 2.08 PDS1202 12 3.29 PDS1002 10 5.32 PDS0802 8 8.51 PDS0602 6 13.50 Stranding AWG mm 16/30 16 x 0.25 26/30 26 x 0.25 41/30 41 x 0.25 65/30 65 x 0.25 105/30 105 x 0.25 168/30 168 x 0.25 266/30 266 x 0.25 Insulation Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.048 1.22 0.060 1.52 Jacket Thickness Inch mm 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 Cable Dimension Inch mm 0.280 x 0.172 7.11 x 4.37 0.322 x 0.194 8.18 x 4.93 0.356 x 0.211 9.04 x 5.36 0.392 x 0.230 9.96 x 5.84 0.450 x 0.250 11.43 x 6.35 0.608 x 0.336 15.44 x 8.53 0.750 x 0.420 19.05 x 10.67 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 433 Cable > Dearborn Marine Cable > Multiconductor > Unshielded > 600 V Dearborn™ Marine Cable 600 V Unshielded, Multiconductor, Premier Triplex Cable UL BC 5W2 UL Oil Res. I UL VW-1 Materials Operating Temperature • -20°C to +105°C (dry) • -20°C to +75°C (wet) Conductor Color Coding • 1 Black (ungrounded) 2 Green (ground) 3 White (ground neutral) Three-Conductor Cable Wire Size Part No. AWG mm2 PFM1603 16 1.32 PFM1403 14 2.08 PFM1203 12 3.29 PFM1003 10 5.32 PFM0803 8 8.51 PFM0603 6 13.50 434 Stranding AWG mm 26/30 26 x 0.25 41/30 41 x 0.25 65/30 65 x 0.25 105/30 105 x 0.25 168/30 168 x 0.25 266/30 266 x 0.25 Insulation Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.048 1.22 0.060 1.52 • C  orrosion-resistant stranded tinned copper conductors • White PVC insulation Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) (Minimums may apply) Jacket Thickness Inch mm 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 Cable Dimension Inch mm 0.194 x 0.442 4.93 x 11.23 0.208 x 0.484 5.28 x 12.29 0.227 x 0.541 5.77 x 13.74 0.252 x 0.616 6.40 x 15.65 0.302 x 0.766 7.67 x 19.46 0.379 x 0.997 9.63 x 25.32 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Dearborn Marine Cable > Multiconductor > Unshielded > 600 V Dearborn™ Marine Cable 600 V Unshielded, Multiconductor, Premier Round Cable UL BC 5W2 UL Oil Res. I UL VW-1 Materials Operating Temperature • -20°C to +105°C (dry) • -20°C to +75°C (wet) Conductor Color Coding • Two-Cond.  Cable: 1 Black, 2 Red • Three-Cond. Cable: 1 White, 2 Black, 3 Green • Four-Cond. Cable: 1 White, 2 Black, 3 Green, 4 Red Part No. Conductors PRM1602 PRM1603 PRM1604 PRM1402 PRM1403 PRM1404 PRM1202 PRM1203 PRM1204 PRM1002 PRM1003 PRM1004 PRM0803 PRM0804 PRM0603 PRM0604 2 3 4 2 3 4 2 3 4 2 3 4 3 4 3 4 Wire Size AWG mm2 16 1.32 16 1.32 16 1.32 14 2.08 14 2.08 14 2.08 12 3.29 12 3.29 12 3.29 10 5.32 10 5.32 10 5.32 8 8.51 8 8.51 6 13.5 6 13.5 Stranding AWG mm 26/30 26 x 0.25 26/30 26 x 0.25 26/30 26 x 0.25 41/30 41 x 0.25 41/30 41 x 0.25 41/30 41 x 0.25 65/30 65 x 0.25 65/30 65 x 0.25 65/30 65 x 0.25 105/30 105 x 0.25 105/30 105 x 0.25 105/30 105 x 0.25 168/30 266 x 0.25 168/30 266 x 0.25 266/30 266 x 0.25 266/30 266 x 0.25 Insulation Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.048 1.22 0.048 1.22 0.060 1.52 0.061 1.55 • Corrosion-resistant  stranded tinned copper conductors • PVC insulation • White PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Jacket Thickness Inch mm 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Nominal Diameter Inch mm 0.324 8.23 0.344 8.74 0.376 9.55 0.352 8.94 9.374 9.50 0.410 10.41 0.390 9.91 0.415 10.54 0.456 11.58 0.400 10.16 0.469 11.91 0.517 13.13 0.646 16.41 0.716 18.19 0.794 20.17 0.888 22.56 435 Cable > Dearborn Marine Cable > Multiconductor > Unshielded > 600 V Dearborn™ Marine Cable 600 V Unshielded, Multiconductor, Premier Clear Cote™ Cable UL BC 5W2 UL Oil Res. I UL VW-1 SAE J378B, J1128 Types GPT and HDT Materials Operating Temperature Availability • -20°C to +105°C (dry) • -20°C to +75°C (wet) 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Conductor Color Coding (Minimums may apply) • C  orrosion-resistant stranded tinned copper conductors • PVC insulation • Clear PVC jacket • 1 Black, 2 Red, 3 Green Three-Conductor Round Cable Wire Size Part No. AWG mm2 PCM1603R 16 1.32 PCM1403R 14 2.08 PCM1203R 12 3.29 Two-Conductor Parallel Cable Wire Size Part No. AWG mm2 PCM1802 18 0.81 PCM1602 16 1.32 PCM1402 14 2.08 PCM1202 12 3.29 PCM1002 10 5.32 PCM0802 8 8.51 436 Stranding AWG mm 26/30 26 x 0.25 41/30 41 x 0.25 65/30 65 x 0.25 Stranding AWG mm 16/30 16 x 0.25 26/30 26 x 0.25 41/30 41 x 0.25 65/30 65 x 0.25 105/30 105 x 0.25 168/30 168 x 0.25 Insulation Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 Insulation Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.048 1.22 Jacket Thickness Inch mm 0.035 0.89 0.035 0.89 0.035 0.89 Jacket Thickness Inch mm 0.022 0.56 0.022 0.56 0.022 0.56 0.022 0.56 0.022 0.56 0.050 1.27 Nominal Diameter Inch mm 0.292 7.42 0.329 8.36 0.370 9.40 Nominal Size Inch mm 0.244 x 0.140 6.20 x 3.56 0.272 x 0.144 6.91 x 3.66 0.306 x 0.161 7.77 x 4.09 0.197 x 0.350 5.00 x 8.89 0.226 x 0.408 5.74 x 10.36 0.364 x 0.628 9.25 x 15.95 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Dearborn Marine Cable > Multiconductor > Unshielded > 300 V Dearborn™ Marine Cable 300 V Unshielded, Multiconductor, Premier Speaker Cable Operating Temperature Availability • -20°C to +60°C Conductor Color Coding 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) • Clear (Minimums may apply) Materials • S  tranded copper conductors, one bar, one tinned • PVC insulation Two-Conductor Ripcord Cable Wire Size Part No. AWG mm2 PAM1602 16 1.32 PAM1402 14 2.08 Stranding AWG mm 26/30 26 x 0.25 41/30 41 x 0.25 Insulation Thickness Inch mm 0.027 0.69 0.027 0.69 Nominal Size Inch mm 0.115 x 0.230 2.92 x 5.84 0.140 x 0.290 3.56 x 7.37 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 437 Cable > Dearborn Marine Cable > Multiconductor > Foil/Braid Shielded > 600 V Dearborn™ Marine Cable 600 V Foil/Braid Shielded, Multiconductor, Duplex Cable UL BC 5W2 UL VW-1 • PVC insulation • Foil + braid shield Aluminum/polyester foil Tinned copper braid • White PVC jacket Operating Temperature • -20°C to +105°C (dry) • -20°C to +75°C (wet) Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Conductor Color Coding • 1 Yellow, 2 Red (Minimums may apply) Materials • C  orrosion-resistant stranded tinned copper conductors Two-Conductor Cable Part No. PSD1602 PSD1002 438 Wire Size AWG 16 10 mm2 1.32 5.32 Stranding AWG mm 26/30 26 x 0.25 105/30 105 x 0.25 Insulation Thickness Inch mm 0.032 0.81 0.032 0.81 Nominal Size Inch mm 0.340 8.64 0.438 11.13 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Dearborn Marine Cable > Multiconductor > Unshielded > 50 V Dearborn™ Marine Cable 50 V Unshielded, Multiconductor, Bonded Duplex Primary Cable SAE J1128 Type GPT SAE J378B Operating Temperature • -20°C to +105°C Conductor Color Coding • 1 Black, 2 Red Materials • C  orrosion-resistant stranded bare copper conductors • PVC insulation Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) (Minimums may apply) Part No. PWM1802B PWM1602B PWM1402B PWM1202B PWM1002B Wire Size AWG 18 16 14 12 10 mm2 0.81 1.23 1.94 3.08 4.92 Stranding AWG mm 16/0.009 16 x 0.23 19/29 19 x 0.29 19/27 19 x 0.36 19/25 19 x 0.45 19/23 19 x 0.57 Insulation Thickness Inch mm 0.023 0.58 0.023 0.58 0.023 0.58 0.023 0.58 0.023 0.58 Nominal Size Inch mm 0.094 x 0.189 2.39 x 4.80 0.102 x 0.204 2.59 x 5.18 0.117 x 0.235 2.97 x 5.97 0.142 x 0.285 3.61 x 7.24 0.176 x 0.353 4.47 x 8.97 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 439 Cable > Dearborn Marine Cable > Multiconductor > Unshielded > 600 V Dearborn™ Marine Cable 600 V Unshielded, Multiconductor, Flat Bonded Trailer Cable SAE J378/J1128 Type GPT Materials Operating Temperature • -20°C to +105°C • S  tranded bare copper conductors • PVC insulation Conductor Color Coding Availability • 1 Brown, 2 Yellow, 3 Green, 4 White 100 ft (30.5 m) Bulk, cut to length (Minimums may apply) Part No. Conductors PTB1603 PTB1604 3 4 440 Wire Size AWG mm2 16 1.23 16 1.23 Stranding AWG mm 19/29 19 x 0.29 19/29 19 x 0.29 Insulation Thickness Inch mm 0.023 0.58 0.023 0.58 Nominal Size Inch mm 0. 013 x 0.309 2.62 x 7.85 0.103 x 0.412 2.62 x 10.46 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Dearborn Marine Cable > Multiconductor > Unshielded > 600 V Dearborn™ Marine Cable 600 V Unshielded, Multiconductor, Premier Round Trailer Cable UL BC 5W2 Materials Operating Temperature • C  orrosion-resistant stranded tinned copper conductors • Clear PVC jacket • -20°C to +105°C Availability Conductor Color Coding Conductor Colors • 1 Brown, 2 Yellow, 3 Green, 4 White 100 ft (30.5 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) Four-Conductor Cable Part No. PTM1604 PTM1404 Wire Size AWG 16 14 mm2 1.32 2.08 Stranding AWG mm 26/30 26 x 0.25 41/30 41 x 0.25 Insulation Thickness Inch mm 0.031 0.79 0.031 0.79 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Nominal Size Inch mm 0.399 10.13 0.440 11.18 441 Market-Specific Solutions Sets The Fast Track to Finding the Perfect Product Find the wire, cable, and wire management products especially suited to your application with our market-specific solution sets. We’ve taken our expertise in different industries and applications and picked products that match specific application needs. You’ll be able to find and specify products faster and easier. Products in each solution set reflect the specific needs for electrical performance, durability under mechanical and environmental stresses, standards compliance, and all the other details that distinguish your application in such industries as: • • • • • • • • • Consumer goods Food and beverage Material handling Medical devices Military Industrial packaging Pharmaceutical Solar power Wind power Visit www.alphawire.com to find out more about our market specific solution sets. 442 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com.
PAM1402CL005 价格&库存
很抱歉,暂时无法提供与“PAM1402CL005”相匹配的价格&库存,您可以联系我们找货
